Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet model GHW9100LQ1belt slides to back of pulley
Just replaced the belt on my front load washer, leveled the machine yet when I turn the drum the belt slides toward back of pulley, will slide off and break again if I try to use my machine
  • 51 Answers
DO YOU HAVE THE CORRECT BELT? DO THE GOOVES MATCH THAT PULLEYS? IS UR MOTOR PULLEY ON GOOD? DO YOU HAVE ANY RESTRICTIONS IN UR DRUM /BASKET CAUSING IT NOT TO TURN?
ARE YOU USING HE DETERGENT?
Posted on May 16, 2009
My whirlpool duet washer is frozen and locked. It says it has 25 minutes left on the cycle and I can hear the motor trying to work, but nothing is happening. I unplugged it and nothing has changed. ...
I had the same problem with ours, turns out the bearing in the hub seized. Took off the belt, motor turns just fine. If you take the back cover off, (unplus washer first) slip the belt off the pulley, and the pulley still won't spin freely, then you have the same problem.
Not sure how expensive the fix is, hub assembly is $200
Sep 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer wont spin ...motor runs but drum doesnt
If this is a Duet front loader, you need to check to see if the drive belt may have broken, or slipped off the drive pulley behind the wash tub.
To access and replace/reinstall the belt, the following link explains:
http://www.fixya.com/support/r3609900-drive_belt_installation_whirlpool_front
If you have any questions, or if the model washer you have is different, please post back and let me know. I hope this helps you.
Jun 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How to replace belt on a whirlpool front loading washer,
This is an easy fix and I'lll be glad to help. I know they are heavy, but pull the washer away from the wall. If you can get behind with the water hoses and drain connected more power to you. Do however unplug the machine.
Now, there is a panel at the back of the washer with.. 8 screws i think. These are 9/32 nut driver I believe. Once this panel is gone set it aside. You are now face to face with the belt. Take the old belt off (if it is still there). Now, take the new belt and loop it on the motor shaft first. Make sure each rib is in a groove on the motor shaft. Then loop the other side on the large pulley on the back of the tub. Naturally this is a tight fit, but put some of the belt on the pulley and rotate the pulley. This will pull the belt onto the pulley and you will be done!
Let me know if I can be of further assistance :D good luck!
May 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How to replace the belt on a whirlpool duet washer
To replace the drive belt on a Whirlpool Duet washer, follow these steps:
1. Unplug the washer and remove the rear panel.
2. Place the drive belt on the drive motor pulley with the ribbed side on the drive motor pulley. Leave a one-groove gap between the belt and the end of the pulley.
3. Take both hands and pull straight up on the belt and place on the drum pulley beginning on the left hand side.
4. Hold the belt firmly in place and slowly turn the pulley to the right while holding the belt in place. The belt will eventually align and hold in place on the drum pulley.
NOTE: This may require some effort to get the belt in place.
If you have any questions, please let me know. I hope this helps you.
Sep 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Belt on whirlpool duet washer ghw9100lw1
This can be a finger buster. I put it on the motor pulley and roll it onto the tub pulley. I have seen others use a large crowbar to slide it over the motor pulley last but that seem risky to me. It is a very tight fit.
Eric
Jun 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Belt on Whirlpool Duet GHW9200LQ is broken
install belt onto motor pulley first then pull on side of belt onto spinner pulley holding belt onto pulley rotate spinner pulley until belt pulls onto pulley completly
Dec 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool ghw9100l belt will not stay on drum drive pully
I already fixed this problem with the same washer. You need to replace the metal yoke that spins. Its loose. Remove and replace the nut also that hold the yolk.
Nov 07, 2006 | Whirlpool GHW9100L Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
300 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
