Example = 1,2,3,4,5,6,7,8,9,10,11 Combination = 1,2,3,4,5,6,7 Combination = 2,3,4,5,6,7,8 Combination = 3,4,5,6,7,8,9 etc. How can I get a list of all combinations?
Does every number have to be taken only once?
If order is important you have 11P7=1663200 permutations (different from combinations)
If order is not important for example 1,2,3,4,5,6,7---- 2,1,3,4,5,6,7----2,3,1,4,5,6,7----2,3,4,1,5,6,7 etc are all one and the same then you have
11C7 =330 combinations.
You get them by mere obstinacy: take a pad and start. It is only 330.
Testimonial: "Thanks. Can you do it on an excel spreadsheet, and if so, what is the formula?"
SOURCE: on the screen appears <<>> instead of numbers that i type
try resetting it... Will probably rid you of your problem.
2nd>Mem(+ sign)>reset> right 2c(ALL at top should be highlighted)>yes
You will need to reload all your programs, and while your at it you should probably update the OS from the TI site...
Good Luck
-Saik0Shinigami
SOURCE: Casio 9850
Definitely not by asking in a forum. You could get a walkthrough, but that's not solving the problem.
This one is down to reading the calculator manual and your textbook a bit, then satisfying yourself that your answer and the definitions for those types of average are in accord. Mode is clearly an oddball which would make more sense with more context, but for now just pick the most common number, which is a set: (7, 10, 11).
That sounded better than 'toss-up between 7, 10 and 11,' did it not?
SOURCE: On a TI-84 or 83, after a memory clear,
try this: [2nd] [+] [3] [ENTER], that clears ALL entries and should "stirr up" the randomness
