Question about Mitsubishi VS-60803 60" Rear Projection Television
My Mitsubishi VS-60803 has a black bow in the picture going from left to right on the top and the bottom, how do I fix this?
  • sinedie73 May 13, 2009
    It is a 2002 VS-60803. Yes the black streaks are going from left to right on the top and bottom forming a kind of bow tie picture.
  • 10,594 Answers
How old is this TV and that black bow is across the screen going from left to right?
Thanks.
Posted on May 13, 2009
  • Shahid Electronics
    Shahid Electronics May 13, 2009
    Thanks for reply.
    It seems convergence board problem and convergence out IC will be replaced.
    If you want to repair it by yourself, I would recommend to download service manual from HERE for small fee.
    Service manual has all schematics, exploded views, part list of TV to do the repair.
    Thanks.
Mitsubishi vs-60803 turns relay on board then goes
replace the power relay the contacts are burned and, will not latch.
Jul 22, 2010 | Mitsubishi VS-60803 60" Rear Projection...
Hey I have a mitsubishi vs-80803 i have picture but it is a bit bowed on the right side and bottom of picture (black curvature space showing no colors or picture) maybe the convergence needs to be reset?...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 05, 2010 | Mitsubishi VS-80803 TV
Skewed picture
you need ned convergance chips
Mar 22, 2009 | Mitsubishi VS-60621 60" Rear Projection...
Bows on sides
Try degausing the set with the system software. if this doesnt fix it you will have to degause the set with a professional tool.
Jan 27, 2009 | Mitsubishi VS-55601 55" Rear Projection...
Is there a reset? VS-60803
menu -1-3-7-0
then inital
then enter
DO NOT DO THE E2 RESET!!!!
Let me know if you need more help
Tim nolan
Sep 17, 2008 | Mitsubishi VS-60803 60" Rear Projection...
Help with bowing
Usually consumer described bowing is bad solder connects
on pins of convergence IC's. If the effort is made to pull the center PC board out,then replace both Stk392-570 IC's for
durability.
Note: V-Pin amp and pin out relates to left/right side bowed-in
  issues,a problem not usually found on your model.
Aug 30, 2007 | Mitsubishi WS-55908 55" Rear Projection...
Mitsubishi vs-60803
greetings from belize take your set to a tech and have him look at it.good luck.
Mar 23, 2007 | Mitsubishi VS-60803 60" Rear Projection...
Mitsubishi vs-60803
You have the typical convergence IC falure that every projection TV encounters at least once in its lifespan. The convergence ICs will both need to be repalce as it will only get worse. if you have no solid state repair experience, play it safe and call in a pro to assist you in this repair. Good Luck
Mitsubishi vs 60719 - Wavy bow in picture
Either a bad solder connection on your convergence module or a bad convergence IC. Repair costs will probably be in the $350-$500 range.
Jan 28, 2007 | Mitsubishi VS-60719 60" Rear Projection...
Televison & Video Logo
57 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
