Question about LG 42PX5D 42 in. Plasma HDTV
Trying to connect PC
All is connected, and were getting no signal. I changed the input to RGB-PC, even - still nothing. ANyone??
  • laurakoi Nov 14, 2007
    Thank s for the help!
    It was the Fn, F4 key combo i didnt know about.
    Thanks for the advice!!!!
    Laura
After cunnecting did you switch to monitor on pc
Posted on Nov 13, 2007
    Brigadier General:
  • 6,966 Answers
pls see your other post.
Cheers.
Posted on Oct 15, 2007
Getting a no RGB signal on my vizio tv model #E371VL any suggestions?
Try changing the input on the television with the remote or on the television control panel. Apparently you don't have anything plugged into the RGB connections.
Dec 31, 2014 | Vizio Televison & Video
Blue screen that says RGB on my vizio
I'm sorry for the difficulties you're experiencing in watching programs on the TV. Since the screen says RGB, it appears that you've selected input as RGB(VGA, also known as PC input). If you have nothing connected to PC input (RGB), please change the input to HDMI or component or what ever it is by using the input button on the Remote of the TV.
In some TVs INPUT Button is labeled as TV/Video. Press it repeatedly to change the input from one to next.
Thanks for understanding. Please let me know if you require any clarifications.
Jul 05, 2011 | Vizio L32 32 in. LCD HDTV
I am trying to connect my acer PC to a tv but get
The inputs on a TV are normally via the ariel and go into a pre-amp
To get a signal in you, would again, normally connect to the RGB or Video in which bypasses the pre-amp.
The VGA cable will be outputting a digital signal which a monitor will understand but a TV will not as it prime supply is via an analog signal
You may be able to get a connection if you process the signal through a freeview box which changes the signal from analog to digital
Jul 01, 2009 | Acer Aspire 5102WLMi Notebook
Trying to connect my laptop to my lcd hdtv.
change it to VGA and put the audio in the mic jack on the laptop and in the audio in jack on the tv.
Jun 17, 2009 | Konka DLC-3211UT 32 in. LCD Television
Stuck in RGB input.
i imagine your problem is over by now one way or another, but for anyone else experiencing this problem, thought i would share. your rgb input is tripped and needs to be reset, there are multiple things that "may" fix this, but the sure fire method is to connect a laptop to the rgb input, make sure you change your display settings on the laptop to "external monitor" and change the monitor selected in display settings on your computer. When the TV recieves a signal (which is what it is wating on and why it is frozen) it will then allow you to change input and will not turn off. Make sure your computer is running and all display settings are set before turning on tv so it does not time out and shut off before you can get it to pick up the signal
Jun 06, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
While trying to change channels, my t.v. displayed ''no signal'' and then shut itself off. Now, when I turn it on, it says no signal and turns itself off after a few seconds.
Turn the television on and as soon as the screen turns on repeatily press the input button or change the input to whatever input you are using from a source device. As long as you change it to anything other than RGB.
Your television is essentially a big computer monitor with multiple inputs and a tuner. When using your computer and shutting it down the monitor will go in a power save mode. You don't need to shut off your monitor due to this power saving mode. When you power up your computer your monitor automatically turn on.
With the VIZIO and the RGB (computer) input the television will act just like a computer monitor. When you have a computer connected it will power down automatically when you shut off your computer. When you turn your computer on the VIZIO will automatically come out of standby mode. This is through RGB only.
This is normal operation for the VIZIO but can see confusing when nothing is connected to the RGB input. If you change your television input to RGB it will sense no signal on the input and will go into standby mode after about 5 - 10 seconds. If you were to send a signal to the television through RGB it would automatically kick on.
Apr 05, 2009 | Vizio L37 Television
Connecting pc
Did you change the input on your tv to the corresponding input that your RGB cable is connected to?
Mar 19, 2009 | Sharp LC-32SB24U 32 in. LCD TV
LG 32LG30 no signal when pc and tv r connected via rgb cord
For No signal try- Updating your Video drivers, and making sure it shows a connection on your laptop ( by going to propertys on desktop and then dysplay)
For format try- Updating and or turning down the screen resulotion becuase the size differs on screen even if you think it shouldnt.
Mar 14, 2009 | LG 32LG30 32 in. LCD HDTV
No RGB imput signal
You need to change the input signal, get into the menu on your monitor and change the signal from rgb to dvi, hdmi or vga dipending on what cable you using for connection.
There is NO rgb connector on that monitor
Good luck
Dec 05, 2008 | Balance CM2015 15" LCD Monitor
CTX
Neichi could this monitor be set to receive dvi signals and not rgb even if he has the rgb hooked into the monitor? so in menu select rgb input?
Mitch, monitors don't conflict with windows generally usually they(windows os) will install a basic generic driver to run the monitor, and you should do this when changing monitors before you hook up the new one, your description really lacks any concrete description where are the "black and blue errors" what do they look like last I have had problems with modems interfering with video so I would remove the modem and see if the problem goes away.
Apr 27, 2008 | Gateway FPD2275W LCD Monitor
LG 42PX5D 42 in. Plasma HDTV Logo
229 people viewed this question
