Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Jenn Air stove wired backwards
My cabinet guy on my jenn air stove replaced the plug wire backwards. Placed the ground on a hot and a hot on the ground.
When he plugged it in it worked until he tried the fan. Then something popped and melted. Now only the eyes work. No control panel.
Are there fuses in the back or am I just shopping for a new stove?
  • james_bon213 May 14, 2009
    the model number is a SVE47600 or 47500 according to the owners manual.
    I wasn't there so I don't know about the fan but the control panel is dead. No LED numbers so no control of the oven or the fan
    Thanks so much for your help!!!
    President:
  • 1,865 Answers
The fan is likely 120-volt fan, and swapping the wire likely put 220 across the fan. Did the fan seem to rev up very fast? The control is also likely 120-volt, and that too had 220 applied to it.
Give me the model number, and I'll find what parts you need to replace
Posted on May 14, 2009
Jenn-air electric down draft stove has power to the controlls but the power to the elements is not working on the stove and the oven. is there a fuse? What is my problem?
The electrical connections are as follows: L1 goes to one of the 120 VAC hot lines. N goes to neutral. L2 goes to the other 120 VAC hot line. You may have a separate ground wire (required on all new installations) connected to the stove frame. L1 + L2 = 240 VAC.
Your controls are connected to L1 and neutral. The wiring here is good. The heater elements are connected to L1 and L2 with no connection to neutral. Either the L2 line is open, or the L1 connection that provides power to the heaters is open (probably a different wire than the one providing power to the controls). L2 is the most probable culprit, and the problem could be the wall socket, the stove cord, or a bad connection inside the stove. (I recently fixed a case like this - both the socket and the plug on the cord were burned out.)
Jan 14, 2011 | Jenn-Air JES9800A Electric Kitchen Range
Wire from circuit breaker is Black/White/Bare(ground). From Jenn Air is Black/White/RED/Green (ground). How do I wire? Jenn Air Black to Black, Jenn Air Red and White to White? Grounds (Jenn Air Green to...
depending on your local electrical code:and I see that the unit is 240 Volts A.C., then RED=Power/Black=POWER(L1 & L2)/WHITE="N"Neutral/and GREEN=SAFETY GROUND,on the new unit, then use from the wall power BLACK = L1 and White= L2. then on the unit RED=L1 and BLACK=L2(either way you hook these 2 up there isn't a polarity issue on these 2 wires) on the units hook-up/then use the BARE supply wire as neutral and tie BOTH WHITE and GREEN from the unit together to this BARE wire
Apr 29, 2010 | Jenn-Air JED8230 Electric Cooktop
Jenn Air cooktop has 4 wires Black, white, red, and green and my house supplies power with 3 leads white, black , & green. How are the wires hooked up to power the unit?
Old plug: green is ground, white and blace are both hot power. New cooktop: green is ground, WHITE is COMMON, black and RED are hot power. You are going to need an electrician to run a new circuit and plug for your new cooktop.
Aug 31, 2009 | Jenn-Air JED8230 Electric Cooktop
Jenn-Air 30 in. Under Cabinet Hood had no instructions on how to
This is a straight forward wiring project involving 110 volts of electricity and a 15 amp circuit.
If there is already power available at this location use it. If not, run a wire to the cabinet above the hood location with enough extra to drop down into the hood area and hook it up.
Once you have the power wire in place it is just a matter of hooking the wires up black-black, white-white, ground-ground screw.
enjoy your new hood.
May 26, 2009 | Jenn-Air 30 in. Pro-Style Range Hood
Wiring a used Jenn Air
The red and the black are the two 'hot' wires and the green is the ground. The red and black are connected to L1 and L2 of your cordset or circuit breaker. The green connects to the ground bus bar
Apr 26, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Wiring problem
those wires dont go to the down draft. those colors are to hook up the stove. do you have the instalation instructions?
Nov 09, 2008 | Jenn-Air JED8430 Electric Cooktop
Wiring 4 wire cook top to 3 wire outlet
What you have is a 220v and a 110v circuit within the cook top. It needs a 4 wire feed to supply 2 hots, 1ground, and 1 neutral. The 3 wire outlet only has 2hots and a ground no neutral, which will probably not allow your control circuit to operate. You nee to run a neutral wire to obtain a 110v circuit. DO NOT try to run neutral off the ground or you will energize your cook top cabinet and it will shock you. Your solution is to run a neutarl wire from the closest circuit that you can find.
If you need further asst.
Eboukater@gmail.com
Sep 24, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jenn air electric range wiring diagram
In a normal house, black and red are the hot wires and are wired to a circuit breaker or fuse at the panel box. White goes to the ground bar. Sometimes the white(neutral) is seperated from the ground. Sometimes they can be connected together. At the fuse box they both go to the silver ground bar. If you are attaching a cord and plug purchase one to match the outlet you have. Usually at the terminal block the hot wires are on the outside. Neutral in the middle. At the terminal block there is a metal strap or wire going from the center terminal to the frame of the stove. If the cord you have is just 3 wires leave it. If the cord you have uses 4 wires remove the strap and connect it seperately to the green or ground wire on the cord.
Jul 02, 2008 | Jenn-Air JED8230 Electric Cooktop
Jenn-Air 88370 drop-in stove, want to convert!
your old jennair is 220 should be three or 4 wires in it red for 1 side of the 220 black for the other side of the 220 white for the bottom of the outlet and if green is there you can hook it with the white wire or just not use it let me know if your colors are different
Feb 14, 2008 | Ovens
Jenn-Air JED8430 Electric wiring confusion
On Cooktop From Box
Black to Black
Red to Black w/red stripe
White to Ground
Green to Cooktop frame
Nov 16, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
207 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
