Question about Amana ACD2232HR Side by Side Refrigerator
Fridge is leaking
Earlier I posted a question but was not clear enough on the problem.  My Fridge leaks water ONLY when you try to dipense water.  We unhooked the water line when this first started, thinking the hose had froze, but now it has been unhooked for about 6 months, now we are trying to REALLY fix the problem so our icemaker and water dispenser works.  Ok, now when we hooked everything back up, and tried to dipense water again....water came out in the floor on the left back side of the fridge---can this be fixed?
  • lgladding Aug 29, 2008
    The plastic water line has broken off between the freezer and the freezer door. How to replace?? LeeAnn
  • 114 Answers
Your plastic line which carries water to the dispenser has a crack in it.  Activate the dispenser and have another person pinpoint the lead and splice two pieces together with plastic connector.
Posted on Oct 15, 2007
Why does my samsung fridge leak water under the fridge when I use my water dispensor?
hi Todd.
Problem: It's leaking water. ... Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leakingout of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself - CNET
https://www.cnet.com/.../three-common-refrigerator-problems-you-can-easily-fix-yourse...
Why is my refrigerator leaking water from the bottom?If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.17 May 2013SOLVED: Water leak in refrigerator? - Refrigerator - iFixithttps://www.ifixit.com/Answers/View/128713/Water+leak+in+refrigeratorSearch for: Why is my refrigerator leaking water from the bottom?
Why does samsung fridge leak water under the fridge Google Search
Nov 27, 2017 | Samsung Refrigerators
Why is my 2002 Whirlpool top-mount Refrigerator leaking water inside the fridge. About every two weeks my fridge leaks water in the inside, not enough to run on the floor but, must remove everything to...
Check the defrost drain/trap, its clogged, so the water cup is overflowing and water runs down the inside back of the unit. Clear the drain/trap and it should be fine.
Feb 24, 2015 | Whirlpool Refrigerators
Water leaks at bottom of fridge
The same thing happened to me then I noticed ice had formed at the bottom of our fridge. It was covering a drain hole so water was leaking out the front of fridge instead of going to the drain pan or wherever the hole goes. After I chipped out the ice and cleared the hole with warm water the leak stopped. I also fixed another leak coming from bottom of fridge caused by a loose brass connection on water line going to the door.
May 25, 2014 | Hotpoint HSS25GFP Side by Side...
Fridge leaks on the inside
The drain line in the freezer is blocked. It drains the water away after the defrost cycle. You will need to post your model number for me to be of more help.
Mar 30, 2012 | Refrigerators
Frozen potatoes and soft butter, fridge not working
Anytime one of the cooling tubes is blocked it forces the cold air from the freezer through the open cooling tube or tubes so you will have spot freeze ups. Suggest you use a flexible wire like a guitar string to attemp to clear the blockage. If you heat the wire with a hair dryer, it will make the job faster.
As far as the unit resetting itself, it could be a preset condition. If the sensor are telling the control board one thing and you are trying to change settings, then the preset conditions could be over riding your commands. Get the cooling tubes cleared and see if things go back to normal.
The water dispenser - could be you have a leak in the water line running into the door or it could be the water depenser itself. Not enough data to tell - suggest you localize the leak. Sometimes flour will tell you where the leak starts.
Jan 08, 2012 | Refrigerators
WATER LEAKING IN MY FRIDGE
OK I will try to help but I see the date of your post is close to 2 weeks ago. Sea Breeze
Jul 07, 2009 | GE GTS22KBP Top Freezer Refrigerator
Water leaking along back interior to bottom under & over veggie bins
Sounds like the drain to the drip pan is clogged -- maybe with ice.
Defrost water runs down to a drain in the bottom of the fridge and into a pan underneath where it evaporates.
Sounds like the defrost water is not reaching its final destination.
Here's the way the same problem was solved earlier today:
For those who have this problem with this model: The drip pan is in an open space on the back side of the refrigerator. There is a rubber spout that empties into it. But to clear clogs...you must take out the shelves from the freezer, unscrew and remove the back panel on the inside of the freezer. There you will see the water exit. Boiling water cleared it out.
May 29, 2009 | GE Refrigerators
Water leaking inside of refrigerator from freezer
IT SEEMS LIKE YOU HAVE A CLOGGED DRAIN . CHECK YOUR CONDECER COILS BEHIND KICK PLATE .. AFTER THAT YOU CAN UNPLUG FRIDGE FOR 24 HRS WITH DOORS OPEN AND SOULD DEFROST ENOUGH TO CLEAR DRAIN . IF NOT . DEPENDING ON MODEL YOU SOULD BE ABLE TO GET THROUGH DRAIN THROUGH MOST FREEZERS .
Feb 03, 2009 | Kenmore Refrigerators
Side by side w/ dipenser ge refridgerator
Your unit is under charge and need to check for leak. Please call qualified technician.
Jan 01, 2008 | Refrigerators
Amana ACD2232HR Side by Side Refrigerator Logo
141 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
