Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Printer shows a paper jam when there does not appear to be one
I have followed the correct procedures but cannot use the printer for any function due to the above
  • robinburrow May 15, 2009
    Problem disappeared then came back! Anyone got any other suggestions?
  • robinburrow May 17, 2009
    Thanks Jim. A local supplier had reservations about vaccuming but I may do so if all else fails!
    Problem Solver:
  • 9 Answers
Often, even after you have removed the paper jam, one of the sensors can still report a "Paper Jam". These sensors look like small plastic "fingers" that project along paper path. More sophisticated printers may have an "electric eye" mechanism. Sometimes when you get a bad jam, the paper has to be ripped out, and a very small piece can get caught on one of the sensors or block the electric eye type sensor. Remove the ink cartridges and shine a light into the machine and look for small pieces of paper stuck inside, and gently remove them. If one of the sensor fingers is bent or jammed, it can cause the same problem. See if any of these are stuck and gently free them. Take care, since they break off very easily. They may also break off if you forcibly pull out a jammed paper. If one of the sensors is broken, then you are out of luck, and will need to buy a new printer. you can also try vaccuming insides with one of those flat nozzles connnected to a regular vaccum cleaner.
Posted on May 13, 2009
  • WormJim May 17, 2009
    If the problem is intermittent, it still may be a sensor issue. If there is dust, preventing one of the sensors reseting, it may be indicating to the printer that there is still paper stuck in the paper path. Have you tired vaccuming inside?
    WormJim
  • 30 Answers
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
takio-25
Posted on Sep 04, 2009
"cover open" when the cover is closed! I just
You have a new printer and one with a defect. Since this is a brand new printer and after it is made sure that your installation procedure was done correctly, the fault can be due to a damaged door detectlimit switch.
Finally you remove the printer from the PC, open programs and uninstall the drivers. Now restart and install the drivers, connect the printer ONLY WHEN PROMPTED.
Now check the functions and if the fault has not cleared, you MUST report the matter to the dealer or the support site to get free replacement.
Oct 08, 2011 | Canon Pixma MX410 All-In-One Printer
I have a nvram error,950.31 after system board change on a t640.
950.30 through 950.60 EPROM mismatch failure
Warning: When replacing any one of the following components:
• Operator panel assembly (or upper front cover)
• System board assembly
• Interconnect card assembly
Only replace one component at a time. Replace the required component and perform a POR before replacing a
second component listed above. If this procedure is not followed, the printer will be rendered inoperable. Never
replace two or more of the components listed above without a POR after installing each one or the printer will be
Warning: Never install and remove components listed above as a method of troubleshooting components.
Once a component has been installed in a printer, it can not be used in another printer. It must be
returned to the manufacturer.
Note: Before proceeding with this service check, make sure you have the correct system board installed in the printer. The system board has a label with an board ID and barcode.
Replace the original system board with a new and not previously
installed system board. If the problem remains, contact the next level
of support.
Jun 30, 2011 | Lexmark T640 Laser Printer
Canon IP2600 Ink absorber replaced and i am still get the error message. I have been told that the count needs to be reset. this is done with a button sequence on the printer. Does anyone have this...
Try these:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The LED lights in
green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
4) When the LED lights in green, press the Resume/Cancel button the specified number of time(s) according to the function listed in the table below. (Each time
the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes,
the printer returns to the menu selection mode automatically.)
Function Procedures Remarks
Service test print
- Model name
- ROM version
- USB serial number
- Waste ink amount
- CD-R sensor correction
See "Service mode operation procedures" below. Set a sheet of A4- , letter-, or larger-sized paper.
For print sample, see 3-4. Verification Items, (1) Service
test print, <Service test print sample>.
EEPROM initialization See "Service mode operation procedures" below. The following items are NOT initialized:
- USB serial number
- Destination settings
- Waste ink counter
- CD-R correction value
Waste ink counter reset See "Service mode operation procedures" below. If the waste ink amount is 7% or more, replace the bottom
case unit, or the ink absorbers.
Destination settings See "Service mode operation procedures" below. Other than Japan: iP4000
Japan: iP4100
Time(s) LED Function Remarks
0 times Green Power off When the print head is not installed, the carriage returns and locks
in the home position.
1 time Orange Service test print See 3-4. Verification Items, (1) Service test print.
2 times Green EEPROM information print See 3-4. Verification Items, (2) EEPROM information print.
3 times Orange EEPROM initialization
4 times Green Waste ink counter resetting
5 times Orange Destination settings Proceed to the step 5), and follow the Destination settings
procedures.
6 times Green Print head deep cleaning
7 times Green CD-R test print Not used in servicing.
8 times Orange CD-R print position correction
(horizontal) Not used in servicing.
9 times Green CD-R print position correction
(vertical) Not used in servicing.
Hope that helps!
Jan 10, 2011 | Canon Pixma iP2600 Photo InkJet Printer
No print. white paper coming
Hi, i will give you answer common to all copiers since you did not specify the model number but if you find it inadequate, please specify the exact model number of your machine. This problem can occur due to the following;
  • Check corona wire that they are intact.
  • Check there is toner or developer in the copier and no gear broken.
  • Check that the drum is rotating.
  • Check that the HT board is okay or disconnected.
Do the above procedure and test every time you do each procedure and stop where it work.
Bye.
Nov 24, 2010 | Canon Office Equipment & Supplies
Scanner function does not appear to work. All
i would say possibly you are missing out on something..because if the other functions particularly photocopying are working then this should work..as in if the photocopying function works then the scanner is ok cause basically in photocopying the machine scans then prints... perhaps check whether you are correctly following procedure to scan..most hp all in ones have a button on them that you press and it automatically initiates scanning and simultaneously the software on the pc is initiated..try this,if not then try reinstalling the hp software..hope this helps..regards
Jun 04, 2010 | HP Photosmart 2575 All-In-One Printer,...
Hp color laser jet printer is displaying error 59.co on the display pannel
Developing disengaging motor error
. Run the component test to verify that
the print developing disengaging
motor is working correctly.
. Reconnect the connectors J468 and
J1020 between the developing
disengaging motor and the DC
controller PCB.
. if motor is not rotating Replace the developing disengaging
motor.
or
problem due to cairtage leaver lock cairtages not engage properly i hv found max problem of this leaver it found damaged due to improper opening the doorpls follow above steps if problem not resolved then call hp engr for 4th step
May 14, 2010 | HP LaserJet 4700 Printer
We have a Samsung Digital Home Theater System HT-DM150. After some guests were fiddling with the remote, we find that we cannot eject a DVD that was inserted. The DVD plays OK, but when we try to eject,...
Samsung Home Theater Systems have a Dealer Lock or Tray Lock Function that prevents the disc tray from being opened.
There are four procedures for turning off the Dealer Lock function. Try one, then the other, to see which works on your system.
Unlocking Procedure 1 To turn off the Dealer Lock function, follow these steps:
  1. Turn on your Home Theater System.
  2. Press the Stop button on the front panel and the Power button on the remote control simultaneously for four seconds.
Note: Repeating the two steps above turns the dealer lock on again.
Unlocking Procedure 2 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Function button on the front panel for 3 seconds. The display shows the word Unlock.
Unlocking Procedure 3 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Open/Close button on the DVD player on the front panel for more than 4 seconds.
Note: Repeating the two steps above turns Dealer Lock on again.
Unlocking Procedure 4 To turn off the Dealer Lock function, follow these steps
  1. Using the HTS remote press the Menu button + 712, and the HTS will display CAN OPEN.
The Dealer Lock feature is mainly used by retailers to ensure that the display discs are not removed. However, parents of young children may find this feature very useful as well.
Jul 05, 2009 | Samsung Audio Players & Recorders
Display reads OPEN LOCK when I try to open dvd tray.
Jun 26, 2009 | Samsung HT-DS610 System
Hp psc 1350 all-in-one
Source: HP support
( Click link above to read complete article and instructions )
Introduction A full feature software and driver package for Windows Vista is not available for your product. However, the Windows Vista operating system installed on your computer contains a basic driver solution for your product. With the basic driver, the buttons on the product do not function and some of the advanced product features are not available. But you can still print, scan, and import and view images on a memory card, using the workaround procedures in this document. Use the following instructions to install the basic driver in Windows Vista, and then review the workaround procedures to use the available features for your product. Installing the printer driver When you connect the product to the computer, Windows Vista detects the hardware and automatically installs the correct driver. A notification lets you know when installation begins and when it is complete. You do not have to download any software or insert the product CD.
  1. Turn the product on.
  2. Connect the Universal Serial Bus (USB) cable to the printer and to the computer.
  3. A Your devices are ready to use window might display on the screen. If the window displays and does not close automatically, close the window.
Workaround procedures The basic driver in Windows Vista is sufficient for several functions. You can print from a software program, scan documents, and import and view images on a memory card. Printing Use these steps to print from a software program.
  1. Open the document to be printed in the software application in which it was created.
  2. Click File , and then click Print .
Scanning Use one of the following three methods to scan a document. Method one: Scanning with Windows Photo Gallery
  1. Click the Windows (c01367391.gif ) icon.
Oct 06, 2008 | HP PSC 1350 All-In-One Thermal Printer
I am trying to find a way to be able to use my hp psc 2410 photosmart. om my new hp computer but i dont have a disk to load the printer to windows vista?
Source: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00808543&lc=en&dlc=en&cc=us&product=303753&os=2093&lang=en
Installing the Printer Driver Located in the Windows Vista Operating System s.gif s.gif
Workaround procedures The basic driver in Windows Vista is sufficient for several functions. You can print from a software program, scan documents, and import and view images on a memory card. ....you can read the rest at the link above
Hope this helped - remember to rate :)
Oct 02, 2008 | HP Office Equipment & Supplies
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
203 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
