Question about Maytag LAT3600A Top Load Washer
Water leak from bottom
When the spin cycle was turned on, all the water started to spill out of the bottom of the washer. All the water hoses sems to be fine.
    Scholar:
  • 91 Answers
Then you may be leaking from the water pump. maybe is worn out, only way to find it is to remove the cabinet an do a load test an see if it comes from there, if the hoses are fine then check the pump.
Posted on May 27, 2009
Somtimes my washer will put too much water in, then when it starts to agitate the water spills over the top of the tub and onto the floor. it happens (but not always) on the initial fill and when filling...
Remove the front panel. Pull the plastic hose off the air bell on the front left side of the tub.
Use a toothpick to clean the residue out of the hole in the air bell. Replace the plastic tube.
Set the washer on SPIN and turn it on. After the spin cycle finishes start the washer normally.
Aug 10, 2011 | GE Washing Machines
Washer leaks when on spin cycle
drain is not working properly so that only spin is not starting
Jun 06, 2010 | Washing Machines
Fridgidaire FDB1250REC dishwasher comes on, fills some water in bottom then cycle stops but can hear motor turning on and off, water will drain when I try to start cycle again.
This seems to be the "anti flood" device at the base of the washer is triggered due to water at the base of the washer. This safety device consists of a polystireene float and a micro switch that detects water leaks/spills and automatically puts the washer in pump out mode. You need to find the leak (hose or clamp)dry the base and rectifythe leak it before the washer works.
Mar 22, 2010 | Frigidaire 24 in. PLD2850 Built-in...
About 1 minute into the cycle water starts running out from underneath of the washer. Checked all the hoses that are connected to the back and none are leaking
this is either the front seal that goes from the outer tub to the front of the washer or a hole in the outer tub itself or one of the hoses underneath the seal and the hoses are easiest to check you can take a cup of water and slowly pour it into the front seal. take care not to overfill it to where it spills into the tub and see if you are getting water on your floor from that. the hoses tip the washer up onto its back and look at them from the bottom for any cracking etc. the tub itself can only rust out on some of the neptune models or on others is plastic and can get punctured. just have to look for damage with a light and a mirror.
May 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Water level high when spin/drain cycle begins.
The water level is higher when in the rinse mode; but it should never leak. Examine the interior through the rear, there should be a loose hose somewhere. Or at the filter area. Plug off the mains caution.
Feb 28, 2009 | Kenmore 22932 Top Load Washer
Water Leaking From Calypso, Won't Drain Completely
the bag type device is an overflow and should never have "water"in it, but it will get suds if you are using the wrong type of soap.
you need to use "HE" soap as it is a non-sudsing soap and thats why you are getting suds leaking from your unit.
just run the rinse and spin cycle until the suds are gone. then use the right type of soap and it will work properly with no leaks.
Jan 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer won't spin and drain properly
i've pulled stuf from many a calypso pump and its not the funest pump to clean.some designs never get stuff in the pump others its like theres a sock magnet in there or somthing.your has got a sock magnet.take off the frount and you will see the pump on the right.white,it has two hoses.take the inlet off first if eazyest then will only have to take one hose.you can geter done.God bless,tom
Jan 03, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Maytag LAT3600A Top Load Washer Logo
143 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
