Question about Homelite Mighty Lite Lawn Trimmer
Weed eater will start but the head will not rotate. its like some thing is not connected.
  • Anonymous May 25, 2009
    i have the same problem, but my weed eater is a McCullough brand
  • 246 Answers
Hello snap77b:
From your Description it Sounds like the Shaft May have Slipped Out of the Power Head and the Drive Cable is Not Engaged to the Drive, the Clutch is Worn Out, the Drive Cable is Worn and Requires Replacing, the Trimmer Head has Slipped and is Not Engaged to the Drive Cable or the Trimmer Head Gearbox is Bad and Requires Replacing.
>>Send me the Model Numbers Off the Unit, Please. With these I can Locate the Proper Manual and Better Assist you.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
When I turn my weed eater on it makes a loud noise what could the problem be?
will assume electric
fixable
would say bearing at the cutter head dry or worn out
when you turn the head to edger the load on that bearing is different
if noise is up in the motor same thing .. bearings
Oct 13, 2016 | Garden
How can I remove the cartridge head to clean?
Usually the cutting head will have a couple of plastic tabs you push in to release the spool cover and get access to the spool
Mar 06, 2016 | Garden
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    How do I remove the spoolhead so as to afix the pivotrim head
    I installed the Pivo trim head yesterday. The info that came with the unit will show you how to install it on ANY Weed Eater Unit. Also they have videos on their web site at: https://pivotrim.com/
    Look on the end of the shaft of your weed eater at the head. Mine was a 25cc Poulan/weed eater SST45 and it has a hole that you need to stick a HEX KEY in so the shaft does not move when you try to remove it. ALSO it has a BACKWARDS THREAD!!! So "Right is NOT Tight." Left is to tighten and turn towards the right to get the head to unscrew so you can put on the Pivotrim Head. Also you can use ANY Weed Eater line on the unit. As I tried several different lines and found different uses for different lines. Such as edging and trimming against fences. Best after Market Weed Eater head I have EVER used. :-)
    Enjoy! :-D
    Jul 28, 2011 | Craftsman 25cc Gas Line Trimmer
    Mcculloch trimmac 250sl the spool at the end of the grass trimmer does not spin although everything else works fine. I think it's the angle gear that's broken but I don't know how to get to it....
    on top of the head there is a star shaped bolt(middle of the head), remove bolt and rotate the spool you should see the gear turn, to remove the head from the shaft remove bolt/screw on the side of the shaft towards the top of the head, remove head and inspect the shaft, this should rotate when you pull to start the weed eater, if it does not then you will need to remove the top portion of the weed eater and inspect to see if the shaft is broken or not seeded inside the motor. Hope this helped Tim
    Jun 07, 2011 | Garden
    Ryobi weed eater head won't spin
    Sounds like the clutch has taken a long trip south. If the clutch pads are not wore out, try some wd40 on the pad hinges.
    Apr 27, 2010 | Ryobi Garden
    Troy Bilt 4 cycle weed eater - trimmer head doesn't spin
    rotate attatchment head slightly while inserting driveshaft
    Jul 30, 2009 | Garden
    Tryingto replace my troy built weed eater's head
    Replacement head can be purchased from amazon, here Amazon com troy built head. I hope this helped you. Have a nice day. Vince
    Jul 12, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
    Need to add new string to a weed eater xt 12
      For manual go to;
      http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
      Preparation Instructions
    1. Press the lock and rotate the spool counter-clockwise.
    2. Remove the locking ring if your weed eater has one.
    3. Take off the automatic feed button.
    4. Wipe away any debris.
    5. Push down on the spool to release the locking tabs.
    6. Remove the spool from the chamber. Restringing the Weed Eater
    7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
    8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
    9. Secure each of the lines into its own upper and lower deck grove settings.
    10. Install the spool back into its chamber.
    11. Pass the lines into the left and right holes and snap the spool into place.
    12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
    13. Reinstall the locking ring if necessary.
    Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
    Jun 01, 2009 | Garden
    Screw cap to reel head of ryobi ss30 weed eater will not come off
    The spool retainer nut loosens when you turn it clockwise . The opposite of " normal ".
    Apr 05, 2009 | Garden
    Homelite Mighty Lite Lawn Trimmer  Logo
    369 people viewed this question
    Top Homelite Garden Experts
    roeb
    Roland W VanLue
    Roland W VanLue
    Mike Squire
    Are you a Homelite Garden Expert? Answer questions, earn points and help others
