Question about SanDisk Sansa Shaker SDMX9N-512 MP3 Player
SanDisk Sansa cover
The cover to my usb port and battery does not stay on, does anyone else have this problem, or should I return it and hope the next one will stay closed?
  • Anonymous Dec 26, 2008
    I have two of these and they both have poor lids that come EASILY. This is a very poor design especially since these things are designed for kids. They can't change tracks without it coming off.
I think everyone has that problem. Poor Design!!
Posted on Dec 25, 2007
Will my mp3 player (sandisk sansa m230) charge
Assuming the computer puts out enough juice, yes. Not all USB ports do.
Plug it in, and the Sansa should say "Charging" if it is charging. If it doesn't, try a different USB port if possible. If your computer has ports on the front/side and on the back, the back ones are more likely to put out sufficient power.
Apr 29, 2010 | SanDisk Sansa m230 MP3 Player
Hey my sandisk sansa 2gb mp3 player will not charge and it is bran new how do i fix this
1) Try plugging it into a USB port on the BACK panel of your PC, and leave it there for a few hours.
2) Try plugging it into an AC adapter, and leave it there for a few hours.
3) There was a manufacturing problem with many Sansa Clips where the battery leads would detach from the battery. This would result in the Clip not being chargeable, and eventually it would only turn on when connected to a PC (which bypasses the battery). If this is the case with yours, you'll need to return it for a replacement.
Feb 03, 2010 | SanDisk Sansa Clip MP3 Player
MP3 Sansa Sandisk 1 GB
If it won't charge, then:
1) USB connector is damaged
2) USB port is damaged (Have you tried other port and/or other computer ?)
3) MP3 Battery is damaged
May 27, 2009 | SanDisk Sansa m240 MP3 Player
Will not take a charge. took two charges prior but has now stopped
I found this online at www.sandisk.com under warranty and manuals link.
I believe they have an excellent Return Authorization system, that if you truly have trouble with your disk player and it's still under warranty, gather your receipts and get on line to get an RMA. I have successfully returned to disc players that were infact faulty (FAT problems) and received two replacement players. Get on it right away. Look at the manaul online too. IT can be very helpful. I've included the Battery info, and the link for the manual at the end.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
May 12, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
My sansa fuze wont charge
Some USB ports cannot supply enough power to charge the Fuze. I had the same problem. I worked around it by getting a wall charger from RadioShack.
Mar 15, 2009 | SanDisk Sansa Fuze MP3 Player
My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
USB Port 2.0
Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
I hope this helps, and don't forget to rate the answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip wont power up unless hooked up to usb
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Charging
computer.
Clip player.
Sansa
adapters.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
I know its a silly question but can anyone please tell me the step-by-step process to transfer songs to my sansa c150 MP3 player......... Thanks
  • Step 1:Free a USB port on your desktop computer. Now, grab the USB cable for your SanDisk Sansa MP3 player and connect the player to your computer.
  • Step 2:Wait for your computer to find and recognize the player. This may take a few moments. Once you receive a confirmation message, open your computer and scan the icons for the SanDisk MP3 player.
  • Step 3:Open the SanDisk Sansa MP3 player on your computer. The music files that you currently have saved to the player’s memory are displayed.
  • Step 4:Open a folder containing music files that is stored in your desktop computer’s memory. Scan the files for songs that you want to transfer to the SanDisk Sansa MP3 player.
  • Step 5:Left-click on a song file and drag to the SanDisk Sansa window. Drop the file and let your computer complete the transfer. The transferred file appears at the bottom of your music list.
  • Step 6:Unplug your SanDisk Sansa player from your computer. Turn the player on and allow the file transfer to update to the internal memory of the MP3 player.
Tips & Warnings
  • When properly connected, the SanDisk Sansa MP3 player displays a USB Connected message on its LCD screen.
  • The music files in the SanDisk Sansa MP3 player will have different icons next to their filenames which will tell the file type at a glance (MPEG, MPEG layer 3 or WMA, for example).
  • Some songs feature copyright protection which may interfere with your ability to transfer music to the SanDisk Sansa MP3 player.
Jan 27, 2009 | SanDisk Sansa c150 MP3 Player
Charger
Your USB port must be repaired. In the meantime, hopefully, your computer has another USB port that you can use. Battery is a replaceable lithium ion rechargeable battery. There are battery chargers that you can connect to wall outlets - the type that plug into the computer would probably require that you plug it into the USB port, which you said is broken - so that's a no-go. There are multiple vendors for battery chargers - one possibility is http://www.greenbatteries.com/
-Tha Mp3 Doctor
Jun 02, 2008 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa Shaker SDMX9N-512 MP3 Player Logo
21 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
