Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Windtunnel U6425-900 It seems the vacuum gets stuck in the carpet when the front dips and sucks up the carpet.
    Problem Solver:
Re: Windtunnel U6425-900
I think I may have the solution to all these same problems: If you buy a new front brush this might solve your problems, because the brushes have worn down and causing the vacuum to **** stronger because it is closer to the carpet. I hacve the same problem and I am going to see how much it would cost to buy a brush roller. If it works I'll let ya all know.
Posted on Feb 01, 2009
  • 101 Answers
Have you tried raising the 'carpet level' adjustment?
Posted on Oct 15, 2007
0 characters
3 Points
The carpet attachment is turning but not sucking.
Check the clips that attach the hose to the front of the Rainbow. If one is broken, then it will leak air and reduce performance.
Apr 22, 2012 | Rainbow E series Canister Wet/Dry Vacuum
It seems when i am vacuuming it is very hard it move and the brushes does not rotate after the rug strings got into it.
Your belt is stretched or worn and therefore cannot turn against the resistance of the carpet. If you replace the belt it will fix the problem. You can get the belt you need here:
Oct 24, 2009 | Hoover U6630-900 WindTunnel Bagless...
Dirt not moving through vacuum.
can you disconnect the hose completely ,if so then take it to the sink or outside and blow through it if you can blow then the clogg is further down.there should be a hose the base coming up the bottom backsi21pdenit will be sort of a clear hose.disconect that and take a coat hanger wqith the tip bt so it is rounded,thats so you don't cut a hole in the tub work its way down imto the clear tub\r
Apr 23, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Sensor wont go to green
Try cleaning the dirt sensor. It's usually located where the bag connects to the vacuum. Take the bag off and clean the inside of the tube that goes into the bag with a damp cloth.
Jan 11, 2009 | Hoover U5450-900 Windtunnel Supreme Bagged...
Height adjustment on Hoover Windtunnel u5755-900 no longer works
On this model it is only a single slide adjustment lever. have you trie to tilt the vac backwards (lifting the wieght off the front wheels) and then slide the adjustment lever?
If there is a mechanical issue with it. take the bottom plate and roller out, and then the 2 small screws which hold the cover on underneath. you should be able to see the problem from there
Jan 10, 2009 | Hoover Vacuums
Hoover Windtunnel carpet level adjustment
The suction is so great that it sucks up your carpet, then nothing works. I get my children to stand on the corners/edges of the rug so that it stays perfectly flat on the floor while I vacuum. Or, you can turn off the brush roller (set it to "hard floor" setting). Or, tip the vacuum cleaner's front up slightly while vacuuming, to reduce suction.
Oct 28, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Brush Roll belt won't engage on WindTunnel self-propelled
When you had the brush roll off, did the ends turn freely? If not then the brush won't turn and the belt will just slip. You would have to replace the brush roll if either of the ends are frozen. Other then that you would have to remove the top cover to see if there any broken parts, there is a spring loaded asm, it has a black wheel that will push the V belt when it is in the carpet setting and the handle is in the down position, it could be jammed so the roller is stuck.
Jul 16, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Dog hair from vacuum is being laid back onto carpet
my plush carpet and dog hair do not go together! I realized with this particular model and in my environment, the bag fills in one vacuuming! I literally dug out all the dirt I could by taking it apart and then changing the bag. Voila!
Mar 31, 2008 | Hoover WindTunnel Widepath U5397 Vacuum
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
198 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
