Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
How do you change the fuel lines on a weed eater?
The cable for the attachment clutch lever broke and there is a large spring on the other end. where does it attach to?
  • 246 Answers
SOURCE: how do you relace the recoil spring in poulan weed eater lt1500le
Hello dan_montecar:
>>The Following is a General Instruction File I Made to Perform this Repair. If you have Any Suggestions or Remarks, then Please Let me Know. Thanks.
>>**Remove the Boom/Shaft from the Engine. Remove the Mounting Bolts and the Boom and Center Drive Shaft should Slide Away from the Starter Housing Assembly.
>>**On Some Model Trimmers, there is a Torx Screw Inside the Coupling Drive that has to be Removed.
>>****There is also a Locking Screw on the Side of the Housing that is a Anti-Vibration Lock.****
>>Using the Breakdown as a Guide Remove the Starter Housing Assembly from the Engine Assembly.
>>Now Carefully/Slowly Remove the Pressure Plate Assembly from the Starter Housing.
>>The Spring May have Broken and Sometimes a Section will Jump Out when the Pressure Plate Assembly is Removed from the Starter Housing. When it Jumps, it Pushes the Recoil Pulley Out Also.
>>Look at the Direction of the Coil of the Spring in the Housing and Make an Arrow in the Direction of the Coil with a Magic Marker on the Inside of the Housing.
>>Remove the Broken Spring and Clean the Housing with Spray Lubrication. You can Use Solvent if Required, Just be Sure to Wipe it Before Assembly with Spray Lubricant. The New Spring should come with a Retainer that Holds it in a Circle.
>>If you have Removed the Spring from the Retainer, then Use a Piece of Plastic Pipe About 2" Long that is the Same Inside Diameter as the Retainer (Slightly Smaller than the Recess that the Spring Coils Into if you Lost the Retainer).
>>Coil the Spring Into the Pipe and then Set the Spring Into the Recess. Make Sure the Spring Tab of the Spring Engages the Spring Lock in the Recess.
>>Use a Socket to Hold the Spring in Place and Pull the Pipe Out of the Recess.
>>Lock the Pulley in Place.
>>Now Turn the Pulley in the Same Direction that the Pulley would Turn if the Rope was Turning it.
>>Once the Pulley will Turn No More, then Reverse Direction 1 or 2 Turns and Thread the New Rope Through the Hole in the Center of the Pulley and Out the Hole in the Blower Housing.
>>Pull the Rope Through Until it is Tight Against the Pulley. Now Tie a Slip Knot in the Rope to Hold the Pulley in Place While the Handle is Attached to the Rope.
>>Once the Handle is Attached, Release the Slip Knot and the Rope Should Retract Into the Housing. Reassemble the Blower Housing Onto the Engine.
>>On Some Models you May have to Install the Rope Before you Lock the Pulley in Place. If So, there is a U in the Pulley that the Rope is Held in While Turning the Pulley to Tighten the Spring.
This is a Basic File and your Unit May be Slightly Different.
>>You can View a Breakdown/IPL of the Mower at this Site Addy, http://hayward.arinet.com/scripts/EmpartISAPI.dll?MF&app=ASP&lang=EN&TF=Mainframe&LoginID=hywd&loginpwd=hywd&Partner=HYWD and Select the Catalog Poulan/Weed Eater.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
  • 279 Answers
SOURCE: Reattaching fuel line to gas tank.
Get a new line the same size and length of the old one. Get the filter out of the tank. If it is as I think, it has a barbed end that goes into the outlet hole. Take your new line, fit it onto the filter end and make sure it is all the way on. Take the other end of the line and cut a taper on the end. Thread the end through the tank, into the outlet hole and aissist it so your filter sticks through the tank hole. There was a ring on the outside of the tank, on the line. Take that ring and run the ring over the end of the tube up to the filter bottom. Make sure it goes all the way up to the bottom, and tight.Square off the end and slip it onto the carb...Good luck...Lee
Posted on Aug 28, 2009
Testimonial: "Thank you for the solution, very helpful."
bulldogchief
  • 388 Answers
SOURCE: Can't get weed eater started. Have an older weed
This is a common problem on older Poulan models. Press the primer button 10 times and pull the starter rope twice, then pull the spark plug and examine it. If the plug is wet that means gas is definitely getting to the combustion chamber. Next thing is to use a compression tester. If you do not have a compression tester but have an AutoZone anywhere near you, you can get a loaner from them. Screw the compression tester into the plug hole and pull the start rope 4 times. If the tester reads anything below 90psi, you have a bad ring and will have to take the motor apart to clean the piston and ring or replace the ring.
Keep me posted on what you find, ok? I can walk you through the procedure to replace the ring if necessary. Good Luck!
Posted on Sep 17, 2009
Testimonial: "thanks...I will give it a try and keep you posted"
SOURCE: Weed Eater Lightweight 1500 Leaf Blower Fuel Line
If you push the bulb and note the port the gas squirts out... this is the short line. The other port should **** up when the bulb is released... this connects to the long line with weighted filter in tank.
Posted on Nov 08, 2009
  • 279 Answers
SOURCE: how to repair spring starter on FL1500LE
The casing is situated so the spring faces the starting spool. The spool is plastic and the rope is wound around it. The hook goes to the spool. Put it back together carefully! Good luck...Lee
Posted on Nov 24, 2009
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    How to change the fule line of weed eater?
    There should be clamps on either end of the fuel line..1.. empty the fuel out of the weed wacker ..2..loosen the clamps..3..remove the hose ..make sure you are careful when replacing any fuel lines..so you dont puncture a brand new one..tighten the clamps good but not too hard or you can pucturethe hose that way too and make sure its the right one for that model. make sure the line is also fuel resistant..gasoline can eat through the wrong type of line. You should be able to buy the fuel line and clamps at any hardware store:)remember to ask for help from someone in the right department
    Apr 14, 2014 | Garden
    Weed eater wont start
    If you haven't changed fuel filter in awhile, do that as well.
    look here...
    Aug 01, 2010 | Craftsman 25cc Gas Line Trimmer
    Ryobi weed eater head won't spin
    Sounds like the clutch has taken a long trip south. If the clutch pads are not wore out, try some wd40 on the pad hinges.
    Apr 27, 2010 | Ryobi Garden
    I have a poulan poll saw. The pull cord broke i have disassembled down to cluch assy. I can't get the clutch assy. off to get to the cord pulley can someone tell me how the clutch is attached is it just...
    there is a clutch removal tool, that you could buy. I dont know if there are any to rent. I just used a large screwdriver and hammer, and tapped it counterclockwise to remove it. It is threaded. I at first thought the springs were holding a dog, to the shaft. but looked harder and realized that it was threaded. I tried going clockwise like the guru said, but it was counterclockwise to remove. I hope this helps.
    Jul 09, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
    Can't find fuel filter on Poulan Pro weed eater. Acts as if it's fuel starved
    Where is the fuel filter?
    All gasoline engines have a fuel filter on the end of the fuel line in the fuel tank. Weed Eater recommends changing the fuel filter yearly. To remove the filter,
    1. drain the fuel from the unit,
    2. Pull the filter from the tank through the gas tank opening and remove it from the line,
    3. Install the new filter on the fuel line and drop back in tank.
    Jul 08, 2009 | Poulan Garden
    Lose gas line poulan weed eater
    The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
    The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines.
    (HINT): when feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
    Jim
    Jun 13, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
    My homelite weed eater sx-135 the fuel filter broke of the tube
    The longer, and sometimes smaller in diameter fuel line, goes from the carburetor to the bottom of the tank. This line, which has the filter attached to the end, should rest comfortably on the bottom of the tank.
    The other fuel line goes from the primer bulb to just inside the tank, (about an inch, with that very small piece of plastic attached to it. This piece of plastic keeps this line from pulling out of the gas tank. this line serves as an overflow from carb.
    Jim
    Jun 07, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
    Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
    361 people viewed this question
    Top Poulan Garden Experts
    Roland W VanLue
    Roland W VanLue
    Phil Walker
    Phil Walker
    Are you a Poulan Garden Expert? Answer questions, earn points and help others
