Question about Craftsman Garden
Repair a weed trimmer, How to remove the starter clutch
Craftsman 4 cycle string trimmer model #358.796121. I cannot get of the starter clutch in order to get at the armeture-magneto
  • kane8 May 13, 2009
    steve the solution worked great; however now I cant get the next part off, it looks like it threads onto the shaft and turns counter clockwise. How do you keep the shaft from turning while losening this part???
  • Anonymous Mar 22, 2014
    removed clutch but cover I can't remove to get to the armature-magneto how do I do that
  • 181 Answers
Down in the center of the clutch there is a screw that holds everything to gether.usualy it's a torx head screw.some are reverse thread so be careful.hope this helps,let me know
Posted on May 13, 2009
How do I replace the pull starter cord
How do I replace Graeme, Check the attached links,instruction and videos on starter rope replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starter Repair
String Trimmer Recoil Starter Replacement Echo String Trimmer Repair Part...
How to Wind Up or Rewind Starter Pull Rope Recoil Spring on Yard Pro 130A...
Part 1 3 Changing the Recoil Rope on Craftsman Model 358 791030
Apr 01, 2016 | Garden
Barely used weed wacker head stopped turning clutch seams loose has play can i unscrew the clutch?allen wrench??
If your clutch is spinning you more than likely have broken the drive shaft that goes down to the head. it is fairly common with craftsman weed trimmers.
Nov 06, 2015 | Garden
Husqvarna weed eater starts , but blows alot of smoke & then stalls out
Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
Check the attached links,instruction and guides, Good luck
String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Craftsman Trimmer starts then dies
How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
How to Clean Two Cycle Two Stroke Engine Carburetor
Sep 06, 2012 | Husqvarna 128 LD Weedeater
I have a craftsman line trimmer, I believe it is model #79107, pull string to start and string will not go back in ???
This can be a challenge to repair. The Torx screws holding the casing and machine to it will have to be removed to access the starter/recoil unit. If you have opened one up before, it's not that bad...if not...it's a real learning process, Take your time, you will need Torx head screw removal tools and a little patience. Once you reach the starter unit, you will realize the problem. Go to that point and maybe post again later?
Jul 06, 2010 | Craftsman Convertible 25cc. Gas Line...
The head will not spin on Troy Built weed eatter
sounds like your flex cable has taken a trip south. Pull the shaft off the head and take a look at the flex cable. If flex cable is ok, they your clutch is defective.
May 29, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Replacing pull string on Poulan BVM200VS leaf blower
You will need to split the housing and remove the impeller wheel. In doing this you will have to disconnect the throttle cable and the switch assy. This can be a hand full if you have never done one.
In the future when you are purchasing a string trimmer or blower
or hedge trimmer, be sure that the starter can be removed by
removing 4 screws. This makes starter repair a 5 minute $10 job
instead of an hour $40 or more job. The problem is that you will
not find this in most home centers or box stores. You will have to
go to a full service dealer.
Sep 12, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Pull string for Weed Eater Featherlite Plus came out
If you have the starter spool out (the one the rope goes in)...Here is what to do. Take the starter spool and change the rope out putting it back exactly as it was. Leave the rope hanging. Hold the spool and set it down on the rewind spring. Turn the spool on the rewind spring until you feel it is tight enough. While turning, hold the rope in the little slot in the spool so it can go around without hanging up. Once it is tight, get the rope in line with the spool opening and SLOWLY let the rope rewind. Put on the handle and put the unit back together.Good luck...Lee
Sep 06, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Trying to replace the head of the weeder with a new line system,
I cannot get the head of my craftsman 791050 head off to replace with a new line system
Aug 01, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Manual for craftsman weedeater
how do i take the clutch off my craftsman weed eater model # 358791050 to change the pull string
Apr 11, 2009 | Garden
Craftsman manual for a 4 cycle lawn trimmer
I have a craftsman incredi-pull 4 cycle, I changed 4 cycle oil, too much smoke coming from the machine, what I can do?
Nov 11, 2007 | Video Game Consoles & Games
Garden Logo
488 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
