Question about HP Pavilion Ze4805us Notebook
System error I have a Hp Pavilian ze4805. I tried to install i newer version of window and the program was to large for my system. I have a 32gb. So it wiped out alot of my important commands. I how can i reset my computer to its original settings. Also i cannot access my control panel. The system says it is domain? How do i reset so that i am the system administrator
  • 1,006 Answers
In safe ( I THINK WITH F5 OR F8 ) mode then u go to the SYSTEM ADMINISTRATOR
Posted on Oct 15, 2007
What is the procedure to install a 32-bit softwares in to my laptop(windows 7,home premium,64-bit) ?
Most programs designed for the 32-bit version of Windows will work on the 64-bit version of Windows. Notable exceptions are many antivirus programs.
Device drivers designed for 32-bit versions of Windows won't work on computers running a 64-bit version of Windows. If you're trying to install a printer or other device that only has 32-bit drivers available, it won't work correctly on a 64-bit version of Windows.
Windows 7 64bit does run programs that will run on windows 7 32bit, see here
How Windows 7 / Vista 64 Support 32 bit Applications
BUT not ALL 32bit programs will run on Windows 7!!! There are many programs that will run on Windows XP and before that will not run on Windows 7. IF you had Windows 7 Pro version (or upgrade) there is a program you can download from Microsoft that will simulate an XP environment to allow programs to run called "XP MODE".
Try to install the 32bit software first. If installation not succeed, it would be better if you first look into a newer version of the program you want to run.You have to consider that a newer version of your program might not be that much more expensive than upgrading to pro, and with the newer version, usually comes newer features.
Hope this help and if helpful RATE please.
Feb 17, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Can not install old version of paper port on 64 bit system
I am assuming you are using one of the newer version of windows, although you don't mention this. There is a free version of paperport you can download over the internet so you might like to try this. With windows you can install 32 bit versions of software onto 64 bit system and they will generally work fine. You should also try using "compatibility" mode which windows uses to help manage programs designed for older version of windows. I have some older software that wont work on anything other than windows XP so I have installed a virtual machine onto my 64 bit computer, then installed windows xp onto the virtual machine, and then installed the software I need to use. This is a bit tedious and time consuming but works perfectly and allows me to use my older software.
Jun 20, 2017 | Brother DCP-9000 Copier
Have Windows 7 Home Premium (64-bit)on a new HP laptop computer. Am trying to install PrintMaster Gold 2.0. I get error messages when it is nearly installed. Broderbund told me it is compatible with...
Not compatible or not working well with windows 7?
(make your program/application run with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Feb 11, 2010 | Broderbund PrintMaster Gold 16 for PC
I bought a new hp touchsmart computer, and i get
If you using operative system above Windows xp, it is not compatible. Se here :
They write compatible with : Windows Me / XP / 98 / 2000
you can try to upgrade your software to a newer version, try to ask the software provider, normally it is writed in the field About under the Help menu.
Hope that helps
Have a nice time over there
Please rate my answer
Nov 28, 2009 | Broderbund American Greetings Spiritual...
Failed Error During Installation. MSI.dot4wrp...Error Code 2753' Message Displays on the Computer in Windows XP and Vista
This is an internal installation error. There can be 2 solutions:---- Solution 1:-- Find all of the hpqwrg files and delete them before installing the software:
  1. Click Start .
  2. Click Search ( Find for Windows 98).
  3. Click Files and Folders .
  4. In the Named entry box, type hpqwrg .
  5. Set the Look In entry box to C: .
  6. Click Search Now ( Find Now for Windows 98).
  7. Click Edit , and scroll to Select All .
  8. Delete all files pertaining to hpqwrg . There will be approximately five to six files.
  9. Be sure to empty the recycle bin of these files also.Solution 2:---- Completely uninstall the higher version of software and reinstall the lower version first, follow the steps below in order:
    1. Uninstall all of the HP Photo and Imaging software (for both of the products). (The uninstall program can be found in theControl Panel in Add/Remove Programs ).
    2. Re-install the lower version of the software.
    3. Re-install the higher version of the software. Thank you Sir.
Sep 27, 2009 | HP OfficeJet J4580 All-In-One Laser...
Error Code: 2753 " Fatal Error or error MSI.dot4msi"
Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
The Windows services (files) were:
Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
1) Check to make sure that the 2 Windows services above are not running (or not installed).
2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
3) Run the installation again.
solution 2>
complete uninstall printer software from computer.
run uninstall L1 L2 L3 L4(if not an hp computer).
run same uninstall l1l2l3l4 from 7z..folder or hp folder from temp if availalbe.
then clean from add remove programs/program and features.
then clean from cleanup utility all hp pritner related entries.
then clean temp folder. clean recycle bin.
delete c:\program files\hp and hewlett packard folders (if not an hp computer). on hp computer delete digital imaging bin folders.
delete following folders from following locations-
C:\windows\System32\Spool\Printers and deleted entries inside it
C:\windows\System32\Spool\drivers\w32x86\*.* deleted entries inside it
cleanup from regsitry--
plz make back up for registry first.
>> hklm/system/current control set/control/print/environment/windowsNT(x86/64)/drivers + processors delete all pritner entries from there.
>> hklm/system/current control set/enum/usb/vid_000,vid_003 delete.
>> hklm/system/current control set/enum/usbprint delete pritner entries.
>> hklm/system/current control set/control/print/monitors/hp standard tcp/ip ports/ports.
>> hklm/system/current control set/control/print/monitors/standard tcp/ip ports/ports.
>> delete same ports from printers and faxes/pritners pritner properties ports
>> hklm/system/current control set/control/print/monitors/hpz..
>> hklm/system/current control set/control/print/providers/lan man settings.
>> hkey_Current_User\Software\Hewlett-Packard
>> hKey_Local_Machine\Software\Hewlett-Packard
>> HKEY_USERS\.DEFAULT\Software\Hewlett-Packard
>> hkey_current_user\software\hewlett packard delete if not hp computer.
>> hkey_curent_configuration/system/current control set/control/print/pritners.
then go to msconfig
make it selective startup disable all microsoft services except hp services. hide all microsoft services. disable all startup tab apply restart.
after restart install cue version 12 officejet pro 8500 or 6500.
then run msiexec.exe /unregister then msiexec.exe /regserver cmd commands.
then install software from downloaded version of original pritner install only basic drivers first and imaging devices only and use solution center 12. cue 12.
issue resolved.
Jun 19, 2009 | HP LaserJet 3055 All-In-One Printer
Error code 0x80040702
Reinstall the game if problem stays repair ur operating system
May 17, 2009 | Microsoft Gears of War for Windows, Mac
Getting error 1628
Upgrade to Windows Installer version 2 or newer version. To do this, follow these steps:
1. Start Microsoft Internet Explorer, and then browse to the following Microsoft Web site:
2. In the left pane tree menu, click "Setup and System Administration", and then click "Setup".
3. Click "Windows Installer", and then click the appropriate link for your operating system.
4. Click "Download" to download and install Windows Installer version 2 or newer version.
May 13, 2009 | Brother MFC 420CN All-In-One InkJet...
Our email which is serviced by msn intrnet explorer has quit
some file in the system are corrupted probably by some mal-ware or some virus. do u have any anti-virus installed on your computer?
what i can suggest you is try accessing your e-mail from other browsers like Mozilla firefox or safari. or you can try reinstalling the internet explorer.
Mar 14, 2009 | Microsoft Windows XP Home Edition with...
Error code 103
Some vista doesn't work properly for updates or pc game. Try to install fresh installer for your game, maybe it works properly. The best use for OS windows xp 2.
Jun 17, 2008 | Microsoft Windows Vista Ultimate Edition
HP Pavilion Ze4805us Notebook Logo
37 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
