Question about AudioBahn A1801T Car Audio Amplifier
Blown fuses the fuses blow everytime i hook up the remote wire is it the wrong fuse or is there something wrong with the amp? i use 25, and 30 is it the right size fuse?
  • 631 Answers
If the fuses only blow after the remote voltage is applied, the output transistors are likely shorted.
According to the owner's manual, the amp should have two 20 amp fuses.
Manual
Posted on Oct 15, 2007
Everytime I cut it on. It cuts back off like there is something wrong with it
If you turn it on and it clicks right back off you may have a short. Make sure the wire panel does not have any straggler wires going from one connector to another. Also you may have a very weak fuse. Check the fuses in your amp and at the battery terminal. Make sure the power, ground and remote wires are solidly connected. Make sure that ground is tight. Is the deck shutting off at the same time your amplifier does? The remote wire off the deck powers that amp so if the deck is also cutting out the problem may be the deck and not the amp. If this is the case then run through the steps I listed above but with the deck as well.
Regards, Tony
Mar 24, 2011 | Sony XMGTX1852 Car Amp
3 amp fuse blows
Mark all your wires using tape or by writing it down to ensure you will be able to hook them back up exactly the way you found them. Remove all the wires from your board again. Tape off the ends so you don't "short" anything together. Identify the wires going to your outdoor unit and the wires going to your thermostat. Hook the wires up one at a time starting the with C wires and the R wires. Then hook up G. Then W. Then O. Then Y.....and any other wires you might have. Check the fuse everytime you hook up one of the wires. Remember to do the tstat and outdoor unit wires one-at-a-time also..........meaning........you will have 2 "Y" wires. Hook up only one, then check the fuse, then hook up the other, check the fuse...........Eventually, that fuse will blow again when you hook up the right wire. Then you will be able to determine the color wire and whether it is the one for the tstat or the outdoor unit. Once that is determined, disconnect that wire at the other end and re-install the fuse and restore power. If the fuse blows, the problem is in your wire. If it does not blow, it is most likely a bad control coil. More often than not, it's the wire. Look for damaged insulation and "crimps". Usually the repair can be made with simple electrical tape and/or cutting the bad spot out, using a wire nut and electrical tape, and testing it again. Let us know how you made out. If you run into another stumbling block, we'll dig deeper and walk you through it. :-)
Apr 10, 2010 | Heating & Cooling
Soon as i try to connect the power and ground starts sparking and my fuse blows by the battery. I changed the ground cause i thought that could be it plus i tryed installing it in another car that had an...
your inline fuse wouldn't blow if there was just something wrong with the amp. the amp fuse would blow if that was the case. something is faulty with your wiring. you probably have the wires touching somewhere or are in the wrong terminals at the amp or on the wrong battery terminal. or your power wire is grounding out somewhere. its not the amp. its your wiring
Mar 16, 2010 | Car Audio & Video
Amp blows fuses
Are you using the correct fuse? if so,
more then likely, you don't have a good ground. Try grounding to something else that has more direct connection to your frame. If that doesnt work, try getting larger power cables.
I had the same problem with my 2500w xplodes all I had to do was get a thicker cable for the ground and battery connection. What was happening, was it was needing more power then the wire and fuse could handle, so it would blow the fuse, since the higher you have it, the more power it needs to feed the watts.
I would try grounding it directly to the frame on a good part of the frame before spending another $70 on new power cables though.
Mar 09, 2010 | Car Audio & Video
Please help. weird problem
IF FUSE ARE BLWN OFF EVERYTIME YOU REPALCE THEM, THEN THE AUDIO TRANAIATORS ARE DAMAGED, OR POWER IRF TRANSISTORS ARE DAMAGED, REPLACE THEM WITH SAME TYPE OF NUMBER IF YOU CAN DO IT, OR TAKE IT TO QUALIFIED PERSONAL
Oct 13, 2009 | Nitro BMW-481 Car Audio Amplifier
Blowing of fuses
The reason your blowing fuses is the amp needs at the least a 150 amp fuse on the wire that runs to your bat. There are fuse blocks that you can put 4 40amp fuse and theres the high dollor ones that you can put all the way to 200amp. When you trun up your amp its drawing to much current for the little 40 amp fuse that you have and will blow it everytime. I recomend Running a 4 gage wire to bat and ground with same. Get you a 150 or above amp fuse from a car audio shop somewhere. anyway sounds like from what you decribed, theres nothing wrong with your amp just the wires and fuse are not big enouf to handle the current that your amp pulls.
Oct 21, 2008 | Lanzar OPTI 50c Car Audio Amplifier
Car amp blows 12 volt wire fuse
the wire from your battery is blowing fuses? and you are using 20-30 A fuses? mine has a 100A fuse..look into getting new wire plus my wire is 4 gauge.., 1600 watts is too powerful for a 12 g wire and a 30 A fuse
Jul 26, 2008 | Car Audio & Video
Hifonics amp keeps blowing the main fuse
have u tried using thicker wire from the battery to the amp u need to put a fuse in there thats a minumum 60
Jul 15, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Keep Blowing Fuses
Sounds like the amp is shorting somehow. You are obviously shorting out somewhere between the battery and the amp. Are you sure you grounding location is a good one? is the fuse blowing only when you turn the stereo on? Something is not hooked up correctly.
If the fuse at the battery is blowing then it's a short.
If the fuse on the amp is blowing then its probably a bad amp.
Jun 12, 2008 | Kenwood KAC-728S Car Audio Amplifier
Amps
If the amp blows a fuse with no remote voltage applied, the amp has a short in the primary side of the power supply. If the fuse only blows after remote voltage is applied, the amp probably has shorted output transistors.
May 02, 2008 | Boss Riot 1500D Car Audio Amplifier
AudioBahn A1801T Car Audio Amplifier Logo
145 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Jerry Naidoo
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
