Question about ASUS WL-500g Premium Router
Admin interface I cannot connect to the web admin interface any longer
  • nazman Oct 17, 2007
    I am getting an ip address but it is my public IP and it is not getting nat'd for whatever reason.  If I switch off and on it is still the same.
    If I unplug my cable modem ethernet cable from the wan port I get 169.... address after doing a renew.
    Anybody had this before?
  • 32 Answers
The 169.xx.xx.xx address is the internal ip address. If that is what you are getting, then the router is sending the link state advertisement but not offering any addresses for use or validation. Now, try the following for me:
Connect an ethernet cable from LAN port 1 on the router to your computer.
Set your PC's ethernet port to address 192.168.1.2 / 255.255.255.0 and your default gateway to 192.168.1.1.
Unplug the power to the router and plug it back in.
Open a browser and type in 192.168.1.1 and hit enter.
This should bring you to the point where you can reset factory default and such, and hopefully get things working again. If it doesn't work, we can try something else. Remember, if it is still under warranty get ASUS to replace it. If not, we can try other methods to revive your router.
Posted on Dec 23, 2007
That means the router is not giving an  ip address already it might require hard reset and if still not giving an ip aside from 169....then it means router is busted and is just acting as a pass thru now.
169.254 ..... is an ip that computer will generate if the device where its plugged into is not giving an ip address.
Posted on Oct 19, 2007
  • 49 Answers
Make sure that you have still a valid ip address on command prompt. Go to start - click run - type cmd (open box) - click ok - type ipconfig after the cursor - hit enter and check ip address. If you are getting an ip address of 0.0.0.0 or ip starting with 169.254....then that is the reason. Unplug and replug router to regain the ip. also check firewall and proxy server. they should be disabled
Posted on Oct 15, 2007
Forgot ip address and password
To re-enable the Console access requires the SW2900 series to be reset to its default settings via the WEB INTERFACE
- Web Interface
- Device >Configuration >Initialize To change the Default User "ADMIN" password it is necessary to use the Console connection
-Console Interface
-Once the unit has successfully booted and the prompt presented
-Enter "password" (without "")
-Enter "admin" when the system prompts for User
-Press the "Enter" key when the system prompts for "Old Password" (the ADMIN password was reset by the Web Interface commands)
-Enter "" when the system prompts for the New Password (where "" is the new product ADMIN password)
-Enter "" when the system prompts to confirm the New Password In order to complete the configuration it is necessary to save the configuration via the WEB INTERFACE
-Web Interface
-Device > Configuration > Save
Symptom:
SW2900 Baseline Switch - Default console access disabled following password change
From the web interface, the default user "admin" password is changed and console access is disabled
Cause:
When applying the new password, by default the service-type is set to "telnet". When applied, the default "terminal" setting is removed thus disabling console access.
Apr 20, 2013 | 3Com Baseline Switch 2924-SFP Plus
How can I reset the passwork on my LG 32LD400 TV?
If you have access to the web admin interface...
All passwords can be changed in the User list (Share -> User). Click the User ID to change the password. Due to security reasons, passwords can only be changed in the web admin interface. If you forget the admin password, the password can only be reset by a service technician.
You can re-initalize the device (per instructions in the manual), but it will erase all data.
more...
Apr 15, 2012 | Lg M3703c-ba - 37 Lcd Flat Panel Display...
Put a password on tv and forgot ... is there a way of erasing the code?
Hate to have to tell you but....
Due to security reasons, passwords can only be changed in the web admin interface. If you forget the admin password, the NAS would have to be reset by a service technician.
Quote from there website.
Good Luck. I would just give them a call.
Mar 01, 2011 | LG 32LG30 32 in. LCD HDTV
I have moved address and taken my router with me but no longer have the software cd for it and cannot find a way to get my wireless set up
Hard reset your wireless router and connect it with your laptop/desktop lan port through patch cord. Look there it is connected or not. If connected then check the default gateway ip address and put it in your web browser and press enter to open the router terminal. Most routers username/password is admin/admin or admin/****(blank) or ****(blank)/admin or admin/password.
Hope it works.Then you setup your wireless router as before as you done.
Feb 10, 2011 | Computers & Internet
How do I secure my wireless internet? I just got a new laptop and I need to secure the wireless connection before I start using it. I have a Linksys wireless-g 2.4 GHz broadband router and I never secured...
your router has a driver cd..try to run it and set up it again in the installation process you will be prompt to insert security for your wireless lan...create your passsword and your wi-fi will be secured...
just remember your your password so that you can connect to it...
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
Need to configure for wirless setupnew dsl line from one isp to another need to set up router for wireless connection
If you are setting up a new router for DSL connection, i presume that you already know the login credentials to access your router's admin interface. By default, depending on your router's model, you can access and configure it at http://192.168.1.1 or http://192.168.0.1 using a web browser and make sure that computer you are using is connected to the router through an ethernet cable.
Default login credentials:
user name: admin
password: admin (or try also leaving it blank)
When you are at the web interface, go to a link known as SETUP and there you can setup your connection. If your DSL provides you a user name and password, then you can also enter them there. Then save your settings.
To allow internet broadcasting using wifi, go to a link known as "WIRELESS" and setup encryption there using WAP, WPA2, or WEP or any other recommended encryption protocol. Through this, you can prevent other users near your place to use your internet connection without informing you.
Feb 04, 2010 | Computers & Internet
How to reset security key
You need to visit your router's web interface at http://192.168.1.1 or http://192.168.0.1 (whichever works with your router)
If you are prompted with the password, then use these defaults:
user name = admin
password = <leave blank>
OR
user name = admin
password = admin
OR
user name = <blank>
password = admin
Nov 19, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Unable to connect cable/DSL router with my new att dsl service.
access web interface configuration page http://192.168.1.1 user: admin password admin (this is by default). Go to basic settings. look for MAC clone. click this. power cycle modem and router.
Aug 08, 2009 | Linksys EtherFast Cable/DSL Router
HP 1022nw default web access
try
username: admin, sysadmin, sysadm, administrator
password: admin, blank, sysadmin, sysadm
Feb 17, 2009 | HP LaserJet 1022nw Printer
ASUS WL-500g Premium Router Logo
338 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
