Question about Kenmore 24032\24036 Top Load Washer
I have Kenmore Elite washer (110.24942301) with bad timer, but I can't get to the timer to change it. No screws visible and no plastic caps on sides. There are plastic hinges screwed on behind the top console. Any idea how to get to timer??
  • dbreaux May 14, 2009
    Thank you plnote. Your solution was just what I needed. We're ordering the part now and will be up and running very soon! Thanks!
  • 62 Answers
Here is a link to a diagram of your control head on your washer. Make the diagram full size and zoom in, (the options to do that will be in blue on the border at the top of the diagram). Use a flat blade screw driver to push from the front on the clip, (#8 in the diagram), and the head should release and lift up. Good luck and don't forget to write back if you need further assistance and/or If I have helped you fix it! Good Luck! Click on the link below.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=11024942301&productCategoryId=0153200&brandId=0582&modelName=RESIDENTIAL-WASHER&diagramPageId=00002&componentDescription=CONTROL
Posted on May 13, 2009
Is it difficult to replace the timer on a kenmore 22942 (Elite top loader)?
you should be able to remove your control panel end caps them remove the 2 screws holdind it on and then pull towards you just a little and flip the panel back it has plastic hinges on top so be careful not to break them , you can get right to the timer ,don.t forget to unplug unit!
Feb 15, 2010 | Kenmore 22942 Top Load Washer
Side vent
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 09, 2009 | Kenmore Elite Oasis ST 7806 Dryer
I have a kenmore elite model 11026942500 top load washing machine. It won't start once it fills with water, and I don't hear the "click" when I shut the lid, (which usually starts the wash cycle).
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 28, 2009 | Kenmore Washing Machines
Washer stuck in cycles
May 09, 2009 | Kenmore Elite 21082
Kenmore elite top loader keeps getting stuck in all cycles....
May 09, 2009 | Kenmore Washing Machines
Timer knob spins when pushed in. unable to set wash cycles
May 03, 2009 | Washing Machines
How do I remove the control panel? on the kenmore elite calypso
Mar 30, 2009 | Kenmore 24082 Top Load Washer
Trying to remove the user interface cover for a kenmore washer
Feb 23, 2009 | Kenmore Washing Machines
Kenmore washer continully runs
Feb 09, 2009 | Kenmore Washing Machines
Kenmore Elite, Quiet Pak II Top Loading Washer
there should be 2 screw on the left and right side of the console. remove the screws and the console flips back so you can get to the timer. youll have to remove the knob and dial from timer too to get to the screws that hold the timer in place. if you dont have a local appliance parts store in your area then you can order the timer at sears.com and theyll ship it to your house
Nov 24, 2007 | Kenmore 15944 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
1,169 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
