Question about Kenmore Washing Machines
I have a Kenmore washer model 110.81620100 that has completly stopped working. It's in the garage and pipes froze in winter. When it warmed up I ran the washer-got water-but smelled like burning rubber. I turned the machine off and let cool down, and now it won't turn on at all on any cycle. Someone said check the fuse, but I don't know where that is located-cannot find any websites for this model. Others say it may have burnt the pump or motor?
  • 62 Answers
Here is a website link to your washer just click on the link and it will have your modle number listed below and the list of subcomponents. It is probable your motor as most kenmore top loaders do not have a fuse. Some older maytags did,...but not kenmore. Here is the link. Good luck! Don't hesitate to write back if you have further questions. I really think you need a motor though.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.81620100
Posted on May 13, 2009
Ouch washer wouldn't fill because the water line was frozen. Now it will wash but won't spin out. It is in the garage and it is -6C
The only thing to do is wait for it to warm up enough to know if the cold is causing the problem. Could be ice
Jan 27, 2017 | Washing Machines
Wiper fluid keeps freezing drained all old wiper fluid and put in rain x -25 and it still froze
Rain X should have alleviated the freezing problem assuming that you circulated enough of it through the tubing and through the nozzles before it froze again.
Maybe try to disassemble the nozzle and soak in the Rain X solution or warm water to unfreeze it.
Trace the piping or tubing to the place where the frozen water exists and eliminate the ice by warming it up.
You may take the whole vehicle to a heated garage and let it thaw out, then circulate the fluid by pushing the button or switch to operate the windshield wiper fluid pump.
Jan 14, 2011 | 2008 Chevrolet Tahoe
Have hot/cold water pipes coming outside from roofspace in house to garage for washer/dryer. Already had two bursts inside garage and machine and electrics destroyed. New machine installed after...
Insulation only slows down the transfer of heat (cold), it does not stop it. If it is below freezing and the water in any pipe is not moving, it will eventually freeze. Most major industrial supply houses like McMaster-Carr or Grainger in the US, carry pipe tracing tape. It comes in various lengths and you secure it to the pipe under the insulation, plug it in and many types have integral thermostats that keep the pipe above freezing. If you have a washing machine, you will have to consider the lines to the washer valves, both hot & cold and any other areas in the washer that may hold water like the pump and the discharge hoses.
Was this washer always outdoors?
Jan 08, 2011 | Easy Heat Water Pipe Heating Cable
It is very cold in my garage where my Fisher and Paykel washing machine is. First it would not fill it just ran and ran without filling, then it started filling fine, but then after a while started...
water freezes. sounds like first your fill pipes were froze then the pump froze. if you can find a place inside the house for washer or you may have to build a room around washer and dryer and heat it
Dec 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
Refrigerator/freezer in garage doesn't keep food frozen in winter
Yes there is a solution. You need to install a garage Thermostat Heater. This will trick the thermostat into thinking it is in a warm environment. This article will tell you why this is happening and the solution as I described. Sorry but for some reason I cannot post this as a link. Copy & Paste into your browser. http://applianceparts.wordpress.com/2009/01/12/why-won’t-the-freezer-in-my-garage-refrigerator-freeze/
Dec 07, 2009 | Kenmore Freezers
2005 Honda Accord power door locks froze a couple of times last winter, had to wait until the afternoon when the temperature warmed up to work. Dealer claimed that the actuators worked properly when they...
The dealer is full of garbage. This is a common issue with Accords. It will only get worse until they stop working. Fight them to replace them.
Sep 30, 2009 | 2005 Honda Accord
Kenmore 90 series washer model 20922 wont drain
have you tryed blowing back the drain pipe to clear and sourse of fault,also is the water element heater working ok?it could be waiting at a thermostop position till its up to correct temp,hope this helps
May 27, 2009 | Kenmore 15944 Top Load Washer
My husband forgot to winterize our Kenmore Elite H3 washer when we moved. It was stored in our garage for 5 months(September - February). When we hooked it up water immediately started pouring from the...
Its most likely the rubber tubing, and sack that connect the drum to the drain pump. You can either remove the back panel, or the panel in the bottom front of your washer to check for cracks in the rubber. It might be as simple as the tube came out of place during the move.
Mar 13, 2009 | Washing Machines
Washing Machines Logo
83 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
