Question about Maytag Dryers
Wire to heating element burns in two at connection on element. Crimping on a new lug lasts for a few days and then burns again.
  • 323 Answers
Did it just start burning out on its own, or have you recently changed the element or the wire to the element?
It sounds like the crimp isn't nearly heavy enough for the wire. If the wire isn't burned, and the element is the right one, then either the wire is not a heavy enough guage or the crimp is too light weight for that connection.
Dryers are 240 volts and there's a lot of amps going through that connector. If it is not the same as the original, buy a heavy duty crimp ring from an electrical supply house for that guage of wire or at a Home Depot or Lowes.
Let us know if that's not the case.
Sirwriter
Posted on May 13, 2009
The wire connecting to the heating element keeps melting/burning. Ive replaced it twice, each time it melted, how do i fix it?
What size wire? When you replaced the heating coil, what did you use? Was it OEM? What part number? Do you have an ohm meter?
Apr 11, 2014 | Dryers
2000 Isuzu Rodeo LS V6 starter issue. I bought this starter a year ago and it has been doing the same thing from day 1. I have had this rebuilt starter tested at a few places and everyone says it'
The key line was bad,
if you had hot wired any starter solenoid on that tiny pin
then in 1 second you saw it cranks ok, ending 2 starter pulls.
then saw it green with corrosion, or cramp bad bad or lug bad.
they sell new FASTON(tm) crimp lugs in stores with the correct tool to do that.
you can make a new wire, and crimp it sitting at a table.
then solder and heat shrink it back to the harness wire.
this is like electrics 101 here.
its just a wire. and a lug,.
or do that all laying on your back under the car,
your call.
all this is very easy, why not ask any shop to do that.
Mar 07, 2017 | 2000 Isuzu Rodeo
Our Lakewood 5101 oil heater gets warm, but over the last few days, it is not getting hot like it used to. It seems like it has slowly been getting colder over the last week or so. I can feel the heat...
Appears you have a heating element issue. Many of these elements are segmented for temp control. If one part goes fubar the heater will work but not put out the heat it used to unless you replace the element with a new one that has no burnt out sections.
May 03, 2017 | Lakewood 5101 Oil Filled Radiator Heater
I have a Maytag Electric Dryer model #MDE5500AYW that will not heat up. When I opened the front and looked at the heating element, I noticed that the wire attached to the heating element (a black wire)...
Okay have you replaced the wire with with the correct one? If the wire gauge is wrong it will do every time next you need a volt meter with a buzzer sound maker on it test your thermostat and hi limit thermostat if it makes a noise when testing its working. Only thing that would cause that wire to keep burning are those options and if all checks out okay then its faulty wiring which is grounding out somewhere which is a pain to trace and if you might not find the bad wire had a few of these with these problems and I ended up junking them big fire hazard sorry for the problem.
Jan 06, 2011 | Maytag MDE5500AYW Electric Dryer
My dryer is not heating right now just cold. We
If you are buying the element and installing it yourself they are not that expensive. But you have to make sure you have a solid conection to the wires that come with it. Make sure you use a good crimping tool. Check the your electrical cord itself as it might have overheated and damaged its ground wire. Those can be bought at WalMart. All your conections must be TIGHT.
Dec 29, 2009 | Dryers
When welding, the wire burns off and falls to the ground instead of going to the metal, i increase speed which seems to help but the weld has problems penetrating, when i turn heat up the wire burns off...
1- you may need to change the polarity in the machine. I am welding with solid core wire and the power feed wire in the upper right corner is on the + lug and the wire going up into the machine is on the -- lug. These lug connections are under the flip up cover.
2- Are you keeping the tip a 1/2" to 3/4" from the work ?
Nov 30, 2009 | Garden
Recently the heating element was replaced along with a sensor. Since then it has been running fine, but about a month ago, the wire attached to the heating element corroded through. I initially thought...
more often than not those connections are loose and that jsut cannot be
but check your outlet voltage it should read 220 across the poles anything else it could eb trouble
Oct 06, 2009 | Whirlpool Dryers
I have a Frigidaire self cleaning electric oven. I heard a two pops and this tripped the circuit breaker. I can't reset the circuit breaker because the pops occur again and trip the breaker again. Any...
Sounds like a shorted wire or something grounding.
Slide out range and unplug and take off bake and look around for a short either at the bake or broil element ot at the terminal where the cord connects.
Oct 01, 2009 | Kitchen Ranges
Need service for Malber 1000 heating element..
Hi. Mike here. I repair Malbers in the Washington D.C. area. The most likely problem is not the heating element, but the hi-temp (or "brown") thermostat. They cost about $25 and are very simple to install. A "Torx 1.5" screwdriver (asterisk tip) removes two screws, in back, holding top on. Lift off top, and (from the front) see silver-foil-wrapped heating assy. At lower right will be a small philips screw holding a thin wire "hasp" which holds the thermostat in place. Remove screw and hasp (without dropping in machine!), unplug two "quiik-connect" lugs (orange & red wires) and pull out thermostat to the right. New one slips right back in. Replace wires, hasp, phillips screw and top -and you're done! This is 90% sure to fix. The heating element is only about 5% likely.
One last thing ... when re-inserting new thermostat, you'll have to "wrestle" with it a bit, as the tip needs to slip into a tiny (hard to "find") hole. Keep trying, and eventually it'll fit ALL the way in, so the hasp can hold it. To purchase part, call Joel (at Malber): 800-600-8913
Oh yeah, one MORE last thing... That red wire may be burnt a little, or completely burnt in two. Radio Shack and Home Depot sell "crimp-on" lugs (1/4") like these (female). Trim back the wire, crimp a new lug on the end, and push it back onto lower terminal on thermostat. If wire is too short, of course, add a few inches of 16 guage "stranded" (lamp cord). The same stores also sell tubular "crimp-on" wire-connectors (little blue tubes) to join the old and new wires. May God bless.
Mar 02, 2009 | Malber WD1000 Front Load Washer/Dryer
Admiral Dryer will not heat
Bad connection
this wiil cause this make sure to use a Hi Heat connector abnd the connections are tight
Apr 27, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
134 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
