Question about Tomtom ONE XL GPS
Tomtom one xl has a red cross across the sd card when i turn it on
  • 515 Answers
4 Suggested Answers
  • 58 Answers
SOURCE: When I switch on my TomTom, SD card has a red cross?
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you update.
Posted on Jun 14, 2009
  • 12 Answers
SOURCE: my tomtom one has a
Some people have said to pull the SD card out and turn on the unit and then press the restart button in for 10 seconds. Once it has restarted put the SD card back in and turn it on again. Hope it works for you mate.
Posted on Jan 21, 2009
  • 58 Answers
SOURCE: When I turn on there is only a cross over the SD card.
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you updat.
My tom tom one when i swith on the screen shows the sd card being removed from tom tom with a red cross across sd card.the sd card is in side .i can not past this screen or use gps how do i fix thanks
It is likely that the SD card (data) is corrupted. I'm assuming that it had previously worked properly.
Have you tried running a (fix) disk utility against your (internal disk or SD card) storage for the GPS ?
For instance, connect the GPS to your PC (Windows), and select (highlight) the (internal) "disk" on the GPS device. Under File - Properties, go to the Tools (tab) and run the "Error-Checking" option.
This utility may fix your data error.
If not, consider doing a restore (from backup) of your GPS disk storage.
Mar 24, 2013 | Tomtom One XL GPS Receiver
My tomtom fell on the floor and i get aflashing red and white cross. How do i correct this and get my device working again?
Internal memory was damaged when dropped.. OR the SD card if it has one. Replace the sd card and copy data over from back up
Feb 23, 2013 | Tomtom ONE XL GB Car GPS Receiver
Sorry wrong Question.......I'm really frustrated right now. I have a TOMtom XL 30 Series that will now show nothing but a Big Red X when I plug it into my Truck.....HELP !!!!!
It is quite common tomtom bug.
Do: 1. backup restore or 2. copy all original SD files to your new formated SD card. Restart TomTom and see if it works.
Sep 28, 2011 | Tomtom One XL GPS Receiver
The tomtom X-l doesnot start anymore. It shows the card taken out of the themtom with a red cross over it
If the sd card is in the tomtom then it has become corrupted, have you tried reading the sd card on a pc using a card reader?
Feb 24, 2011 | Tomtom ONE XL GPS
TomTom will not boot up.
Your sd card doesn't match with your device. It can cause device memory demage later. Change or don't use recent sd.
Jun 22, 2010 | Tomtom ONE XL GPS
My tomtom 1 xl is giving me a memory card symbol on the screen with a red cross over it !
do you have an sd card loaded?
if so and it hasnt been formatted for the tom tom then this can cause your issue, also if there has been an sd card in the device and then removed unexpectedly you will get the same issue.
hopefully this answers your query if so please rate my answer accordingly.
Thanks
Sep 14, 2009 | Tomtom One XL GPS Receiver
Jun 14, 2009 | Tomtom One XL GPS Receiver
Jun 13, 2009 | Tomtom One XL GPS Receiver
Red cross across sd card
It sounds like you need to reformat the card to get it working again but you will LOSE ALL THE DATA on it if you do that.
BE SURE before you do this. Find someone who can help you do this to make sure you reformat the right memory device.
Peter
Feb 18, 2009 | Tomtom ONE GPS Receiver
My tomtom one has a red cross across sd card when i turn it on
no that will not work see pullin the sd card out of the tomtom kinda pisses off the application if u have the red x error first do the soft reset if that does not work then update ur tomtom an application should pull thru as a download if not dont fret on tomtom home go to show contents on my one then delete just the application and i mean just the application then go back and hit update my one it will download and install new app and boom baby all done
Jan 20, 2009 | Tomtom ONE GPS Receiver
Tomtom ONE XL GPS Logo
641 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
