Question about Apple iPhone Smartphone
My problem is when I 'm trying to make a phone call, by touching the key pad the digits don't appear on the screen, so I cannot call a new number. Zac
    President:
  • Apple Master
  • 688 Answers
Hi Zac,
Is your phone an iPhone i presume it is.
it sounds as though the phone software may be corrupt.
Have you tried restoring it.
if the phone is unlocked, restoring it will lock it but you can easily unlock it again with quickpwn.
Back your phone up on itunes and then restore it.
if you want an older version of the software, when you click restore press the shift key and
you can browse your computer for the older firmware version.
If this is all greek to you maybe you should have someone look at the phone for you.
Posted on May 13, 2009
Work centre 5775 touch control do not work properly because of wrong calliberation
Enter the UI Diagnostic Tests menu by simultaneously pressing the Phone, #, and * buttons.
Use the number key pad on the Control Panel to select Diagnostic Test number for Touch Panel Calibration
A grid will appear on the touch screen with intersecting lines.
Use a pencil to tap the center of the + in the top left. The + will move around, each time it does use the pencil to touch the center of the +
After you touch the center of the + for the bottom right corner, the calibration should be complete
Exit out of the UI Diagnostics by pressing 0 for Exit
Nov 11, 2017 | Cell Phones
How do I do a hard reset for my motorola blurr? I'm having problems with the touch screen sensitivity. It selects things that I don't touch, and doesn't select what I do touch, please help!!
  • If the device is responsive, back up all necessary data.
  • Power off the phone
  • While the phone is off, press and hold the Camera key, then turn the phone back on using the Lock/Power key
    • Note: Continue to hold down the Camera key while the phone boots up
  • When prompted, release the Camera key
  • On the USB FastBoot/BOOTLOADR MENU screen, press and release the Volume down key to enter the Recovery Mode
    • If done correctly, you will see VOLUME DOWN KEY PRESSED appear on the screen
    • IMPORTANT: You only have 10 seconds to complete this step before the device powers back on. If that occurs, you will need to start back at Step 1
  • When the "Triangle!" screen appears, tap the bottom right corner of the display to access the Motorola system recovery screen .
    • Note: If this doesnt work, Touch the bottom right corner and make a small circle gesture to access the recovery screen.
  • Highlight the row labeled wipe data/factory reset [Alt+W]
    • Note: You can use the touch display, volume up/down keys, or the Tinytouch pad to highlight the row
  • Tap Ok to begin the wipe/factory reset
  • When the wipe is complete and the device returns to the Motorola system recover page, highlight the row labeled reboot system now [Menu+Back]
  • Tap Ok to begin the reboot
  • When the device powers back up, you will see the MOTOBLUR setup screen and have the option to create or sign into an existing BLUR account
  • May 28, 2012 | Motorola Cell Phones
    Touch not working for contact shortcut
    Yoou can simply restart your handset sir. ;)
    Dec 10, 2009 | Nokia 5530 XpressMusic Smartphone
    My blitz doesnt text
    Try this. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
    Hope this helps, let me know if this works or if I can help you with anything else.
    JimmyC
    Aug 05, 2009 | UTStarcom Blitz Cell Phone
    LG Secret touch screen, can not use left upper, middle & right upper touch screen pad .... cannot add contacts, back space or forward a message .... When the phone is hot - the touch screen does not...
    I have the same problem sometimes, when it happen I press the touch media key in the middle right side of the phone, and enter to the pictures aplication and exit touching the screen, this appear to recalibrate the touch pad most of the times.
    Jun 06, 2009 | LG Secret ? KF750 Cellular Phone
    Keyboard will not work
    Try this and see if this works for you. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
    Let me know if this works for you, if not let me know.
    JimmyC
    May 07, 2009 | UTStarcom Blitz Cell Phone
    DROPPED PHONE NOT SURE WHAT I NEED
    You can replace the lcd screen and digitizer.
    Its about $40 US on ebay. Try searching treo 750wx screen/digitizer/touch screen, etc. Also i tried searching treo 750wx but it didn't work, I suspect the 750 to be the same as the wx, but you might wanna make sure with the seller incase (Ask seller a question link is on the listing, or click their username and go to their profile and click on contact)
    Feb 27, 2009 | Palm Cell Phones
    Iphone has a problem
    Hi Bob. If your touch screen is fully functional on other areas or pages, I would restore the firmware. Should take care of that prob. If it is not responding at all, then you would probably be looking at replacing your digitizer.
    Jan 29, 2009 | Apple iPhone Smartphone
    White screen!!
    my lg's camera started to turn my phone off, i do tech work for a wireless company and when i was trouble shooting my own phone as a test i went to my camera and my screen went blank! i tryed every thing, but the master reset. because my screen is blank i need to know the number i will have to enter to get it reset from the key pad.
    Sep 30, 2008 | LG CHOCOLATE VX8500 Cellular Phone
    Apple iPhone Smartphone Logo
    Top Apple Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Lesley Cameron
    Lesley Cameron
    Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
