SOURCE: Songs deleted, but empty space and song info. still remain
Get yourself anapod from Redchair software, this works on older PC's and you just drag and drop songs onto your ipod.Its also very easy to delete tracks aswell.Anapod supports adding and deleting photos onto the ipod.
SOURCE: IPOD Shuffle deletes songs if I delete them from the music library in Itunes
You have to keep all the songs that you want on your iPod on your computer, otherwise you will get this problem. So if you want song "a" on your iPod it must also be in your iTunes library at all times unless you don't want it on your iPod anymore
SOURCE: My 120 GB I pod classic Doesn't play the next song
Hi.
Check that when you plug your iPod in that it isn't selected to "Shuffle," play which can happen if you are expecting to go through songs. There is also another reason and one I didnt know about until I took my iPod Classic back to my retailer thinking there was a problem;
If the songs on your iTunes or default device isn't an AAC file the iPod will fail to play it. On MAC systems simply click the file that you want to put onto your iPod, right click and scroll to "Get Info." If the file doesn't say it is an AAC file it won't play on your iPod. Scroll further down on the list to "Create AAC version." This takes milliseconds, doesn't affect the sound quality but condenses the data fit for the iPod Classic. Once that's done you can add any song you like.
Generally when you put a CD into a MAC it will automatically change the AIFF files into AAC which means you don't need to manually convert. AAC is usually needed when individual tracks are called up and put onto your iPod. I hope this helps you - it drove me nuts until I found out about the AAC.
SOURCE: unable to play songs on ipod-nano 4GB
You need to restore the ipod, Please refer to the manual or itunes help.
SOURCE: Cant delete songs off my ipod
Two possible solutions:
Solution 1. Go to iTunes, go to Edit, Select All, go to Edit once again, select Delete. This will clear your whole music library. Connect you iPod and let it sync. It will delete everything in your iPod. The problem with this is that it will delete all your music in iTunes as well so you better back it up elsewhere.
Solution 2. Go to iTunes, connect your iPod, let it sync. Do not disconnect your iPod. On the left hand side of the screen you will see "Library", "Store", "Devices", etc. Go to "Devices" and you will see your iPod's name there. Click on it and you will see on the right hand side of your screen your iPod, with some menus tabs. On the first tab (Summary), make sure that "Sync only checked songs" is activated. Then go to the second tab ("Music"). Make sure "Sync music" is activated and "Selected playlists" is also activated. Make sure NONE of the playlists is activated. At the bottom right hand side of the scree there is a button that says "Sync". Press it and it will sync no songs into your iPod. That should clear the songs but leave the contents in iTunes intact. If you want to put some playlists in your iPod, then check only those and only those will be added to your iPod.
Hope this helps.
