Question about Sanyo PLC XP46L Multimedia Projector
Have the service codes up but I don't know which codes shows lamp hours.
  • klb3 May 13, 2009
    Hold up arrow for 22 seconds. Lamp hours will display for 5 seconds.
Hold down up arrow for 22 seconds and lamp hours will display for 5 seconds.
Posted on May 14, 2009
Tv randomly loses pictrue but not sound when watching
May be you need replace the lamp.
Time life aprox 3000 hours
If the picture is dark or don`t show picture, but you get sound, try replace the lamp
Is easy. You can find it in www.Amazon.com I recommend you buy Electrified brand.
Sep 16, 2011 | Televison & Video
I have a Sony model KDF-e55a20. I just changed the buld but I still don't get any picture all I get is the power on light blinks 3 times. Does anyone know what the problem is?
Sir reset the lamp timer of your unit.
1 Press "Display" on the remote, followed by the 5 button, then the sound up key, and "power on". Do this while the tv is in stand by mode.
2 Then press "jump" 3 times to enter DE service menu.The tv screen will display the total lamp time hours.
3 Reset the the lamp time by pressing channel 3, then mute, then enter.This will return lamp timer back to 0. Hope this may help good day and best regards.
Aug 18, 2011 | Sony KV-36FV26 TV
The old lamp in my in focus LS 110 reached its maximum hours. I replaced with a new lamp but it is not firing up - i think I need to reset the lamp hours but don't know how and don't have the...
Sorry, I am not familiar with the Infocus LS 110 but the user guide can be downloaded at
http://www.retrevo.com/support/InFocus-LS110-Projectors-manual/id/1081dj697/t/2/
You don't need to put in your email address but you will need to type in the numbers. It come in a PDF format so you will need adobie acrobat to read the file. It should have instructions on how to reset the lamp hours.
Hope this helps
Aug 01, 2011 | InFocus LS 110 Multimedia Projector
There is no light coming out of the projector, I have replaced the bulb and still no luck
Welcome to Fixya!
Have you placed the bulb right , i mean if you shake it really hard you may damage it , moreover check the position of the bulb if it stays fitted ,
More over Your lamp has a warranty typically. No matter what, don't expect any more than 1,000 hours out of a projector lamp, and budget accordingly. I had my first lamp go, in low power, when rated for 5,000 hours - at 1,200 hours
This is the way projectors work, and is unfortunate, but ignore the owners manual, because if the lamp was really going to last 2,000 hours they would WARRANTY it for 2,000 hours. The fact that they don't clearly show that how much it lasts for.
Now how can you prolong the lamp life.
i believe most home use projector's lamp's life can over 2K hours at lab.
but the environment should be as:
1. no use it over 3 hours each time.
2. keep the room degree at 20-25C
3. keep your room very clean.
4. adjust projector's fan speed to fast
Do comment if it helped you in any matter
Apr 19, 2011 | Televison & Video
HI I WANT SERVICE CODE OF INFOCUS LP600 ASKC175
I am not exactly sure what service code you are searching for, what is happening with the projector? You turn it on and immediately it's looking for a code? Please let me know and I can help
Tim
Sep 13, 2010 | IBM Office Equipment & Supplies
Sanyo PLC XU48 Need to know the lamp hours!
press and hold down the power button for about 20 seconds. The info will show in the top right of the screen.
Micketec
May 25, 2010 | Sanyo PLC XU48 Multimedia Projector
Installed new lamp/how to reset the lamp hour meter on samsung (HL-S4666W)
Here is the procedure for resetting the lamp timer.
This is a quick reference guide to show you how to reset your Samsung DLP TV’s lamp hour meter or hour counter. Resetting the counter is a very simple procedure.
Begin with the TV powered off.
Point your remote towards your TV.
Press:
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterwards!).
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Ballast UART Error
Same thing happened to me. After one minute of running, lamp shuts off and 5 power led blinks and 3 ready led blinks, indicate UART ballast error. Well, I purchased a new lamp, and installed it, and the problem was gone. I looked closely at my old lamp, and it showed a little blister inside, and a tiny spot of white residue, perhaps it was the whole problem there, although I don
Nov 20, 2008 | Televison & Video
Mitsubishi wd52525 shows error code 37
error code 37 is either the dmd fan or the lamp fan. you can see the dmd fan with the cover off. you cannot set the lamp fan as it is under the light engine. I guess the easiest thing to do is get a lamp fan 299P282010 and a dmd fan 299P283010 and change them both.
Nov 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52327 Lamp hour indicator.
Found this in another forum. So apologies if there are any innacuracies. service code
menu-5-7-5-7
Press the "AUDIO" button on a remote hand unit to select an adjustment function.
Press the ?VIDEO? button to select a specific adjustment Item.
After selecting an adjustment Item, use the ?ADJUST UP/DOWN? buttons to change data.
? Press ?ADJUST DOWN? to decrease the data value.
? Press ?ADJUST UP? to increase the data value.
Press ?ENTER? to save adjustment data in memory. The character display turns red for approximately one second in this step.
Press the ?MENU? button on the remote hand unit twice to terminate the adjustment mode.
options code
menu-5-7-7-0
Nov 07, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Sanyo PLC XP46L Multimedia Projector Logo
555 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
