Question about Samsung SlimFit TX-S3082WH 30" TV
"NOT SUPPORTED MODE" when using my xbox 360
Ok, so I have always used my xbox 360 on the component 1 input of my samsung tx-s3082wh without a problem. then while I was playing a game, the entire screen looked as though there were a green filter applied to it. It was not part of the game. I turned off the xbox. Now when I turn on the xbox, the television says "not supported mode" in the same blue box that usually says "no signal or weak signal" when the xbox is off. Is it the tv or my xbox? I plan to try the xbox at a friends house asap. The television still receives HD cable service perfectly in both component 1 and 2. Please let me know what you think if you have any ideas. Thanks in advance.
  • Anonymous May 13, 2009
    i have the same problem...
    let me know how u fix it once u get it fix.
  • Anonymous May 16, 2009
    i have the same problem it just randomly happened while i was playing
If you got that while playing it sounds like its your GPU melting... when the older xbox360s get hot the circuit starts to warp and sag in the middle.. the causes the GPU to seperate from the board which gives you wierd or no graphics... ppl suggest "the towel trick" wrapping you xbox in a towel to overheat it in hopes it will reconnect the GPU.. otherwise there is very little you can do.. just hope MS will repair it for you or buy a new one.. i have the same problem at the moment with my friends old one.. so im currently working on a solution.. will try and let you guys know if i find something that works...
Posted on Jun 13, 2009
  • 11,896 Answers
Try the xbox in all inputs that the tv has. If still having problems, it may be a faulty cord from xbox. Also do try on another television.
Posted on May 13, 2009
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Dec 26, 2012 | Video Game Consoles & Games
How do I select the correct input when using Direct TV
See what the output is from the Direct TV box---if from the rear jacks it goes to the matching ones on the set. Coax to coax or more commonly component to component---rather straightforward.
Dec 04, 2012 | Samsung SlimFit TX-S3082WH 30" TV
I need to configure the settings on my Samsung TX-R2035 TV so i can play my Xbox 360 on it. I don't know what all these abbreviations are, though. Help?
If you use the yellow, red, white jacks, these are called RCA jacks.
The tv should have these. Some have two sets of these. Make sure yours are hooked up to input or a/v So run xbox cords to tv input or a/v jacks.
Then turn on your tv and turn it to input or a/v channel
Some tv remotes have an input button on them
If you have any other questions just ask.
May 16, 2011 | Samsung DynaFlat TX-R2035 TV
I am using my xbox 360 via HDMI, and I have a 5.1 surround sound system hooked up via RCA output from the tv. If I switch it onto the coax input it works, but when I switch to HDMI it doesnt. Is there a...
no, there's no firmware upgrade that you can do on the tv. the reason for that is because you are sending digital sound to the tv with hdmi from xbox 360,and when you have rca cables connecting your tv and surround sound, the rca cables provide stereo sound. what you need to do if you want to use hdmi is connect optical cable from tv orxbox 360/ or tv to your surround sound to get digital sound, and it will sound better digital sound.
Apr 17, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Samsung, xbox problem
Try to change the hdmi cable...
set your plasma hdmi input...
Good Luck
Dec 10, 2008 | Microsoft Xbox 360 Console
Xbox 360
Not sure how many and what type of outputs the xbox has, but it's always a good idea to try the other outputs. If you're using component out, try the DVI, or HDMI, or Composite. Also, most importantly make sure the TV is set to accept the input. Is it set to Input 1, Input 2 - this is usually labeled as Input or Video on the remote control.
Aug 28, 2008 | Microsoft Xbox 360 Console
TV won't accept monitor input
Try changing your computers resolution to something much lower. Mode Not Supported is usually an error regarding the Display Resolution of the video card being set higher than the monitor is capable of handling.
Aug 14, 2008 | Samsung SlimFit TX-S3082WH 30" TV
Component video inputs 1 and 2 look very fuzzy, but DVD component doesn't, 720P
Hello, I am sorry for your issue. The audio inputs should not matter. It sounds like those inputs do have a problem. Please contact Onkyo at 800-2291687 option #3 so that we can troubleshoot with you and provide options. Thank you, Onkyo USA
Jul 06, 2017 | Onkyo TX-SR304 Receiver
XBOX 360/SAMSUNG PLASMA TV
If you have an Xbox 360 Elite or a newer Xbox 360 Premium, you should use an HDMI cable if your TV supports it. Otherwise use a component cable.
Nov 25, 2007 | Microsoft Xbox 360 Console
Samsung SlimFit  TX-S3082WH 30" TV Logo
2,572 people viewed this question
Jerry Greenberg
Jerry Greenberg
