Question about Frigidaire 24 in. GSB5712B Gallery Supreme Built-in Dishwasher
Fridgidaire Gallery Series Dishwasher Leaks from bottom
I have a Frigidaire Gallery Series Dishwasher that leaks at the bottome right corner and puddles up on my hardwood floor. Frigidaire gallery dishwasher leaked at the door the FRIST time I ran it. Did the first run with nothing in it to test and clean it out. About 1 lt of water came out the bottom right corner. Sadly it's over 1 year old before we ran it. Doh! We bought it knowing it would be a while connecting it, but all the SST appliances would match in our new Kitchen. Now there is no warranty which doesn't seem to be a loss as the repair reports are anything but satisfactory.
Took the SST front panel off to watch while it was running. Saw the seal at the bottom of the door was ineffective. Every few rounds of the arms inside a small gush of water shoots under the seal, hits a small 45 degree lip that forms the front lower edge of the tub (1/2 inch high) and jumps over the edge. This then leaks down the inside of the door and drips onto the floor. Could happen on either side of middle.
I put a run of tape along the lip where the water goes up and out. This directs the water back into the tub area so there is no direct path out for it. Almost 100% effective.
The seal looks like an integral part of the door liner. So Frigidaire isn't likely to want to replace this with a better seal. Alternatively the tub seems to be the real culprit. Too expensive to replace and a 10o% possible ineffective repair if it's not 100% flat and to spec.
 I think it's simply a seal design that is dependent on a precise match of the tub/door and absolute flatness of the PLASTIC TUB. I'm not a rocket scientist but I don't think the flatness and STIFFNESS required for this seal design is possible on a plastic tub that is soft enough to withstand the heating/cooling and detergent of the dishwasher. If this was the intended design, the engineer is incompetent. SST tub... MAYBE a good fit would be possible.
A better design would have some sort of mechanical "trap" or "dam" formed into the tub to prevent the water force from directly hitting the seal. The seal should be a back-up line of defense.
The tape is a temporary test for me to see if it's fixed. My plan was to adhere a piece of plastic to the bottom of the tub (under the seal) about 1/16" thick so the BOTTOM DOOR SEAL contacts the tub bottom more tightly. This was likely the intended design. First though, I might do the "dam". Adhere a 1/4' X 1/4" plastic strip inside the tub, just in front of the seal. This should  stop the direct water force from pushing against the seal. Alternatively, another 1/4" strip in the outside of the seal would make the seal fit into a groove. This might be a fine solution and be a 100% mechanical means to stop the water from flowing out. This would leave the fragile seal from getting over-squished and failing (see : seal is part of the door liner).
It saddens me that so many of these can get out of the factory (or out of the test lab) without a competent engineer catching this. It's like it's the first dishwasher they ever made.
Good luck.
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Leaking dishwasher
Sorry about the delay in time in getting back to your problem if not already resolved heres what you can try. Remove the bottom panel and run through a load, to see exactly where leak is coming from, most common place for leak is through the heater hold down brass nuts. They crack and need to be replaced
Posted on Mar 16, 2008
wheelshot
  • 102 Answers
SOURCE: My frigidaire dishwasher leaks from the bottom
One possible solution to your problem could be as follows... Could have been little regular soap or something put in that made it suds up causing it to leak out of the front and sometimes not to drain all water out. Pouring vegetable oil into the dish washer tub will remove the suds. After running vegetable oil for about 5 minutes, pour 2 cups of vinegar in to the tub and run it on the hottest longest cycle with no dishes in it. This will clean the residue out and what ever "gunk" may be in the internal parts. Use Only powder detergent. No gel and No tabs. These 2 cause a build-up over a period of time of use and reduce the performance of your machine. This should take care of your problem. Also could have a bad door seal. Check for any tares in the gasket.
Posted on Apr 11, 2009
heatman101
  • 43501 Answers
SOURCE: Fridgidaire Gallery Series Dishwasher Leaks from bottom
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
wre
Posted on Sep 29, 2010
Frigidaire gallery fghd2455lf leaks from bottom of door
Thank you for your post, Jacques Lanthier!
From what you have described it sounds like you could have a loose or bad gasket on your Frigidaire dishwasher. Typically, to clean any seals you would remove them and wipe them off with a rag and warm water. If you continue to experience an issue with water leaking I would recommend replacing the gaskets. I hope this information has been helpful. -Matt
Jan 10, 2015 | Frigidaire Gallery FGHD2455LF Full Console...
Frigidaire dishwasher leaks from motor
This is caused by the cheap bearing's in the motor. Even after I have replaced my $200.00 motor assembly it still leaks. put a small flat dish under it as the leak should be small and when the dishwasher starts making a loud noise the bearings are gone and I do not recommend replacing motor as it is half the price of washer itself. I myself will never buy a fridgidaire again. However if you do replace the motor assembly it is very easy and there is a video on youtube showing you how. good luck
Mar 25, 2014 | Frigidaire FDB700BFC Built-in Dishwasher
run it with no soap. if you get no leaks then cut back on your soap. you may need to run washer a few cycles to get rid of excess soap.
Sep 02, 2012 | Frigidaire Dishwashers
After the cycle starts, water leaks out of the bottom of the machine and into the basement
I would call for service. many probabilities and none are good. it is fixable but for a diy'er it could get to be a bit much.
Apr 29, 2012 | Frigidaire Professional Series 24 in....
I have a fridgidaire refrige and water keeps pooling in the bottom of the refrige and then leaking out the bottom when it fills.....what is the problem?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water leaking on the floor at the door.
frigidaire models usually leak water at the top of the door and water enters in the door through door latch.2 fix this u can insert a double sided sticking tape behind the tub seal at the top so that door top sits tight against the top part of seal.
also u can remove the front door panel 2 c if water ia jumping out of tub at the bottom at lhs and rhs corners.if thats the case pull out the door seal and insert it back stretching it little bit and leaving some of it extended at both bottom corners so that it can stop the water from splashing out.
Aug 15, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Frigidaire gallery pro series model frs26zsh water leaks out somewhere goes into backside of freezer eventually goes down to underside of bottom basket and freezes
Mor than likely you have a clogged defrost drain. Drain is located at the bottom of freezer compartment behind the back panel. You will have to remove the panel and blow out (or vacuum) the drain hole. Hope this helps
Jul 31, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Cannot clear PF light flashing on frigidaire dishwasher
Frigidaire dishwasher will not work at all it has PF blinking
May 27, 2009 | Frigidaire 30 in. Electric Gallery Series...
Leaking Dishwasher
heatman101
wre
Mar 01, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire 24 in. GSB5712B Gallery Supreme Built-in Dishwasher Logo
779 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
