Question about Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point
I lost my encryption key password - Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point
    Problem Solver:
  • 11 Answers
As far as I know there is no way to retrieve a lost encryption key password. All I am aware that you can do is to re-set the router to factory defaults and pretty much start from scratch. I am sure not what you wanted to hear.
Posted on May 13, 2009
How do I open Folder Lock v6 without a password? I forgot the password a few years ago and haven't been able to open it. I am much heartbroken that I haven't been able to reclaim/recover my encrypted
Maybe Spy Hunter will get rid of it for you. OR a password recovery tool.It sounds like malware is there somehow. Google
JRT and download it, free, could something wrong in your registry also.
Dec 13, 2014 | Internet Computers & Internet
Tip
PDF encryption, set PDF password and recover PDF password
PDF encryptionGenerally, PDF files are with a password called User Password, which is used to open the file and view the document. To encrypt a PDF password does not simply mean you can’t open and view the document, but PDF files have five to seven encryption ways to protect the file for office needs. Owner password, the other password of PDF files, is another crucial PDF password, which is to protect the file from maybe being copied (to Clipboard), printed, or modified, etc. So, in speaking of PDF password, it doesn’t necessary mean the one which you use to open the file.
PDF encryption largely relies on the sophisticated algorithm that hardly to be reversed. For example, you are easy to calculate that 1000 plus 1 is 1001, however, the reverse is seemed impossible, for 1001 can be an answer of countless calculations. PDF encryption works in the similar way. In this sense, given a password, it’s easy to deduce and decipher some data; however, the reverse PDF password recovery seems impossible.
Generally speaking PDF encryption with 128 bits key value is much more secure than that of 32 bits. PDF encryption is accomplished by a key value, either 128 or 32 bits in size. When using the key, all the bytes are changed (unless they are decoded back with the same key) into meaningless codes, and the file is impossible to be opened. Only the meaningless codes are calculated back using the correct value is it possible to get the correct password and open the file. 128 bits has a lot more possible values than the one with 32 bits, so it is much more secure. If your password is forgotten and intend to recover PDF password, PDF Password Unlocker software could be faster, for it supports 128 bits encryption, either 128 bits RC4 or 128 bits AES encryption.
PDF files are composed with objects, like image Objects, graphic Objects, and text Objects, etc. The key is calculated for each PDF Object in the PDF file using local data, which is much hard to crack, as the key keeps changing.
Set and remove PDF passwordsAdd a PDF Password1. Click the Secure button pdf-encryption-and-pdf-password-recovery_clip_image002.jpg in the Tasks toolbar, and choose Password Encrypt.
2. Click “Yes” to the prompt about changing the security, and if necessary, type the Permissions password that lets you change security settings. If you don’t know the password, contact the author of the PDF.
3. In the Password Security - Settings dialog box, set the security options as desired, confirm the password, click OK, and then click OK again.
4. Save the document to apply the security settings.
Note: You can also restrict editing capabilities when you certify a document, or when you apply a policy to a PDF.
Remove PDF passwords and security settingsYou can remove PDF passwords and security policies from an open PDF if you have the permissions to do so. If the PDF is secured with a security policy that resides on a server, the changes can be made only by the author of the policy or by a server administrator.
1. Do one of the following: Click the Secure button pdf-encryption-and-pdf-password-recovery_clip_image002_0000.jpg in the Tasks toolbar, and choose Remove Security.
Type your password, and click Yes to the prompt about removing the security.
In the Security tab of the Document Properties dialog box, choose No Security from the Security Method menu.
2. When prompted, specify the Permissions password, and then click OK. Recover PDF password in case you forgot it.Every coin has two sides. Even the PDF document is strongly encrypted with passwords, it is impossible to insure that it is secure. Once you forgot PDF password, the data in the encrypted PDF file are on the risk of unavailability. Unless fortunately the password knocks your memory again, you got the data lost or you have to give up the document eventually. With the ever-growing of strong encryption algorithms, decryption algorithms gradually come into existing, too. Though the cracking is far more difficulty than ever before, it is still of help to those expecting to recover PDF password and access the password protected PDF file. Take PDF Password Unlocker, a popular PDF password recovery software, for example, it has adopted the advanced decryption algorithms to crack 40-bit RC4, 128-bit RC4, 128-bit AES, and 256-bit AES encrypted passwords with 3 attack methods, Dictionary attack, Brute-force attack, and Brute-force with Mask attack
Reference: http://www.passwordunlocker.com/knowledge/pdf-encryption-and-pdf-password-recovery.html
on Apr 30, 2010 | Computers & Internet
Removing encryption key
To open a locked memory card, select Options > Unlock memory card. Enter the password.
If you cannot recall the password to unlock a locked
memory card, you may reformat the card, in which case
the card is unlocked and password removed.
Formatting a memory card destroys all data stored on
the card.
Encryption
Select Menu > Tools > Encryption.
Encrypt your device or memory card to prevent
outsiders from accessing your important information.
Encrypt device memory or memory card
To encrypt the device memory,
select phone memory.
To encrypt the memory card, select memory card from the following:
Encrypt without saving key
• memory card without saving the encryption key. If
you select this option, you cannot use the memory
card in other devices, and if you restore factory
settings, you cannot decrypt the memory card.
Encrypt and save key
• and save the key manually in the default folder. For
security, store the key to a safe place outside the
device. For example, you can send the key to your
computer. Enter a pass phrase for the key and a
name for the key file. The pass phrase should be long
and complex.
Encrypt with restored key - Encrypt the memory
• card with a key you have received. Select the key file,
and enter the pass phrase
Oct 19, 2013 | Nokia E63 Cell Phone
"This memory card is encrypted but the phone encryption is off"how would that happen ?
I'm using E71 device, yesterday i heard about new firmware available for my phone. I had backed up my phone with Memory card encrypted with stored key file. After update new firmware successfully i go check memonry card enter password correctly open encyption function to store but my phone keep saying: invalid key file
Now i lost more important data in it with whole my private things, credit card, identify, taxing billing, pictures and company most important file
Mar 19, 2012 | Nokia E71 Smartphone
Help finding out my lost Network Key for an SMC Network router
go to dos prompt in a windows pc and type in ipconfig and press the enter key to find the default gateway address
it might be 10.0.0.1 or 192.168.0.1 these are the most common. Type the ip address into internet browser to log into the gateway router. There will be an admin user name and admin password. It might be the default or it might be written hopefully on the router case/
try
Username: cusadmin Password: password IP Address: 192.168.0.1 http://www.cleancss.com/router-default/SMC/SMC8014WG
if you get into it look up wi fi security to find out the wep key or wpa key
Apr 06, 2017 | D-Link Computers & Internet
Need to hard reset westell 7500 modem to factory defaults..cust chngd admin password and can't remember what they chngd it to and i need to get into modem
  • Note: Resetting your router to the factory defaults not only changes your router user name and password to the factory default values, but it also deletes all your home network settings. This includes the SSID and network encryption key. After you reset your router to the factory defaults, your home network won't be accessible until you reconfigure your router and all your network devices to use the same SSID and encryption key.
To reset your VersaLink 7500 gateway to the factory settings:
  1. Hold the reset button on the back panel of the VersaLink 7500 gateway for 30 seconds.
    • All your settings will be lost including network encryption information and any SSID information you have entered.
    • The gateway user name and password will revert to the default of Admin as the user name and Password as the password.
  2. Your VersaLink 7500 gateway is now using the default settings for the network configuration. This includes the default SSID and network encryption key. You must re-configure your VersaLink gateway to match your previous settings that were assigned to all other devices on your wireless network. Otherwise, no other network devices will be recognized.
Nov 05, 2011 | Westell Wirespeed VersaLink...
We are using your wireless internet but forgot the security password
The security password is the wireless router's encryption key.
When youclick Refresh network list, then Choose yourwireless network and then click Connect to your secured WirelessNetwork, it will asks for a Network Key before allowing you to connectinto your wireless network. This Network Key is either the WEP, orWPA or WPA2 Encryption key that is used to configure the Wireless Router. The Passphraseis an alternate way to set the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router. http://www.fixya.com/support/r5270415-network_password_network_address For information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Apr 14, 2011 | Motorola Computers & Internet
Why does my netbook password not work? It says encrypted and can't long in to my netbook.
What operating system are you using? You might have to reinstall your operating system since you might have a virus
Mar 03, 2011 | Acer Aspire One Netbook 8.9" Notebook
How do we find the WEP key for my WGR614v9
Configuring WEP:
  1. Use an ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  3. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
  4. Select Wireless Settings from the Setup menu in the left-hand navigation bar. n101675_image001.jpg
  5. Under Security Options, select WEP (Wired Equivalent Privacy).
  6. From Security Encryption (WEP) > Authentication Type, select Automatic.
  7. From Security Encryption (WEP) > Encryption Strength, select 64-bit or 128-bit. NOTE: You will need to configure your wireless computers with the same setting.
  8. From Security Encryption (WEP) Key, select Key 1 and enter a key.
    • Note: WEP keys are entered in hexadecimal digits, which are any combination of 0-9, A-F.
      • If you selected 64-bit under Security Encryption (WEP) > Encryption Strength, then enter 10 hexadecimal digits for your key.
      • If you selected 128-bit under Security Encryption (WEP) > Encryption Strength, then enter 26 hexadecimal digits for your key.
    • SAVE or KEEP NOTE of these values - they will be required to connect wirelessly to your network.
  9. Click Apply to save the settings.
Feb 21, 2011 | NetGear WGR614 Wireless Router
Lost encryption key for wireless connection
Yes there is a way you can find out the encryption key or passphease. You can also change it according to your preference.
first connect the router with an ethernet cable to the NB
Go to command prompt and type IPCONFIG
get the default gateway number
type the DG number in the internet explorer address bar
it will prompt for a username and password
Default username : admin
Default password : admin
not once u you are at the router configuration page go to wireless tab and click on wireless security
type the 10 digit phone number in the key 1 boz and make sure it is selected as yr passphrase
not reinstall yr wireless card drivers and connect again
it should work
for further help refer to this link :-
faculty.valenciacc.edu/wyousif/WLAN/Presentations/Configuring%20Linksys%20Wireless%20Router.ppt
Hope this helps..
Regards,
Anup
Apr 06, 2009 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point Logo
136 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
