Question about EliteGroup PT800CE-A Motherboard
Where is the audio output to front napel?
I want to connect the front headphone and MIC to mother board. But, where is the location pin on the mother board to support it?
Thanks
Viet
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 89 Answers
It's right under the rear audio connectors. Audio1: Front panel audio header 10 pin. Two jumpers on it, one on 5 and 6, and the other on 9 and 10.
Pin assignments are as follows:
1- fr pnl mic input signal
2- gnd analog audio
3- mic pwr
4- filtered +5v analog audio
5- rt ch audio to fr pnl
6- rt ch audio return from fr pnl
7- reserved
8- no pin
9- left ch audio to fr pnl
10- left ch audio return from fr pnl
Posted on Dec 29, 2007
  • 196 Answers
The ECS page is here;
http://www.ecs.com.tw/
Enter your model number in the search box and you'll be able to download the manual, which has the info you want.
Posted on Oct 15, 2007
I have an Asus P5QL PRO Motherboard and I'm trying to connect the FP audio and I need some help on how to connect it up properly. On the heaphones lead I have 4 connectors: EAR R EAR L RETURN...
Hi
Pin arrangement for Front panel Audio is usually:
Pin 1 Left MIC-IN Pin 1 right GROUND
Pin 2 Left MIC VVC (or MIC Power, or MIC BIAS) Pin 2 Right empty
Pin 3 Left R EAR (or R OUT) Pin 3 Right R RETURN
Pin 4 Ground or Empty Pin 4 Right empty
Pin 5 Left L EAR (or L OUT) Pin 5 Right L RETURN
This arrangement should apply to both the HD AA/FP or the Standard AC'97 Headers.
I hope this helps
Aug 28, 2011 | ASUS P5QL PRO Motherboard
Hi! i am using Intel DG33FB motherboard, i need the information about the connectivity of front pannel audio. for this it is Realtek HD audio port. i am having 5 cables set for the front pannel...
The L&R-Ret2&3 are common so only one needs fitting so for the speakers you only need to connect 3 cables. R-Out, L-Out and one return (either L of R). I'll comment back shortly on the mic pins for you.
Dec 23, 2010 | Computers & Internet
The front 3mm port is disconnected and I don't know where to hook it back up. I can't tell from the manual.
The front 3mm ports are for mic input / headphones output. The pin connectors are as follows. You need to use the JAudio header, which are in the lower-right corner of the motherboard closest to the front of the case when it's installed.
This header has 14 pins, and allows user to connect the front audio out put cable with the PC front panel. It will disable the output on back panel audio connectors.
Within this header, pin 1 is in the lower left corner, and pin 14 is in the upper right corner, like this:
2 ... ... ... 14
1 ... .. ... 13
The pinouts are:
1 Mic in/center
2 Ground
3 Mic power/Bass
4 Audio power
5 Right line out/Speaker out Right
6 Right line out/Speaker out Right
7 Reserved
8 Key
9 Left line out/Speaker out Left
10 Left line out/Speaker out Left
11 Right line in/Rear speaker Right
12 Right line in/Rear speaker Right
13 Left line in/Rear speaker Left
14 Left line in/Rear speaker Left
Aug 27, 2009 | Biostar P4M800-M7A Motherboard
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
My front panel headphone& mic connecting pcb have only 7 slots and the cable is named as 1)LINE OUT FR,2)LINE OUT RR,3)LINE OUT FL,4)LINE OUT RL,5)MIC IN(R),6)GROUND,7)MIC POWER(L) how can it connect...
FR stands for Front Right, FL for Front Left, RR for Rear Right and RL for rear left. These are speakers connections. You need a convertr cable to connect your headphones with your PC. After getting cable, connect it with FR and FL or RR and RL pair. Your headphone will be working. Similarly get the cabl for Mono to Stereo Mic and you can connect your mic too. (ehteshamhusain@gmail.com)
Jul 14, 2009 | Computers & Internet
Front panel Mic not working when connected to Mother Board
Yeah,sounds like the case wasn't designed for that board. Just carefully double check the pins in the manual for the board. If you don't have the manual,check the asus site.
Jul 10, 2009 | ASUS Computers & Internet
I bought inspire m4500 but only 2 speakers are working....
put the black pin of ur headphone in mic jack of laptop(mostly red color) and green pin of ur headphone in output audio (mostly green).
hope this helps u.. cheers Rajeish
Jul 05, 2009 | Creative Labs Sound Blaster Live! 5.1...
Where does the spk/mic wire go ?
You can download the manual for your board from Intel here. It will show you the location and pinout of the front panel audio header.
May 17, 2009 | Intel Computers & Internet
Need proper wiring for the J9C2 connector pinout
The User Manual for this m/board (E210882) can be found at :- ftp://download.intel.com/support/motherboards/desktop/d865glc/BFLC_English.pdf
you will need adobe free reader to view it. refer to pages 40 thru 46 for the front panel header and isb info.
Apr 01, 2009 | Dell Dimension 4600 PC Desktop
My sony dav-s-400 system keeps activating headphone port output.
Just had and fixed the same problem that hundreds of people are suffering with this system!!
Sony DAV s400 - same problem, won't play though speakers and display indicates that headphones are plugged in - when they are not. Fairly easy to fix and took me less than an hour from start to finish:
1) Remove top cover
2) Remove circuit board that has Audio In/Out phono scockets (to get access to Amplifier Circuit Board)
3) Remove Amplifier circuit board (has the speakers attached)
4) Turn it over and remove copper heat shield
5) Resolder joints where the big brown capacitor is and where the wires go to the front headphone socket...and any other dodgy joints that you find
6) Reassemble.
Feb 03, 2009 | Sony DAV-S400 System
EliteGroup PT800CE-A Motherboard Logo
249 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
