Question about Maytag Neptune FAV6800AW Top Load Washer
All buttons don't light up on fron of washing machine
Put a load of clothes in....need cotton sturdy,....stuck on delicate wash....hot water lights up but nothing else....help.....please
Sounds like there is no help for this idiot.  With a name like grits, they probably have trouble reading and couldn't follow steps to a solution anyway.
Posted on Oct 22, 2007
  • 447 Answers
Try unplugging then repower up, if still no response ill step you through another check.
Posted on Oct 15, 2007
Clothes in bosche washer gets tied up in knots in spin cycle
Are you running a load according to the care labels?? If you run delicate or easy care items on a cotton wash this can happen. Just because an item is 100% Cotton doesn't necessarily mean it will tolerate a cotton cycle check the care label. Also, if for example a cotton cycle is 6Kg, the easy care will be 3-4Kg, Delicate and woollens will be approx 2Kg. Overloading can cause items to knot during cycle. Finally, check that your inlet water is not too hot. Repost if you need any further assistance
Feb 19, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
I get an NF error code and the washer sounds like it's filling, but never does, and then there is water in the detergent dispenser.
Hi
Thanks for using FixYa. Error NF means No Fill. The washer has tried to fill but was unsuccessful. NF indicates No Flow. There is something that is interrupting the inbound flow of water to the washer, either hot or cold. Sometimes this happens when water service in the area is interrupted, creating an air pocket that causing the water valve not to sense water. Try running the diagnostic test by:
  • Press the delicates and heavy soil keys together for 3 seconds.
  • You are in the service mode.
  • Now, press wrinkle free key, cold water should start entering.
  • Then, press the cotton sturdy and hot water should flow.
  • To exit the test mode, either unplug the machine or press the delicate and heavy soil again for 3 seconds.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 22, 2010 | Samsung WF328AA Front Load Washer
LED is flashing nF. What does this indicate? Washer is a front load Maytag Neptune, mod# MAH 8700 AWW.
Hi
Try running the diagnostic test by—
Thanks
Rylee
Aug 25, 2010 | Maytag Washing Machines
Cotton/sturdy button not working on the select fabric
"I have the maytag neptune mah5500bww. the cotton/sturdy button" it has an led read out.
Jul 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag a112 manual on how to add bleach AND fabric softener
Hi
Choosing Your Detergent, Bleach, and Fabric Softener..
Learn what the different items you need to wash your laundry.
Liquid Laundry Detergent and Fabric Softeners
When using liquid laundry detergent, you do not want to poor it directly on your laundry. The dyes in the liquid laundry soap could stain your clothing. You will want to start your washing machine and add the liquid laundry soap while the water is filling the washing machine.
You then can add your laundry once you have about and eighth of the washing machine tub filled. This will ensure your laundry doesn't become stained by the detergent. You should only add the amount that is poured into the cup to the fill line. When you add more, you could find yourself wading through mounds of bubbles overflowing from your washing machine.
The same reasoning applies to liquid fabric softeners. However, liquid fabric softeners are added to the washing cycle after the initial washing cycle is finished. You will want to add the fabric softener once the washing machine has filled with water and started to agitate. This keeps the fabric softener from touching the laundry and will work it into your clothing better.
Powdered Laundry Detergent
You will want to add one cup of loose laundry detergent to your washing machine in the same manner you would do the liquid laundry detergent. By doing this, the powdered laundry detergent will dissolve easier.
Bleach
When adding bleach to your laundry, there is a small triangular cup in the corner of your washing machine. By adding one cup of bleach into that dispenser, the bleach will be added to the laundry at a precise time during the wash cycle.
Setting Your Washing Machine
Most washing machines have three or four cycles. For instance, the Maytag Washer I have has four cycles, regular, permanent press, delicate, and soak.
Regular Washing Cycle
The regular cycle is used for the following types of clothes and other apparel:
• Jeans
• Towels
• Blankets
• Sheets
• Quilts
• Bedspreads
The soil types for this cycle are heavy, normal, and light. This means clothes or other articles that are lightly too heavily soiled should be washed in this cycle. This is due to the washing cycles can be set from a minimum of eight to fourteen minutes maximum. You can use all three of the water temperatures in this cycle.
1Permanent Press Washing Cycle
The permanent press washing cycle is used on the clothes that may or may not need to be ironed.
Such as:
• Blouses
• Shirts
• T-shirts
• Under garments. This would be your unmentionables and socks.
• Jackets
• Sheets
• Baby Clothing
The soil types for this wash cycle are normal and light. The washing times for the permanent press cycle are six minutes to ten minutes. You can use all three washing temperature modes for this cycle as well.
Delicate Washing Cycle
The delicate washing cycle is normally used for sweaters, cotton, silks, and other fabrics that need to be washed with care.
The soil types for the delicate cycle are normal and light. The washing times for the delicate cycle are four and six minutes. It is best to wash your delicate clothes in warm or cold water. Always wash clothing that is more than forty percent cotton in cold water to prevent shrinking.
Soak Washing Cycle
The soak cycle would be used for heavily soiled clothing, such as, football and baseball uniforms. This will help rid the uniforms of caked on mud and grass stains.
You can also use this cycle if you wish to only bleach your white's once a week or once a month with bleach.
Washing Your Laundry
Choose the cycle you need for your laundry. Add the laundry detergent, fabric softener, and bleach (remember regular liquid bleach is for white clothes only.) Start the washing machine and let fill to dissolve the dry detergent or to mix in the liquid detergent.
Now add your clothes to the washing machine. Clothes the lid so the washing machine will continue to wash your clothes.
If you are using a Laundromat, put your clothes in the washing area and shut the lid or door. Add your detergent and other cleaning items in the correct compartments. Put in the correct amount of change so the washer will start.
Thanks for contacting fixya.com
Nov 13, 2009 | Maytag Washing Machines
I have had aqarius a hotpoint aqarius 1000 wm62p
It has a wide variety of wash programmes for white cotton, colourfast cotton, polyester, non-colourfast cotton, wool blends and wool itself. These standard programmes take from an hour and a quarter to three-quarters of an hour to complete.
There is also a quick wash programme lasting just under half an hour for lightly soiled items and a pre wash soak for heavily soiled items. The machine has four buttons providing extra facilities that can be set independently of the main wash programmes to give you a more comprehensive range of settings.
There is a rinse hold button, which I find extremely useful. When set this holds the clothes in the final rinse water until you are ready to unload the machine. You then release the button, let the machine go through the final spin and then you can unload the machine. It means that you don’t leave damp washing in the machine for the time between the cycle finishing and you unloading the machine, which would make for very creased clothes. There is also a button to depress if you want to use the super rinse facility. This merely increases the volume of water in each rinse so that the clothes are rinsed more fully. I have never used this particular facility, as the ordinary rinses are fine for my needs.
The next button allows for a slow spin. I find that this one is really useful for the items that I need to iron as it means that they don’t come out of the washing machine as creased as they normally would on a faster spin. The only problem with this is of course that the clothes are not as dry as they would otherwise have been. The final button is used to set the economy wash feature. This means that the washing machine’s own heating system is not used and the wash is done with the water at the temperature entering the machine from your hot and cold water tanks. This of course means a cooler wash so it’s only suitable for lightly soiled items.
The door remains locked during the wash programmes so that it cannot be opened accidentally and it can be locked when not in use too if you have small children who might get into mischief! The other big selling point for this particular model is that it gauges the size of the load and uses the correct amount of water needed eliminating the need for the half-wash programme. This also means that it is both water and energy efficient
Mar 25, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Is fading and shrinking my clothes
low temperature and low rpm of motor,must try this.
Feb 16, 2009 | Frigidaire FTF2140F Front Load Washer
Water
its probably normal as new machines now only put in enough water to saturate the clothes its only the rinse or wool/delicate cycles that use a higher water level
Mar 01, 2008 | GE Energy Star WCVH6260F Front Load Washer
Not washing clothes
Sounds like you need a new timer.  Sorry.
Oct 14, 2007 | Zanussi IZ161S Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
51 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
