Question about Dishwashers
No Power, my raise green light lit when power off. when switch depressed, red light does not lit, no power. in any cycle. I replaced the power switch, and the door switch. No luck Please help
  • kooyuen May 13, 2009
    This is a Haier HDB18EB Model.
    The green risen light comes on green when power is off. The red power light does not come on regardless what you do. The terminal block location please????
    Thanks, you are the best
  • 6,784 Answers
Hi, you will need to inspect the terminal block for damage , as well as, the control board for damage. The terminal block is the device that will have the power cord wired directly to it. make sure this block isn't damaged. inspect for any discoloration that may show a burn out or loose wire.
Check the control board for lose pin connections as well. make sure the control is functioning. replace if it shows signs of burn out.
Posted on May 13, 2009
  • Michael Masters
    Michael Masters May 13, 2009
    to reach the terminal block, all you have to do is follow the power cord to the actual block. it is a direct wire to the block. the block can be removed by unscrewing from the unit.
    This may be a control fault if the red light isn't illuminating when pressed.
  • Michael Masters
    the terminal block(electrical junction box) is located on the rear bottom side in the middle. inspect carefully for damaged or loose wires and connections.
2003 ford exloper sport xtl 4x4 brake lights dont work
Find the brake light switch mounted on the bracket right above the brake pedal. There should be power on the light green with red wire all the time. If there is no power check fuse 23 in the central junction block. If there is power check for power on the tan with black wire with the brake pedal depressed. If there is not power replace the brake pedal switch. If there is power there than it is possible that all the bulbs are burned out or there is a wiring issue to the rear lamps
Apr 23, 2016 | Ford Cars & Trucks
No power
you have a low amp fuse protecting transformer. could be thermostat issues.
Dec 12, 2013 | Ruud Rheem Corsaire Control Circuit Board...
My brake lights are not working at all. The fuses are not blown
Hi!!
Check the Brake Pedal Position Switch on top of the brake pedal, the Lt Green w/Red stripe wire should always have 12v+, when brake pedal is depressed the Lt Green wire should have 12v+ also, if no power on Lt. Green w/Red wire, check fuse # 2 20A, if no power on Lt. Green wire when pedal depressed, REPLACE Switch, If there is power on both wires when pedal is depressed, check IVD STOP LAMP RELAY on the Aux. Relay Box 1 located at the Left Front of the Engine Compartment.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Feb 16, 2011 | 2003 Lincoln Navigator
Would a bad Flasher relay cause the brake lights not to work?
The flasher does not stop the brake lights from working. Check # 18 fuse in fusebox under lower left side of dash. if it's ok, the brake light switch, on the brake pedal arm is next. light green wire with red stripe is hot if fuse 18 is ok. Depress brake pedal, light green with no stripe should have power. if not, replace brake light switch. If light green wire has power with pedal depressed, combination switch under the steering is next. Remove the cover from around the combo switch {under the steering wheel}. depress brake pedal, light green wire should have power. If it does, pedal still depressed, orange with light blue wire & wire with light green & orange should have power. Those 2 wires are brake & rear turn signal wires. { The turn signal switch should be in the middle, not right position or left. while checking for power in the last 2 wires. Good Luck drvolt.
Feb 06, 2011 | 2004 Ford F250
Green power light is flashing and red light next to it stays lit
A flashing green on printer light generally means its waiting for a command for instance, push print, stop etc... also check that the pause button has not been pushed. if so depress again to release printing process
Jul 11, 2010 | Epson Stylus Photo 1280 InkJet Printer
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
60SDX88B. No video, No sound. DP06 Protection
not a solution but i have a 50gx30b doing something similar, no picture no sound, 3 green leds are lit up on the main board and then one red led lit up also on main board, front panel red led stays on for about 30 -50 seconds and then it all shuts off, I then have to unplug and replug to get the same results.
Mar 03, 2010 | Hitachi 60SDX88B 60" Rear Projection...
Green power light on no sound or picture cycles
MAYBE INVERTER BOARD BAD..
INVERTER BOARD IS A PART OF THE LCD PANEL UNIT
Sep 28, 2009 | Sharp LC-32SH12U TV
Dishwashers Logo
42 people viewed this question
Top Dishwashers Experts
Owen Barnes
