Question about Canon Rebel XT / EOS 350D Digital Camera
Blur on night sports pictures
I can't stop the action with the EOS Digital Rebel XTi with either lens. I use tripod, monopod...ISO is set at 1600/ Aperture at 5/6.  and I'm set on servo. Non of the camera programs make any difference: AV, TV, Sports, or P.
Michael Sellars
  • 4 Answers
You are probably going to need a faster lens to get pictures like you want, like around the 1.* range. If you have the ASA at 1600 and aperture at the minimum in Av mode, try and keep the exposure time to 1/focal distance. Such as, if you are shooting 200 mm lens then maximum exposure time is 1/200 second. If you zoom out a bit to 50 mm then it may look better too. You may as well turn the megapixels down too because otherwise you'll just see the blur even more, I'd suggest 3.2 megapixels that will look good in 4x6 photos or on the web. Other than that, try and take pictures where the action is coming at you or going away. Get as close as possible too, so that you don't have to zoom as much. At the H.S. football games I go to it seems like they let anyone down near the field who has a big lens.
Posted on Oct 21, 2007
I have a canon rebel t1i and while in sports mode at night, it takes fuzzy pictures and nothing comes out clear?
You have to Manually Set/Override the ISO settings to a larger number like 1600 or higher this will let the camera take pictures at faster shutter speed to freeze the action, Try to use the camera in more manual modes, Tell the camera what do, old school photograpy.
Nov 07, 2013 | Canon EOS 500D / Digital Rebel T1i Digital...
Blurred edges
blurring occurs not depending on ISO, i think the lens is the problem. try to clean the lens glass carefully, is there some grease stick on the lens? if not it might be dislocated one of the lens structure.
have you try another lens?
Jul 26, 2013 | Canon EOS 400D / Rebel XTi Digital Camera
I have a Canon Rebel XTi, I am having a problem with the camera either freezing up or being blurry when take action pictures, especially in an arena. Is this a lighting issue or what?
Carmen,
This is likely. Action shots require a fast shutter speed which in turns requires more light. Aside from a very expensive lens, about the only thing you can do is try to increase the light, slow the shutter speed, and increase your ISO rating to 1600.
Thank you.
Feb 27, 2011 | Canon Rebel XT / EOS 350D Digital Camera
I took action pictures last night with the TV mode setting, ISO- 1600, with the White Balance set up. It worked fine on Saturday. I had a lot of burry shots. I am taking volleyball pictures. Do I...
What your are trying to do can be very difficult. First is with a 75-300mm lens you are going to have a hard time keeping the camea steady...I suggest a monopod. Set the camera for Action shots ISO-1600...you will need a shutter speed at least 250th of a sec. to get decent action shots.
Sep 21, 2010 | Canon EOS Rebel XS 35mm SLR Camera
Canon rebel xsi, using 75-300 lens, taking photos of basketball game, pictures are blurry, especially the ones in "action" using the sports mode. also tried my 18-55 IS lens, same thing happening, using...
That's a big lens and for sports photography you are going to need a lot of light to ensure you can use a fast shutter speed to capture the action. Sports mode may do too much for you and you might want to try switching to a more manual mode. Try switching to Tv mode which gives shutter speed priority. Set the shutter speed to something around 1/150 or higher (1/200) which should be fast enough to freeze the action. Make sure the ISO is set to 200 or 400 for best results and see how you get on. This should stop any action based blur which would leave you with focus problems if the pictures are still blurry. Check out http://www.dpreview.com/reviews/canoneos450d for info on what this camera can really do for you
Jul 28, 2009 | Canon EOS Rebel XSi Digital Camera
Blurred pictures on action shots
For daytime, make sure the ISO is kept low, say 100, or 200 if a little dull. For nighttime or indoor, you may need to increase the ISO up to the max of 1600.
Check also the AV+/- setting isn't set too high - are the shots brighter than normal? If so, hold the AV+/- button and use the scroll wheel to bring the setting back down.
One other thing to check is your CF card - have you changed cards recently? I have two 2Gb UltraII cards from Sandisk - one is really fast, about 1-2 pictures per second, the other is really slow, about 3-4 seconds per picture. They should be the same but are not.
Also try shooting in AV mode to keep the lens wide open and get the fastest shot possible.
Hope this helps!
Mar 25, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Blured zoom shots due to low light
Hi Charles A/f works on contrast it 500mm f6.9 even at 1600 iso it willl make no diffrerents if it to dark it will not lock on
Jan 03, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Night photography - Fireworks
ASA - very high 800, 1600 atleast
f- closest, 3.5,4. not more.
speed (ISO) if you want it to look in action so 1''. (second) if you want it freeze so faster..play with it
try use a tripod so it wont look blury
Jul 04, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Blurred night time football pictures
The standard canon 75-300 lens is not considered a "fast" lens. Because of this, when zooming in on objects you are actually reducing the amount of light hitting the image sensor. Fast lenses cost $$$$. Just google "Canon L Glass" and you will see what I'm talking about. Try opening the field of view (zooming out) to allow more light to be absorbed bu the image senor. Crop your subject later in whatever software you use. You can also use one of the manual modes and up your f-stop to make the camera more sensitive to low-light conditions (higher f-stop means higher film speed.. higher film speed is how fast the "film"... aka image sensor absorbs the light. for action photos, faster film speed is key!!). have fun experimenting.
Sep 26, 2007 | Canon Digital Rebel XT / EOS 350D Digital...
Blurred football pictures
low light means the shutter stays open longer to capture the image.   Try changing exposure settings.
Sep 30, 2006 | Canon Digital Rebel XT / EOS 350D Digital...
Canon Rebel XT / EOS 350D Digital Camera Logo
106 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
