Tuner not picking up cable input (from vcr not cable box). Menu is limited to 2 options. How to unlock?
SOURCE: OSD locked Hisense PHD-4220
press menu, when osd locked appears press number 9 before osd locked disappears
SOURCE: close caption
You need to turn on closed captions through the menu of your PVR. To have it on all the time, turn the box off, press menu on the front of the box, and scroll down to captions.
This should fix the problem
SOURCE: DVD/VCR hook up to HDTV. No audio on DVD or VCR, no video on VCR
When you use component audio, it may shut off the side a/v audio settings. Try restoring all defualts (any changes you have made will be lost by doing so) according to p. 32 of the manual:
Menu --> Setup --> Reset --> Yes
-Tha Mp3 Doctor
SOURCE: Lg hotel tv. t.v. button are locked out, only hotel remote works
Hold down the MENU button on the remote for approx 5 seconds. Then enter 1105 this will access the hidden hotel option on the LG tv so you can change whatever you like..
Cheers LITTLE DISH FITTER
SOURCE: hisense H32V77C password reset
I couldn't find it anywhere in the service manual but you can try calling there support line. default is 0000 if that helps anyPhone: 1-678-318-9074
Fax: 1-678-318-9079
All buttons on TV are unresponsive - remote control only. Only options in menu are sound balance and closed captioning.
I am having the same exact problem
Hotel code is 0532 but u go to Menu then sound then balance make sure balances on zero then you enter 548 it will put you in a hotel settings
