Question about LG 42PX5D 42 in. Plasma HDTV
Connecting PC to TV
Getting no signal, can you help?
  • Anonymous Jan 03, 2008
    when i turn the comp on it starts up and then says NO SIGNAL
    Brigadier General:
  • 6,966 Answers
You have to activate the external/dual monitor feature of your PC.  If it's a laptop, it's Fn + F? key and if your PC is a desktop you have to go to the Display Properties, Settings tab, Advance button.
Hope this be of some help/idea. Post back should you need additional information.
Good luck and kind regards.
Posted on Oct 15, 2007
When connecting tv to pc i'm getting an error message 'no signal input detected'
Did you click on the source button? Also you have to go to your desktop right click with the mouse thern click on properties you will go to your display settings you should see 2 display squares 1 & 2. now you can clone or extend. Another thing it would help to let us know you OS ie win xp or 7 or whatever. Whether you've got Nvidia or ATI or onboard Graphics. So I'm just giving you the basic info..Hope that helps Merry Xmas.
Dec 27, 2012 | Wharfedale Televison & Video
I have done an autotune on my sony bravia tv but am not getting channel 9 sbs. the television in the bedroom is a smaller digital tv and that picks up all the channels. the two tv's are connected
Is the splitter an amplified splitter or not? Have you tried the channel search when you connect the antenna directly to the TV? (Disconnect the cables from the splitter and use a coupler to join them together.) Tuners do vary in their sensitivity. For digital signals, your TV should report the signal strength. This is often under the Settings sub-menu. Some TVs will give this information in the Channel Edit option.
If the straight through connection gives a better signal, check your antenna direction and try a different splitter. Amplification will often help; however, when my amplified splitter was damaged the less sensitive tuner lost a number of channels that the other TV received. (Looking at the signal strength, one TV was getting adequate signal with one bar out of 8. The other needed at least 4 bars to process the signal.)
I hope this helps.
Feb 01, 2012 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Can't connect to pc
How are you trying to connect to the PC? Does your video card support TV-out?
If you are trying to connect VGA to component video, you need a converter like this: http://www.svideo.com/pctocomponent.html . There are similar ones for PC to composite video. The VGA to component video cables will not work since the two signal formats are different.
Some video cards do have a TV-out option, you will need to read the documentation to set up that option. (Those cards come with a special dongle to connect the card to the TV cable.)
If you have the converter and are not getting the signal to the TV, first check that the computer video is set to use the external monitor. (This may need to be enabled in the BIOS.) Next check that the converter is working. (Try connecting to a different TV or this TV to another computer.) Try different cables and make sure that they are fully seated to all three devices. Replace the converter if you find that it has failed. (If it is under warranty, send it to the manufacturer.)
I hope this helps.
Jan 16, 2011 | Emerson EWF2703 27" TV
I have A three year old AKAI 42 inch plasma tv---PDP4273M1---Mostly used as PC monitor. It was working just fine when I turned it off. When turned back on the next day, the on indicator light came on and...
Check to see what input setting the tv is on. It could still be looking for a signal from the pc input connection and no pc is hooked up thus getting no signal. Have the device you are trying to display on the tv connected and turned on and cycle through the inputs on the tv until you get a signal.
Sep 07, 2010 | Akai PDP-4216M 42 in. Plasma Television
Problem just started. Getting na signal on TV.
1. Remove the video/display cable from both TV & Laptop.
2. Again Connect the two devices properly.
3. Press "Function Key+F5" to connect to the TV (External Display)
4. Also put your TV in "TV/AV" mode.
tell me if it don't helps...tc! :)
Jan 05, 2010 | Toshiba Laptop Computer Battery PA2510,...
I am trying to connect my acer PC to a tv but get
The inputs on a TV are normally via the ariel and go into a pre-amp
To get a signal in you, would again, normally connect to the RGB or Video in which bypasses the pre-amp.
The VGA cable will be outputting a digital signal which a monitor will understand but a TV will not as it prime supply is via an analog signal
You may be able to get a connection if you process the signal through a freeview box which changes the signal from analog to digital
Jul 01, 2009 | Acer Aspire 5102WLMi Notebook
Im trying to get my sattelite signal to come thru my computer. I have the tv card installed with the vista drivers. I had no problem getting cable thru on this. But now I have sattleite tv and now Im...
There is no real way to get satellite signals into your PC. There are many companies on the net that are selling software that supposedly does this and they are all a scam. Getting cable is easy because your cable connects to the TV tuner card you installed and then converts this into the various channels. Satellite tuners work completely different.
Apr 14, 2009 | Microsoft Windows Vista Home Basic for PC
Attempting to connect PC to Philips 32pfl3403d TV, getting no sig
I had the same problem had to buy a s - video lead then when connected hold in function button n f4 to send the signal
Mar 16, 2009 | Philips 32PFL3403D/27 32 in. LCD TV
Connecting pc to grundig32 tv - msg out of range
I am going to suggest with that message, the the TV does not understand the signals it is getting from the PC.
Reboot the laptop while connected to the TV, and turn the TV off, then On, while the PC is connected. If you continue to get the message, look in the manual for the TV to determine the reason for the message.
Jan 23, 2009 | PC Connection FastCAT 5e Patch Cable...
Hi there, my viewsonic monitor VX912 is not getting a signal from my computer. I first checked to see if the connections were good. No joy ther! so I then tried to see if the cable was faulty(my monitor...
Is your tv HD, it may have worked on the digital signal, but perhaps it switched to a HD program, and it doesnot support that HD signal, If not it may be a switching problem
Dec 16, 2008 | Evesham Computers & Internet
LG 42PX5D 42 in. Plasma HDTV Logo
