When volume is down and on its highest makes buzzing noise i tried everything pls hlp
Is it connected to a computer or tv, if its computer, check all your equalisers, turn them off would be the best start, if not try sound effects on your computer, it has many different ones like bath room, parking lot all sorts of random ****, anyways turn that off and if you still have a problem message me back. As far as tv goes, try and conect to a different tv, no change? try a different rca cord, could be a shity one. hope this helps.
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
one of my small speakers makes a fairly loud static sound and the sub-woofer makes a deep lower static sound. I have tried to reset the speakers by checking all the connections and unplugging the sound system. Any help would be appreciated.
i have logitech speakers conected to a hi fi and make a small amount of sound and buzz wery loudly
