Question about Vantec 1 Bay NexStar 3 USB 2.0 External Drive Case
Cant delete files from my NexStar.3 - Vantec 1 Bay NexStar 3 USB 2.0 External Drive Case
Cant delete or add new files to my NexStar.3, I have it connected to a MacBook Pro
If you can SEE the drive on your desktop but cannot modify it's contents there is a good chance it is formatted as NTFS which is a Microsoft Windows format. Mac's can only read/copy information from these drives and not write/delete/modify them. You have 2 choices, you can erase the drive and reformat it as Mac OS Extended (Journaled) (Mac/Linux only) or you can format it as MS-DOS (FAT32) which is truly cross platform but slower to read and write to from a Mac. To reformat the drive you use Apple's "Disk Utility" program in your utility folder.
Dec 13, 2013 | Vantec Nexstar-3 External HD Enclosure...
Vantec Nexstar 3 driver download
Vantec Nexstar 3 drivers can be found at driverupdate us.Take a look, and enjoy
Apr 04, 2010 | Vantec NexStar-3 External 3.5inch...
Windows 7 NexStar drivers and installation needed
No device-drivers are needed. Just connect this USB device, and Windows will recognize it. If there is a "one-touch-backup" button, it won't work, but you can still use drag-and-drop to copy files from your internal disk-drive to this external disk-drive.
Jan 01, 2010 | Vantec NexStar-3 External 3.5inch...
315 GB space available but can't add more data
Are the files that are on the drive all on the root C:\(or whatever letter it's using) or are they organized into folders such as Pictures/music/documents?
Second, what file format is the drive FAT32/NTFS(to find out right click on the drive in My Computer, left-click properties and in the window that pops up near the top you will see file system: _____
Answer back with that info and I will see what I can do to help you.
Chris
May 08, 2009 | Vantec NexStar-3 External 3.5inch...
Files disappearing on external hard-drive (nexstar.3)
In this case you should use data recovery software to try recovering the files and data, provided those lost data are not fully overwrtten.
Be careful: Before your files are recovered, do not attempt to save more files to the external in case the original files are overwritten.
Feb 21, 2009 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Cannot read/write
Try both moving it to different computers and reinstalling drivers.
Feb 14, 2009 | Vantec 1 Bay NexStar 3 USB 2.0 External...
NexStar hard drive doesn't recognize its size
It may be crashed....use [Nucleus Kernel for FAT and NTFS ] software...
Oct 11, 2008 | Vantec NexStar-3 External 3.5inch...
My hard drive giving me problem
1st - Right click the drive icon, i think you will find Autorun at First, if it is..
2nd - Right lick and press explore
Before that you have to enable Show Hidden files and Folders in Tools Menu, Folder Options.
3rd - You will find some files, that is like command prompt icon and Autorun icon.
4th - Delete both the files and reboot the computer..
The problem is solved...
or use USB Disk Security V5.0.0.85 - www.freshwap.net and install.... it will delete the files...
Oct 03, 2008 | Vantec NexStar-3 External 3.5inch...
Celestron Nexstar 11 GPS Electrical problem
The Nexstar11GPS group on Yahoo.com.
http://tech.groups.yahoo.com/group/NexStarGPS/files/n11gpselectronics.zip
Nov 06, 2007 | Celestron NexStar 11 Telescope
Nexstar
Its normal, and is the signal showing the drive powering/spinning up and down. The drive spins at 7200 rpms, when you power it up or down, its switches onto the speed that best suits  what it's intended to do.
Oct 14, 2007 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Vantec 1 Bay NexStar 3 USB 2.0 External Drive Case Logo
113 people viewed this question
Top Vantec Computers & Internet Experts
Felizardo Erilla
Felizardo Erilla
Ekse
Are you a Vantec Computer and Internet Expert? Answer questions, earn points and help others
