Question about Whirlpool Washing Machines
Washer goes through wash cycle then quits
Does nothing after wash cycle
no spin
no drain
    Scholar:
  • 42 Answers
Well, it could be a timer, but it could also be something easier and cheaper...
There is a sensor that detects whether or not the lid is closed.
If that sensor is maladjusted or loose the washer will "think" that the door is open and it'll stop and sit until the door is closed.
So, look at the lid.... It will likely have a protrusion that will stick through the top of the washer. If you find a hole/protrusion, you could try looking with a flashlight to see what might be going on. You could also stick an object into the hole to see if you can manually activate the sensor, and therefore the washer.
Now I gotta say -- if you put something into the hole to activate the sensor, DON'T USE ANYTHING THAT CONDUCTS ELECTRICITY.
I keep a set of wooden chopsticks around the house at all times. First the cat likes to play with them, and second they come in handy for tasks such as this one.
If you determine that the sensor is the problem, you still need to fix or adjust it, or at least you can tell the repairman that you have diagnosed the problem -- and he won't be able to sell you a $250 dollar timer.
good luck
BTW, if you decide to get a set of chopsticks for household use, and if you have a cat, I'd recommend USED chopsticks. First, you'll get a good Chinese meal, and I've found the cat likes used chopsticks better than new ones.
Posted on May 13, 2009
Why did my washer quit spinning out in spin cycle
Quite often the problem with spin cycles is that the cycle cannot start until a sufficient amount of wash/rinse water has drained. So what will often happen is that the washer drains, the cycle starts, a lot of water comes out of the clothes, it stops, waits for the water to drain, then restarts. If the drain pump or drain lines are restricted or blocked or the pump is faulty, the unit may never achieve spin cycle.
Sep 18, 2014 | Washing Machines
Our washer quit going into going cycle yesterday.
one click clockwise to see if will start if not start check carbons
Dec 20, 2009 | Washing Machines
My washer won't complete the final spin cycle. It goes through the wash and drain OK but won't spin, clothes are soaking wet. I removed the drain pipe and made sure it was not blocked, also removed and...
Hello, problem here is the spin control board is bad. Remove panel under the door and you can locate the spin control at the rear right of the machine screwed to the floor. Replace it and you will be all set. Mike
Nov 09, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Won't drain or spin
my hot pointtopload will not spin or wash
Jul 07, 2008 | Hotpoint VBSR3100D Top Load Washer
Not draining
what happens once it quits and you advance the timer back to a nother spin cycle does it spin or does the motor not start back
Apr 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
94 people viewed this question
Dan Webster
Dan Webster
Sal De
