Question about GE GSS25SGMBS Side by Side Refrigerator
GE model GSS20DBMB
I would like to know how many cubic feet of regrigerator space I will have if I purchase this refrigerator
  • Victor
    Victor May 11, 2010
    Most model #'s..... The 20 is the cubic feet.
aborcass
  • 2651 Answers
SOURCE: I have a refrigerator model
ctx14cys**** the 14 is a give away, it would be a ctx16 if 16 cube. heres a sire just pop in the model number ittl clearly stae it, ifthe link doenst work, i went to www.ge.com, ad nfound it through there
http://genet.geappliances.com/DocSearch/Dispatcher
Posted on Apr 09, 2008
  • 19 Answers
SOURCE: Refrigerator not cold enough
yes, if theres a warranty on it, call the place you bought it and have them send out a service tech. you should not have to pay anything.
Posted on Apr 22, 2009
projdoc
  • 2237 Answers
SOURCE: I have a GE Refrigerator model # TEX21J1SRRAD 20.6
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Posted on Aug 26, 2009
aasc
  • 1606 Answers
SOURCE: what is the cubic feet of gts18fcsarww
18 cu ft . Look familiar ?
Posted on Oct 10, 2009
SOURCE: cubic feet size of Kenmore refrigerator
Try this site: http://www.kouba-cavallo.com/refmods.htm
Posted on Nov 12, 2009
How many cubic feet is ge hotpoint refridgerator, model number ctx14ayxkrwh
The number 14 in your model number is the cubic feet. It could be 14.2.
Oct 20, 2014 | GE Hotpoint Top-Freezer Refrigerator
WHAT IS THE CUBIC FEET OF JVM1339WB-002 GE MICROWAVE SPACE SAVER?
Determining the cubic feet of any given appliance, Microwave, Oven, Freezer or Refrigerator is quite simple.
Follow these steps.
Open the door of your microwave and measure the length, width and height in inches of the interior cavity.
Multiply the length by the width by the height using a calculator to get the total in cubic inches.
Divide the cubic inches by 1,728, which is the volume of a cubic foot. The resulting number will be your microwave's measurement in cubic feet. You can also use an online conversion calculator to simplify matters
Hope that helps
Sep 12, 2014 | General Electric Microwave Ovens
What is the cu ft of Model FRT21IL4FW3 Freezer space?
Easiest solution is to measure the inside dimensions in inches, tall, width and depth. Then multiply the three dimensions t x w x d = cubic inches. To get cubic feet then divide the above answer by 1728 and the result is cubic feet..
For instance if the fridge is 60 inches tall x 24 inches wide x 18 inches deep; the answer is 60 x 24 x 18 = 25,929 cubic inches... 25,920 divided by 1728 = 15 cubic feet.
Jul 12, 2014 | GE GSH25JSTSS Stainless Steel Side by Side...
How many cubic feet is my ge fridge, TFX25JP?
The first few numbers in the model number indicate the cubic footage...so that refrigerator is 25 cubic feet
GENE
Sep 08, 2011 | GE Refrigerators
Cubic feet in a GE MOdel TFX22KRCE WW
If there is nothing inside the refrigerator that will tell you its cubic feet, you could always calculate it on your own. See this link:
http://www.ehow.com/how_4530599_find-cubic-feet-refrigerator.html
Jun 17, 2009 | Computer Gear Fridge Gears Puzzle
How big inside (cubic ft.) is the Roper refridgerator
20.9 cubic feet for model # RT21AKXKQ
14 cubic feet for model number RT14BKXKQ05
Jun 07, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
GE GSS25SGMBS Side by Side Refrigerator Logo
106 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
