Question about Hayward H Series Induced Draft Abg 100,000 Heater
Pool heater Hayward H series won't fire up
When I turn the heater on, it comes up with a code F1 and shuts down. I have the gas on and cleaned out all the burners. Wondering if it's the igniter?
I've had problems every year at start up with this heater.
  • 4 Answers
SOURCE: hayward pool heater h series
the issue is a broken baffle in the system. there is a baffel that directs water into the heat exchanger and back out into the system. The welds that hold the baffel in place have broken off. It can be repaired if you take the unit to someone with a mig welder and have them re-weld it (muffler shop, mechanic?). there needs to be a weld on both sides. You can see the baffel if you remove the unit and look down the inlet and outlet tubes.
Posted on May 25, 2009
john224
  • 1378 Answers
SOURCE: 1 year old hayward h1001d pool heater clicking
Actually, the clicking is likely causing the shaking. Inside the manifold of a H100 is a stainless steel diverter plate that send some of the passing water into the heat exchanger and lets the rest past and back to the pool. When it breaks, you will hear a 'clicking' noise at it rattles in the water path. When it breaks, the flow to the heat exchanger is intermittent and you will begin to boil the water, causing the shaking. This situation is dangerous, especially without a pressure relief in the heater or pipe. As long as your water chemistry is sound, Hayward will usually cover this under warranty even if the unit is over a year old. Contact them to get a factory authorized repair rep out at: http://www.haywardnet.com/locator/
Posted on Jun 12, 2009
  • 139 Answers
SOURCE: Hayward Comfortzone pool heater pilot will stay
check for continuity at all control and safety components,i.e. press switch,high limits,thermostat,on/off switch and flame roll out switch
Posted on Jun 21, 2009
  • 9 Answers
SOURCE: HAYWARD POOL HEATER FIRES FOR 5 MIN. THEN GOES OUT
Sounds like it is cycling on high limit; causes are related to water flow through the heat exchanger or a faulty high limit(doubtful given the heater cycles back on). Check the internal bypass for obstructions; has anyone worked on it recently? There are usually two high limit switches with different trip temperatures; installing the wrong one could also be the culprit. Does the heater "bang" before it goes off (a sign that the water is boiling inside the tube bundle)?
Posted on Jun 28, 2009
thepool
  • 78 Answers
SOURCE: Hayward H400 Pool heater will not stay lit
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Posted on Apr 23, 2010
New Hayward Heater H series 400 BTU won`t light error IF
check gas pressure again meter could be too small if furnace goes on while heater is on it will run out of gas and turn off giving you that error
May 13, 2012 | Hayward H Series Pool & Spa Heater 400k...
My hayward h400ed2 heater starts for 2-3 seconds then shuts down showing error IF. I checked the gas orifices - they all clean. Heater was working fine fo the most of the summer then started showing IF...
Have you installed anything in your home that uses gas? Alot of times it due to low gas pressure.
When you checked the orfices did you actually remove them? or just stick a paperclip inside and clean them?
If the heater is firing ..even for 2-3 seconds the ignightor is fine. If it wasnt it wouldnt lite, period... bad call on hayward
Aug 22, 2010 | Hayward H Series Pool & Spa Heater...
My Hayward H Heater turns on, fires up the gas,
bet you have a spider web or small debri in the gas lines, take a wire into each one, happened to me too
Jun 06, 2010 | Hayward H Series Induced Draft Abg 100,000...
The heater fires up for about two seconds then turns off. The filter is clean!
most likely your flame sensor needs to be cleaned with fine emory cloth.sensors sometime become oxidized or corroded. once burner ignites,if flame is not sensed signal is sent to shut down valve as a safety precaution
Jul 16, 2009 | Hayward H-series Electronic Gas Pool...
My heater starts and then after about 3 seconds shuts off
Either , you really don't have good pressure (below 18 PSI on filter) or your water pressure swith is defect.
Try placing your filter on "recir" and fire the heater , if it fires and stays on .....it's definitely your pressure -back wash.
hope it helps
Jun 07, 2009 | Hayward H Series Pool & Spa Heater 400k...
Jun 06, 2009 | Hayward H-series Electronic Gas Pool...
Hayward H Series 400,000 BTU Pool Heater Won't Ignite
You can not manually light it. Open the front cover look for the gas nozzles brass looking on a tube. on the right side you will see a wire going to a sensor above the next to last burner take the nozzle out for that burner. 7/16 wrench unsrcew the nozzle and see if it is clogged. use something soft to push it out. Spiders love to lay eggs in these. Spray with WD40 and reassemble should work now
Best of luck
May 25, 2009 | Hayward Pool Products Hayward 400k Lp H...
Hayward H Series Induced Draft Abg 100,000 Heater Logo
365 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
