Try this link to download it. http://www.chsinteractive.co.uk/electrical-components/misc/17wlt46b-pcb-main-17mb16-1-toshiba.htm If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
SOURCE: NO Signal on TV but Foxtel works
I am assuming that you have confirmed that your Foxtel works in another TV but not with the Toshiba 37WLT66A and that you are using a single feed from the cable provider and split into two (or more). Additionally, this is a standard cable connection.
If the unit is new, then perhaps it is a matter of programming the Channels using Cable not Std or Air in the menu. If the Toshiba has been used before in the same setup, then possibilities are:
1. cable/connector leading to the Toshiba;
2. splitter or distribution amplifier (if present);
3. worst case scenario, tuner block of the Toshiba.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
