Question about Panasonic TH-50PX75U Plasma HDTV
Cannot control volume
I have sound but I have no volume control (up or down) from eitherĀ the reomote or from the TV front panel. Cannot change channels from either front panel or remote. The remote will only turn on/off the TV.
    Problem Solver:
  • 20 Answers
Dear Mbruce 1,
With set on press and hold the "Power and Action Buttons" on set, for about five seconds, set will turn off and then back on.
Please let us know!
Toprol
Posted on Nov 08, 2007
How do start up program for reomote to operate ty
The Google Fiber remote control is not designed to fully control external audio equipment. Although you can control basic functions like volume up and volume down, if you want the convenience of using one remote to control all of your devices (TV, Google Fiber TV Box, and audio equipment), you might consider purchasing a universal remote control, such as the Logitech Harmony remote.
Dec 04, 2015 | Televison & Video
TV not responding to any remote control
Main system control IC fault. Contact the authorized service center.
Sep 27, 2015 | Vizio VF550M 55 in. LCD HDTV
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
Seems like some type of control board problem. Remote will not work on tv, but works other devices. Manual controls are squirelly. Cannot change inputs. Can move to other inputs on menu but when I hit...
Thats a bad button on the front keypad of the tv . The remote does not work because the tv micro sees a button pressed all the time and never listens to the IR reciever . If you pull the front speaker grill off you will find connector ZF just below the keypad or just inside the access panel. If you do remove that panel don't touch anything else.Just follow the wires down from the keypad to connector ZF. Connector ZF is inline with the wires to the front keypad. Unplug it . Then remote will work like normal. Use it like that or have the front keypad buttons replaced.
Oct 21, 2009 | Mitsubishi WS-65809 65" Rear Projection...
We have a RCA tv. We've had issues with this set before where it wouldn't come on at all, which we've found out is a common problem for it and got it fixed. Now the volume won't go up and it won't even...
It sounds like you have a control panel problem. Switches go bad in these a lot. Try removing the top control panel and changing the switches. To remove the control panel, take the back off and look at the panel from the inside. You will see a tab that keeps the panel from sliding out of the front. push down on the tab slightly and slide the control panel out of the front. Take it to a repair shop and ask them if they have the individual switches as the whole board is no longer available. If not, remove the switches all together and leave the remote sensor. This will disable the control panel but the remote will still work. Good luck
Oct 19, 2009 | RCA F32650 32" TV
Front panel buttons on Philips rear projection do random things
Leaky tact switches on control panel. Part number is 242212802742. Takes 6. They will cost you around 6.00 a piece. Lower front panel pulls off. Be careful as there are two cables attached to htis panel. This should take care of your issues.
Pete....Digital TV & Radio in NC
May 16, 2009 | Philips 55PP9401 55" Rear Projection...
RCA HDTV MENU AND VOLUME CONTROL POPS ON AND OFF SCREEN.
My TV was doing the same thing. Someone told me to disconnect the front menu buttons and this worked for me. The board goes haywire. You have to take off the front black panel on the bottom first then the grey front panel where the controls are. Once you do this you will see where there is a plug from tv to the panel where the control buttons are. Just disconnect. You will only be able to use your remote for TV. Its a cheap and easy fix. Just lots of screws to get the panels off and on. Good luck!
Apr 09, 2009 | RCA HD52W58 52" TV
Toshiba 35a44 problem
check the following power supply components
power transistor of the supply
zener diodes
rectifier diodes
Oct 15, 2008 | Toshiba 35A44 35" TV
Front panel controls are unresponsive
Check volume up switch in front panel locked continuously. If it is not take away the remote control from the TV or remove the battery in the remote. Because maybe the remote continuously sending volume up commands. Rarely this type problem occurs through remote control also. Even problem is not sorted there is problem in EEPROM ic (memory ic). This can be sorted out by the technical persons only. I hope this useful to you.
Aug 31, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
TV Won't Power Down; Change Channels; Change Volume; etc
sounds like maybe the remote contol is at fault.Do the front panel buttons work?
May 29, 2007 | Panasonic CT-32G9 32" TV
Panasonic TH-50PX75U Plasma HDTV Logo
141 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
