Question about ASUS M3000N Notebook
Don't have the M3000 hard drive caddy - ASUS M3000N Notebook
  • leimichaelwa May 13, 2009
    yes I need to know where to buy the hard drive and caddy for the M3000
  • Frank Zhang
    Frank Zhang May 11, 2010
    you want to know how and where can buy it right?
  • 191 Answers
You can buy from here:
http://www.alphapcstore.com/asm3pa.html
add: m3000=a3000 HD candy
hope this help you
Posted on May 13, 2009
  • Frank Zhang
    Frank Zhang May 14, 2009
    is this help you? please rating me thanks!
How to remove hard drive from fujitsu n6000
On the bottom of your Fujitsu N6000 laptop, find the hard drive door to access the hard drive.
2. Remove the Screws.
3. In this step, you will either need to pry out your Fujitsu N6000 hard drive caddy, or simply remove the door.
4. Once the Fujitsu N6000 hard drive is removed the laptop, you need to remove the hard drive caddy. There are usually four screws to remove from the caddy.
5. Simply Insert the new hard drive into the caddy. Place the screws back in. Install your new Fujitsu N6000 hard drive.
Good Luck
Aug 31, 2014 | Computers & Internet
Remove a hard drive
Depending upon your model laptop, the hard drive may be located behind a panel on the bottom of the laptop or it may be located on the side of the laptop and the retaining screw/s will be on the bottom of the laptop.
When you remove the panel the hard drive will be screwed to a hard drive caddy. Remove the screws on the caddy to release the hard drive. Keep these screws as you will need them to fix the hard drive to the caddy.
Feb 11, 2012 | Sony Computers & Internet
My hardrive is less than a year old and it will not power on. I tried a different cable and outlet. What is the problem and can i fix it?
It may not be the hard drive it self, it may be the caddy the drive is in. The best way to check if it is the hard drive is try the hard drive in another caddy, or plug it in to the computer without it being in the caddy itself using the PSU and SATA or IDE cables.
May 07, 2011 | Iomega (H0815VCA) 2 TB USB 2.0 Hard Drive
Hello, I formatted the M3000 with Ubuntu Linux, and... i'm stupid
Take your Sanyo back to Linux box, hook up the USB cable, and then mount it.
Copy the files that you want to keep on to the $HOME directory on Linux.
Next, from a terminal, run
sudo fdisk -l
to display all the mounted filesystems on the computer.
It might be /dev/sdb1, or /dev/sdc1 You should be able to pick out the M3000 as its hard disk size is 6.0 GB. Let's assume that the USB drive is on /dev/sdb1
Re-run the fdisk command.
sudo fdisk /dev/sdb
(press m to get the help menu).
Recommend that you choose d to delete a partition,
then n to create a new partition
when asked about the code for the new partition, use b -- this corresponds to Windows 95 FAT32 file system.
Don't forget w to write the new partition definition out to the USB drive.
Lastly q to quit fdisk.
Once you exit fdisk, remount the M3000 and make sure that you copy your files back on to it.
All Linux and Windows systems should be able to recognize your drive now.
Mar 16, 2010 | Sanyo HDP-M3000 MP3 Player
Specifically where is the hard drive for the toughbook cf- 27 - i've looked all over
Flip the laptop over and slide the 2 tabs that are near the carry handle to the unlocked position. This will allow the metal cover on the underside of the laptop to hinge up and be removed.
With the laptop upside down and the carry handle facing you, you should see the battery on the left of the laptop. On the right, there is a silver case about 4 inches long and 2.5 inches wide. This is the hard drive caddy.
To remove /this/ part, carefully push the connecting cable towards the battery until it smoothly disconnects from the hard drive caddy. Remove the caddy from the laptop. Using a small phillips screwdriver, remove the 3 small screws which hold the top of the caddy on. Remove the top, and you will see the hard drive.
As a note - be sure you do not remove the gel lining. This is 99.9% of the hard drive's shock protection. When you remove the hard drive, the cable should come out of the caddy as well. Put the new cable on a new hard drive (HDD must be smaller than 65,536MB), put the new hard drive into the caddy with cable attached, make sure the cable assembly is fitted into the caddy slot, replace the caddy cover, replace the screws, replace the caddy into the laptop. Then, make sure you connect the cable from the laptop PC board to the caddy cable assembly. Replace cover, turn on computer, and set up your Operating System (if needed).
Nov 10, 2009 | Panasonic Toughbook CF-27 Notebook
WANTED ERGO ELITE 300G HARD DRIVE CADDY
Hi there.
You will be able to purchase a hard drive enclosure/caddy from ebay or amazon.
Good luck and thanks for using FixYa!!
Apr 09, 2009 | Computers & Internet
Hi, i buy used laptop L355D-S7815 without hard disk i put a new 1 work fine but i don`t know if must have a caddy or something else because feel like is loose please help. thanks.
Some laptops need a caddy, but if the hard drive can fit in without a caddy then don't worry about it. If the drive is a bit loose then wrap or add some paper around the hard drive to stop it moving about.
Apr 02, 2009 | Computers & Internet
Hard Disk upgrade
Figured this out...
1)  Flip laptop over, keep front of laptop closest to you and hinges away from you 2)  Remove cover with cylinder/harddrive icon (2 screws) 3)  Remove small single silver screw near the front (close to you) of the laptop in the center of the metal harddrive caddy (the caddy may hold one or two hard drives) 4)  Pull the plastic tab on the left toward the outside of the laptop... the whole caddy with harddrive(s) inside will shift to the left, disconnecting it from the motherboard and lining up the caddy for removal. 5)  Lift the entire bracket straight up
To remove the primary harddrive (the only one present in my model) you must remove the blue L-shaped circuit board from the caddy. 1)  Flip the caddy over 2)  Remove the three screws with slightly larger head diameters around the perimiter of the caddy 3)  Push/slide/jiggle the circuit board so the sata connectors release from the hard drive(s). 4)  Unscrew the hard drive from the caddy
Aug 25, 2008 | Acer Aspire 7720 Notebook
Hard drive
If you can find another working 6L300RO, you can try swapping the logic board from the working drive onto the dead one. Try this if all you want is to recover the data from the dead drive.
Jan 15, 2008 | Maxtor / DiamondMax 10 / 80GB / 7200 / 8MB...
Hard drive
It is possible, maybe. I've done similar and only blew a surface mounted diode on the drive's circuit board. I located a blown drive and took that diode from it, soldered it to the one I blew and it worked.
So yes, if you can do similar to what I've described above.
I have to tell you though, that's a longshot.
**Please repost a comment before giving a rating other than Solved.
Oct 06, 2007 | Maxtor / DiamondMax 10 / 80GB / 7200 / 8MB...
Computers & Internet Logo
242 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
