Brown spotting on washed clothes
Once a load has been completed in my LG WD-8013F Front loader washing machine, small brown circular spotting appears on the washed clothes. It is brown/rust coloured. What is the problem?
  • 3 more comments
  • Anonymous Mar 17, 2014
    lg front loader washing machine...what does an error ic mead
  • Anonymous Mar 22, 2014
    While washing clothes the Le error came on
  • Anonymous Mar 24, 2014
    I have no manual and this is not my machine-I want to turn it on and wash some cloths--either just tell me or tell me where I can get a manual-I has fooled around on line and they want you to join -I did and still can't get the manual
  • Anonymous Mar 26, 2014
    brown spots on my white clothes, and some total brown white clothes
    the washing machines leaves a brown residual stain on clothes
  • 209 Answers
Chances are if you have eliminated anything thats got in by accident that the drum bearings are about to go, the drum bearings are protected by a water seal, this has started to leak and is now washing the grease out of the bearings back into the wash, you may also find a small amount of water on the floor, if you also remove the back and look behind the large pulley you may also see brown water marks running from the center of the outer drum
the next step will be a very noisy spin, like a rumbling noise
Posted on Oct 15, 2007
Large dark brown spots appearing after washing
Normally a washer does not cause a staining problem, but If something inside the washer has rusted, it could. I would check your water tank. Drain water from the drain cock at the bottom of the tank, and see how dirty it is. If it is dirty, you need to drain the water until it is almost clear.
Aug 13, 2015 | Frigidaire ATF6000ES Front Load Washer
Brown residue on clothes after washing
the seals are defective and rust is getting on to clothes inspect seal with silicon
Mar 19, 2012 | Frigidaire Washing Machines
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
Brown spots on clothes from my maytag neptune
this sounds very much like that the bearings have badly worn-out,pain to replace them ?
Jul 13, 2009 | Washing Machines
Brown spots indicates a bearing is breaking up, the spots are the grease from the bearing and as the seal breaks down due to the bearings going off centre, the grease gets in the drum.
Get the bearings replaced if affordable.
Jul 02, 2009 | Frigidaire ATF6000ES Front Load Washer
Iam getting brown spots on white shorts after washing with Kenmore front loading washing machine
If it's gunk or build up the marks should wash away. In this case run a long cycle using "affresh" or "washer fresh" with an empty load and use the hottest water available to help rinse the gunk out.
If the marks do not wash away, it could be grease due to a bearing failure. Listen for loud growling or grinding either by spinning the drum by hand or putting it into a spin cycle. If this is the case, the rear tub assembly (contains bearing) will need to be replaced. Not much can be done about the ruined clothes :(
Jan 18, 2009 | Kenmore 44102 Front Load Washer
Front loader washing machine = black streaks on clothing
I am a recently retired engineer of 20 years once you have ruled out anything getting inside the machine by accident etc, like something in pockets or greasy overalls, then its likely to be the drum bearings, has the machine started to get noisy on the spin the drum bearings are covered by a rubber seal, this seal gets damaged or worn and water leaks into the bearings themselves washing out the grease back into the drum where the washing is, you could also notice slight water marks on the floor underneath the machine on the floor, take the back off and look for water marks coming from the drum outer casing behind the pulley, these marks will be brown and will originate from a small drain hole, if any of the above change the bearings before any real damage is done, either to the clothes or the machine, as repair can be expensive? sorry, hope i have helped you as to where to look at least,
Sep 18, 2007 | Kenmore 46462 Front Load Washer
Washing Machines Logo
739 people viewed this question
Top Washing Machines Experts
