Question about Mitsubishi VS-50603 50" Rear Projection Television
Mitsubishi VS-50603 Wont Turn on
My VS-50603 has no sound or picture. When I plug it in I hear a click and the green LED turns on and is steady. No Picture and no Sound! Please Help!
  • ryan_lechner May 13, 2009
    How would I go about changing them myself? Is there a guide somewhere?
  • 11,896 Answers
The power supply will need to be changed. The capacitors inside the power supply are not sending the correct amount of power to tv and will need to be changed.
Posted on May 13, 2009
  • Nate Stansfield
    Nate Stansfield May 14, 2009
    You will have to purchase a repair manual. Many sites have them. You cannot repair it without the manual. But with the manual, you can do anything.
I turn on my TV and the picture is up in the right hand corner. How can I get a full screen?
Posted on Dec 31, 2012
Mitsubishi Projection TV Model #VS-50603 will not turn on.
The TV is going into a "protect mode", the micro-processor has sensed a circuitry problem and has shut the set down so that no furhter damage can happen, you will need to have the TV serviced by a Mitsubishi tech. Good luck !
Jan 07, 2010 | Mitsubishi VS-50607 50" Rear Projection...
My vs-6055 you can hear it click but it wont turn on
check q570 if shorted replace it,also regulator ic401 goes bad along with c402 100mf/50volt electrolytic cap
Sep 01, 2009 | Mitsubishi VS-6055 60" Rear Projection...
Mitsubishi VS-50609 won't turn on
What a great tv this is Mitsubishi did a fine job making this one, but......only an authorized mitsubishi servicer should repair it. This set records diagnostic led codes that the technician receives to help determine where the problem might be, not the problem, but in which circuit it might be. The one thing to try is, unplug the tv , let it set for a minute, plug it back in , turn it on and hope it reset the micro. Next , call for mits. service.
Jun 11, 2009 | Mitsubishi VS-50609 50" Rear Projection...
I have a Mitsubishi VS-50603 that will not turn on.
Good Day, jessayala;
It sounds like you may have Ethylene Glycol on the boards, leakage from the TV's CRT's. The Glycol is a fluid that help's the tube cool. If you are not handy, very, very handy, I would call an Authorized Service Center to come out and give you an estimate before the repair is performed.
Good Luck, big IRISH......PS..... If can handle your self ..... come back here.
Aug 28, 2008 | Mitsubishi VS-50603 50" Rear Projection...
Mitsubishi VS-5075
Your standby power supplies are most likely at fault you should check the low voltage regulators and see if they are functioning they may be defective.
Jun 16, 2008 | Mitsubishi VS-5075 50" Rear Projection...
Mitsubishi vs 5075
THIS MODEL IS EQUIPPED WITH A KEYBOARD LOCK FEATURE; THIS CAN BE MISTAKEN AS A NO POWER CONDITION. TO UNLOCK THE KEYBOARD PRESS AND HOLD THE "MENU" BUTTON ON THE FRONT PANEL FOR 10 SECONDS
Oct 11, 2007 | Mitsubishi VS-50705 50" Rear Projection...
Need help repairing Mitsubishi VS 4541 rear projection TV
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems, to activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source
Jul 28, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS50603 will not turn on
If you are not a tech the tv needs to go to a tech to be fixed.the probleis in the power supply or related circuit good luck.
Apr 01, 2007 | Mitsubishi VS-50603 50" Rear Projection...
Set won't turn on
I would check the convergence output IC`s first.
Sep 27, 2006 | Mitsubishi VS-50603 50" Rear Projection...
Televison & Video Logo
965 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
