Question about Imperial IFS40 Deep Fryer
Ifs 40 deep fryer
PLEASEHELP i ve connected my fryer but seems like the flue is coming from right at the back any solution.
I have a used fryer, imperial, looks like the ifs 40 but can not find the model number on it. Do you have any idea how I can find the model number?
Posted on Jun 10, 2009
Flames coming out the exhaust
Flames coming out of the exhaust can be caused by several things.
The fryer could be set up for natural gas and it is installed on a propane system. The fryer can be leaking oil near the burner tube and the oil is burning causing excess flame. There could be grease buildup in the flue in the back of the fryer from people hanging the baskets in the wrong place.
Feb 24, 2014 | Pitco Frialator SG18S Deep Fryer
I have a Vulcan lg400 propane fryer it has only been used 4 times for catering events. yesterday we were using it and after a while it started what seemed like mild back drafting the flame was actually...
Hi there. Flames rolling back instead of shooting inside the fire tubes can be a result of clogged fire tubes or air entering the flue, also check if there are objects blocking the flue. Regards.
Nov 03, 2013 | Vulcan 1VK85DF Hi-efficiency Gas Fryer...
Deep fryer ignites but burner flames will not enter cylinders
Hi there.
Fire tubes may be clogged with soot. Have a technician inspect and clean the fire tubes for soot deposits/ build ups.
Check also if there is no air or ventilation directed on flue as it will push the flames back to the burners.
Regards.
Aug 12, 2013 | DCS Gas Deep Fryer 40 Lbs Double Basket...
Deep fryer catching on fire
From the video it appears many things could be wrong. The baffles and burner tubes could be clogged, the burner itself can be clogged, the flue is blocked, or this unit is using the wrong type of gas, ie: propane on a natural gas fryer.
Recommended steps for troubleshooting.
1. Verify proper gas type. Natural or Propane.
2. Check Burners, tubes, and baffles, clean all soot and debris from them.
3. Check for and remove any obstructions from the flue.
Apr 27, 2013 | Kitchen Appliances - Others
FIRE IN FLUE
There may be soot/ carbon build up inside the fire tubes that's why flame crawl all the way to flue. Also check if your fryer receives the right gas pressure and type as rated on the nameplate.
May 27, 2011 | Pitco Frialator SG14 Deep Fryer
FLAMES ARE COMING OUT THE BACK OF MY FRYER,WHAT WOULD BE THE PROBLEM
There may be an excessive carbon deposits inside he heat tubes of your fryer, you have to clean/ remove these carbon to eliminate flames coming out of the back of your fryer (flue riser).Carbon build up on heat tubes are due to low gas pressure and volume; incorrect air and gas mixture.
Apr 17, 2011 | Pitco Frialator SG18S Deep Fryer
Soot coming out of flue (chimney) on the back of the fryer.
you need to clean the burners and fire tubes, remove all carbon deposit and make sure that the unit receives sufficient gas pressure as labeled on the nameplate.
Mar 07, 2011 | Pitco Frialator 35C Deep Fryer
RED HOT FLUE EXHAUST
Hello. Yes this is normal for this type of fryer, meant more to cook the product, as efficiently as possible, and guzzle gas pretty good. If the orange is near the bottom of the flue, that is pretty good, there is , or should be insulation on the outside of the flue, or if the air gap is large enough, no insulation at all. Not getting near the exhaust pipe is advisable, or you will be burned. The gas pressure is important thought, if the burners are over/under pressured, it will affect the burn enough to damage, and shorten the life of the fry vessel. Call a local authorized servicer and have a check up, will not be free, but will save expense of something not being correct, most places, you pay an hour to check it good enough.
Hope that helped, and thank you.
May 05, 2009 | Imperial IFS40 Deep Fryer
Imperial IFS40 Deep Fryer Logo
148 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
