Bosch HCBG500, 5 Pc Industrial Hammer Drill Bit Set
Problem for Bosch HCBG500, 5 Pc Industrial Hammer Drill Bit Set
Throwing oil
By bosnmate on Oct 15, 2007
I own a Bosch "Bull Dog" hammer drill, model #11228VSR. I loaned it to my neighbor a few years ago and noticed later that it now leaks oil out around the rubber gasket near shaft. I believe he over heated something. It still works, but when it warms up it leaks oil around the rubber gasket near the body and drill shaft.  Any help on a self fix would be appreciated. Thanks.
Same Problem
Jan 07, 2008
-   Ya man...my drill is doing the exact same thing....-   Guest
Best Solution
posted on Jun 07, 2008
Helpful)
hammer drill
Rank: Guru
Rating: 86%, 278 votes
i really dont worry about the leak near the shaft because with out the oil in the shaft there is a possibility that the shaft can jam. even dewalt new hammer when you purchase it come with the grease/lube like a toothpaste size. this is to lube the bits for the purpose the bit/shaft can move freely & also can hammer freely. our you can do is to dis-assemble the front end sleeve & remove the excess oil.will i agree weather can also change the viscosity of the oil. varsol cleaner can do the trick available at walmart.
Was this helpful?
Yes
No
Popular Solutions for Bosch HCBG500, 5 Pc Industrial
Questions and Unsolved Problems for Bosch HCBG500, 5 Pc Industrial
Do you recommend Bosch HCBG500, 5 Pc Industrial Hammer Drill Bit Set?
Answer
Answer
my wicks cordless hammer drill always in hammer mode. i can turn the dial to normal drilling mode... (More)
Answer
quando estou usando a furadeira c a ponta da broca p baixo ela faz um barulho estranho como se... (More)
Answer
My bosch hammer drill will not hammer? How can I repair the problem?
Answer
Can you tell where I can Buy one of the New Bosch 4-32 DFR Rotary Hammer Drills in Sydney, Australia... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bosch HCBG500, 5 Pc Industrial...:
Top Drill Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Drill Experts
Top Garden & Power Tool Repair
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
