Question about Philips 55PW9383 55" Rear Projection Television
Comes on then shuts off
55" Phillips 55PW9383  Television that is approx 4 years old. My TV comes on then will immediately turn back off.
  • 1,139 Answers
Re: comes on then shuts off
Hello Mha8649,
The TV shuts off because the shutdown circuit it turning the TV set off. The shutdown circuit does this because of an over-current condition. I would advise that you take the TV to a qualified TV repair shop.
I hope this helps,
Thank you,
Posted on Oct 15, 2007
0 characters
3 Points
Have a model 55pw9383/17f that had convergence issues for a while. The reds, blues and greens were all seperated. Now I turn it on and have no picture.
Your convergence has failed and needs to be repaired.You can call in a repair shop or you can get the parts and instructions from and do the repair yourself. Its a fairly easy DIY fix.
Jun 17, 2011 | Philips 55PW9383 55" Rear Projection...
No display or audio
I had the same problem after replacing several things and still having same problem, it ended up being a capacitor.
Jul 03, 2010 | Toshiba TP55H60 55" Rear Projection...
Tv does not stay on
If you have a rear projection, it is the bulb. Ypou need to replace it.
Jul 24, 2009 | Mitsubishi WS-55859 55" Rear Projection...
I have a phillips 55pw9383/17f
Try going into your system menu under picture and adjust the convergence this will show a plus sign and you realign your picture I hope this helps
May 05, 2009 | Philips 55PW9363 55" Rear Projection...
Tv turns on and then off
Good Day, ruschracing;
Storm? The first thing you should do is unplug the TV from the wall for 3 to 6 minutes (reset), then plug back into wall.
If that does not help, then you should call an authorized service center to give you an estimate for the repairs. OR call your home owners insurance company.
Good Luck, big IRISH.
Jul 25, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
You can get the repair manual emailed to you after purchase at the following link its the full service manual 2400 plus pages you need the DPTV 340 service manual in their Phillips catagory on the left side.
Jun 21, 2008 | Philips 55PW9383 55" Rear Projection...
This can be one of two problems. 1: convergence output ic's need to be replaced. 2: The problem is in the power supply, most likely a power diode.
Both problems you will need to take it two a repair shop.
Mar 15, 2008 | Hitachi 57TWX20B 57" Rear Projection...
The TV is a Phillips Matchline 55"; wide screen, approx 7 years old.When switched on the LED goes red then there is a clicking sound then the LED blinks red continuosly and there is no picture.
The TV is going into protective shutdown. What is the model number of your set? I may be able to help you depending on the chassis number.
Mar 13, 2008 | Projection Televisions
Philips 55PW9383 55" Rear Projection Television Logo
123 people viewed this question
Top Philips Projection Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Projection Television Expert? Answer questions, earn points and help others
