Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Ice dispenser in door clogged up or frozen
My ice maker works but when I try to get ice from the door dispenser all I get is a lot of noise like ice being stirred around and/or crushed but no ice comes out into the glass.  It seems the ice gets stuck or frozen in the door part of the dispenser.
  • 2 more comments
  • soccerfan Dec 12, 2007
    My dispenser works intermittently with partial cubes getting stuck in the metal fingers used to crush the cubes. We do not use the "crushed" option because of this but has not helped. We are constantly dislodging cubes. The problem started about six months ago (the unit is two years old). The auger and motor seem to work otherwise and are not bound up by anything but the trapped cube. Any ideas on what can be tried?
  • Anonymous Jun 29, 2008
    ice maker is frozen in the back and no ice is despensing
  • jose_larriu May 11, 2010
    for how long should i defrost the freezer
  • Anonymous Mar 30, 2014
    loud noise when using door ice dispenser
  • 473 Answers
I see this a lot with people who mainly used crushed ice.  It will leave small pieces of ice behind and add up to a clogged situation.  If you mainly used crushed ice you will need to run full cubes thru every so often to keep the chute clear.  Another cause of this would be the flapper door on the dispenser doesn't close completely and warm air gets in and melts the ice in the bin so it clumps together and won't dispense.  In this case you may need to replace the solenoid that shuts the door and/or the door.  Let me know what you find.
Posted on Oct 15, 2007
Ice will not dispense from the ice dispenser on the door.
What is the complete model number of the unit?
Dec 05, 2012 | Refrigerators
Ice maker
check to see if you ice bin has full size ice cube in it... if there is then you dispense is stuck in the crush mode check to see if there is something keep the crushing wheels from releasing... other than that it could be the control on the door..hope this helps
Aug 26, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Ice maker dispenses cruched ice in cube ice mode
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid.
With your model number I can find a diagram which may help.
Oct 05, 2009 | Refrigerators
Ice Maker GSI-26 dispenses crushed ice and will not dispense cube
Aug 17, 2009 | Refrigerators
Ice Dispenser clogged with frozen ice
I have the same problem. Found this posting:
http://www.applianceblog.com/mainforums/sears-kenmore/10491-kenmore-ice-maker-dispenser-door-shute-clogging-missing-heating-element.html
Maybe our heater is not working?
Jul 05, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Icemaker makes ice; door dispenser cranks, but no ice dispensed
sounds like either the dispenser motor is bad or the dispenser yoke is stripped. remove the bucket from the freezer. you will see a u shaped yoke in the rear of the disp area. this should be fairly hard to turn by hand if it turns easily then the motor gears are bad if the yoke slips on the motor shaft then you have a stripped yoke. hope that helps. peyton...
Jan 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I would contact Hotpoint direct for this one. It sounds like a design fault to me.
What I think may be going on is that the cubes are melting too much, then refreezing lower down.
Set your freezer to -18, and the fridge to +2 and see if that changes things any.
Check seals in that area. Where is the moisture coming from to generate the frosting? - Is the location high in humidity?
Jun 11, 2008 | KitchenAid KSRS25IL Side by Side...
My icemaker is not making ice. This has happened 3 times in the past 3 years but this is the longest it has gone without making ice. The other 2 times it lasted 2 days. It has now been 4 daysince the ice...
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
May 15, 2008 | Amana Refrigerators
Refrigerators Logo
590 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
