My google screen scrolls up and down on its own making it near impossible to click what I want.
Usually screens will scroll like that if you have accidentally pushed down on the middle mouse button - you will see a circle with a double ended arrow in it. Moving the mouse in any direction will make the page scroll up or down indefinitely until you deactivate the scroll or move your mouse to the centre of the screen where page stops scrolling but is still active.
SOURCE: The small scrolling icon on Windows Vista
1-Firstly you go to system control panel(Start button->setting->Control panel)
2-select the mouse option and click
3-you see the 5 option under it,select the pointer options
4-under the visibility option unmark Display pointer trails &
Hide pointer whilt typing option
and also check the pointer speed option under pointer option.
5-than ok..
Thanks,
SOURCE: I have a problem with the windows vista program on
http://www.google.co.in/url?sa=t&source=web&ct=res&cd=2&ved=0CBQQFjAB&url=http%3A%2F%2Fsocial.answers.microsoft.com%2FForums%2Fen-US%2Fvistaperformance%2Fthread%2F1289a4e2-d9ca-477b-8bf6-4560238a6ce0&ei=KBJ0S-i3A9CRjAexhfmjCg&usg=AFQjCNGUYAcXdbMz94uc55wPnBuSWwZ3bQ&sig2=1-cJOatDW5PR26Z-0Nkk1g
try this..myt help you
SOURCE: when scroll webpages they fold down as I scroll.
check your graphics card if installed ensure its seated properly.
SOURCE: when i am working with
Are you using an external mouse? It could be a problem with the mouse. I had the same problem and changing the battery fixes it.
SOURCE: how do you make the page scroll smoothly in
I think you issue is the stuttering effect of scrolling.
Actually in windows, the way of behaving of the mouse scroll wheel is likely controlled by the device driver... So checking the smooth scrooling option may not work.
So you can find updated drivers for your mouse which can resolve your issue.
Also, you can do one thing...
Go to the menu that controls the options for your mouse.... the menu where you change the mouse pointer's speed.
There, go to the " Wheel" menu and lessen the no. of lines to be scrolled per scrolling of the wheel.
I hope I am successful in resolving your issue.
Thank you...
