Question about Fujitsu IPAD 100 (ipad10010) Portable Terminal
Need the driver for the Fujitsu 100 Terminal
Need the driver for the Fujitsu 100 "B-PAD USB Serial" docking station. The docking bay holds the Fujitsu iPAD and connects to USB port on desktop/laptop so that you can connect to the flash drive on the "Windows CE" pocket PC that is part of the iPAD. Any help is greatly appreciated...
2 Suggested Answers
PauldLucky
  • 268 Answers
SOURCE: IPAD 100 - I need usb driver for xp
This is the best way to download the drivers of all your devices which are connected to the system for free.
You can download them easily using the software application called "Driver Magician"
Here : http://www.drivermagician.com/DriverMagician.exe
Install and register with the following details,
"username"="Angels"
"serialnumber"="8974-9325-643"
You are ready to go download unlimited and all the drivers for all the devices you connect.
Good Luck.
Live, Love, Laugh
Posted on Sep 12, 2008
How can i update dell dock?
A docking station is an extension or addition of ports for a laptop computer. Once the portable computer is docked, you can access the docking station's ports, such as PS/2 or USB 2.0 ports, through your computer. Some docking stations have monitors that you can connect your computer to, placing your video on an external screen so you can turn off your computer's monitor and conserve some of your computer's energy. All Dell docking stations will have the same general troubleshooting steps.
Plug your laptop's power adapter into the docking station and dock your laptop onto/into the docking station. If there is no power going to your laptop from the docking station but it works when the power adapter is plugged into the wall, the docking station is bad and needs to be replaced. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power goes on but your computer doesn't recognizes accessories such as a USB mouse--plugged into the docking station, try a different port on the station. If it works in a different port, the previous USB port is burned out. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized, you might have a corrupted docking profile. Undock the computer and dock it again once it has fully started up to reset the docking profile. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If you have an external monitor and it is not working, completely close the lid on the laptop so the image will move to the external monitor. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized and resetting the docking profile fails, update all drivers through Dell's support website and then re-dock the computer. Some of the software that runs the hardware may have become corrupted. Hope this helps
b>
Jan 16, 2013 | Dell Inspiron 1545 Notebook
Docking station with known good SATA drive is not visible in My Computer
check the drive is visible to windows...
control panel>administrative tools>computer management>storage>disk management
it will list all drives (even ones you can't see in explorer)
assign it a drive letter and make it active from there.
May 10, 2012 | BYTECC T200U3 25_35 Black USB 30 Single...
When disconnected from docking station touchpad
there are fixes on dell support site for this, goto dell support and enter your mdoel number for laptop and search for its drivers solotiions, also do same for docking station. http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=dhs&cs=19
Nov 28, 2009 | Dell F3534 Touchpad
When I install the driver and the computer restarts I get a blue screen that tells me a fatal error has occured and windows will not start normally. The only way to get past this screen is to restart in...
When you install the drivers, are you installing them while the laptop is conected to the docking station? If so, try installing with docking first. Then after installation, shut down your computer. Dock the comptuer, then start the computer back up. If you get a blue screen, go into your bios and make sure that your USB setting is set to High Speed.
Please make sure that the docking station is plugged into your notebook before booting up, there is an issue that all expresscard docks share with plugging the docking station in while the notebook is powered on.
If there is a switch located on the Expresscard
On-Pre-boot support
Off-Post-boot support (Default)
This switch is used to determine how the dock is recognized in the
system at boot up stage. Certain notebooks will detect the dock and not
work properly during a pre-boot mode (ie. trying to boot up on the
external VGA device, not the internal VGA of the Notebook). This was
observed in notebooks (Fujitsu, some Sony and Toshiba models) that
use a BIOS developed by Phoenix Technologies. If you experience
such issue, please turn the switch from the default "OFF" position to
"ON". You will only need to set it once.
Jul 23, 2009 | Targus ACP50US Docking Station
How does a USB docking station work w/ a regular docking station
the older pc probably needs a usb 2.0 port to run docking station. the manual on the docking station should tell you. you may need to install a usb 2.0 pci card in your older computer for it to work.
Mar 18, 2009 | Dell Inspiron 5160 Notebook
"username"="Angels"
Good Luck.
Live, Love, Laugh
Sep 12, 2008 | Fujitsu IPAD 100 (ipad10010) Portable...
I have two docking stations for my Travelmate 8103WLMi both docking statins have lost there USB port connectivity. Is there anything that can be done so that the USB ports work again?
Try updating the drivers for the docking stations. Even in commonly used items such as docking stations which can be used without drivers, if you go to the manufacturer's web site and download drivers or management software, you will find it works better.
Otherwise, try somone else's laptop with those docking stations to make sure it's not your latop causing the problem. If it doesn't work for them either, the docking station is broken and there is really nothing you can do about that short of paying more than it's worth for someone to change out the USB component of the docking station.
Jul 09, 2008 | Acer Computers & Internet
Fujitsu IPAD 100 (ipad10010) Portable Terminal Logo
112 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
