Question about Palm Treo 600 Handheld
Palm treo 600
I am having a problem with my charging port. When I plog my power cord in the phone isn't responding . I don'y know if the port is bad. I tried a card charger and it still wouldn't work. I need help .
I have the same problem.  I thought that I might just have a bad charger so I went out and purchased a new one, but it still didn't work.  I noticed that one of the pins inside of the phone had bent against the side of the case. I'm still not sure about what to do.  This might be your problem too.
Posted on Oct 19, 2007
My palm treo 600 won't hold a charge
Replacing the battery should work. I had the same problem and ordered one from (the actual lynk is and the product code you want is PA1547 (you can filter your search by Palm Treo - left side of the page).
You will also need a Torx Set (5 & 6). The replacement instructions can be observed in
Hope it helps
Mario Martins
Sep 06, 2008 | Palm Treo 600 Handheld
Palm treo HELP!!
I have the programming to get in but it'll be easier to explain over phone with the instructions... just let me know...
Jul 24, 2008 | Palm Treo 600 Handheld
Palm treo 700 wx won't charge
Verizon 700wx:I had the same problem. With little or no movement, the phone would go from charging to not over and over. At home with it perfectly still it would charge maybe 1/4 in 6 hours. Same problem with 3 different chargers. With the battery out, I dipped a Q-tip in rubbing alcohol squeeze out excess and jammed it into the charging port on the phone. Put the battery back in and oh **** nothing. Took it back out and let it dry for a few minutes and were back in business. No more charging problems at all.
May be a little risky, but warranty was up and what did I have to lose. Anyway good luck!
Feb 16, 2008 | Palm Treo 650 Handheld
Treo 650 cell phone
buy new battery nimh in ther sit so long loses full charge cant get back .
Feb 05, 2008 | Palm Treo 650 Handheld
Palm treo 650 wont power up
It may be past the point of turning on.
If this is the case, if you connect it through the USB cable to your computer for a little while, it can get a small charge.
Trickle charging
Some Palm devices have the ability to "trickle charge" from a USB port on a PC or Mac. This means that it receives a very small amount of charging from the USB port, even if it is not connected to its AC charger. If your device is capable of this function, the charging time will be significantly longer for a trickle charge (depending on the power rating of the PC USB port). However, the device may not charge at all on an unpowered USB hub (or for example off off a keyboard).
If you can then power it on afterwards, connect it to the regular power charger.
Jan 06, 2008 | Palm Treo 650 Handheld
Problem Getting My Palm 600 To Recharge
Try plugging the Treo in to recharge and then at the same time poke the reset hole in the back of it. This should reset the charging mechanism in the Palm. Let it sit for a hour or so and then try powering it back on.
Jan 02, 2008 | Palm Treo 600 Handheld
Switching from AT&T to Rogers Wireless net work
Turn Wireless off (you do not have to remove sim card ); Hostsync palm treo 600 to your pc; add all files of folder T6GSMUP305 by install from palm desktop.
palm treo 600 will automatically update & unlock.
Read readme file
Nov 18, 2007 | Palm Treo 600 Handheld
Palm treo 650
Hi Sandra Bunch,
Could you inform us which treo do you use? If you use Treo 650 or newer, than you could buy desktop charger beside ordinary palm charger. But if you use Treo 600 there's no alternative than buy the ordinary palm charger. It's easy to get this accessories on the net, you could try or
Nov 10, 2007 | Palm Treo 650 Handheld
Palm Treo 600 Handheld Logo
70 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
