Question about Mitsubishi WS-55711 55" Rear Projection Television
WS55711 mitsubishi RPS - Dec 2002
Problem is there is color and projection of image is not correct. Top of screen has a curved appearance and all images on the screen appear to have a pink and green "double image" appearance. Horizontal objects on the top and bottom of the screen appear to be curved. This problem occurred suddenly... just appeared when the TV was turned on after normal operation. No sound issues or on off issues. Any ideas?
  • Anonymous Jan 04, 2008
    I have the same television and have experienced the same problem after only 4 years. What can one expect to pay to replace the convergance amplifier? The labor rates are reasonably consistent among different repair companies; however, I'm not sure what the part should cost.
I have a problem where there is color and projection of image is not correct.
The main screen appears OK but the RED screen projection has a curved appearance and all images on the screen appear to have a pink and green "double image" appearance. This problem occurred suddenly... just appeared when the TV was turned on after normal operation. No sound issues or on off issues. I have re-set the TV but no cure. Any ideas?
Posted on Nov 29, 2008
  • 1,139 Answers
This sounds like your convergence correction amplifiers have malfunctioned. These Integrated Circuits often burn out after a few years (STK392-110) they can be replaced with a higher version (STK392-150) However it is important to have the biasing circuitry checked to make sure nothing has burnt out as a result of the ICs malfunctioning. If you have a background in electronics you can repair this problem with very little effort, however if you do not have a background in electronics, I would suggest that you have your TV serviced by a qualified TV technician.
I hope this helps,
Thank you,
Posted on Oct 15, 2007
I have a Mitsubishi WD-62525. In general the picture is great from all sources (cable, component, and hdmi). However, there occasionally are very thin, horizontal lines that flicker across the screen....
I have seen this problem before. It is usually caused by a malfunctioning color wheel. Replacing it should resolve the problem. Let me know if you wish to fix it yourself so that I can find you a replacement.
Jan 16, 2011 | Mitsubishi WD-62525 62" Rear Projection...
The screen has a double image and also has a
u have bad convergence , this is a problem from the deflection board , the repair of this repair is about $250
Apr 23, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
The picture projects the image with concave lines on the edges. I'll explain further: somehow the picture is distorted in a way that bends the four edges of the picture in a curved-concave manner so that...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya
Nov 26, 2009 | Mitsubishi VS-55705 55" Rear Projection...
Mitsubishi vs-70601 picture pincushioned and out of convergence
could just be a convergence issue. there should be an auto-convergence feature in the menu. outside of that, you'll have to manually converge the colors seperately (also a feature in the menu).
Jul 29, 2009 | Mitsubishi VS-70601 70" Rear Projection...
Curved/warped and completely out of convergence Image
Sounds like you need the convergence amplifiers replaced. Cost approx. $300.00 for expert to repair.
Jun 20, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Blue, green, red parallel curved lines at top of screen
hello sorry but it sounds like the chip have gone again when you replace these chips you might have to change the resistors and the 2 capacitors as well
May 08, 2009 | Mitsubishi WS-55905 55" Rear Projection...
Curved in at top and bottom and rainbow colors on bottom
Apr 12, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi VS-4561 picture curved inward
Its Your Convergence Chips!. And Maybe a few Resisters!. Common Problem with this kind Of Set!.....
Jun 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Screen is distorted on the top and bottom
Loose connection on convergence board, you could tapp and should go back to normal, find loose conn. and solder back.
Sep 09, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-55711 55" Rear Projection Television Logo
319 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
